    Default Calendar stuck on loading
    55 Posts 2 Posters 13.3k Views 2 Watching
      rushmuzik @sdetweil
      @sdetweil How do I fix that? Is there a way to undo? This is what I see in pm2 status
        sdetweil @rushmuzik
        @rushmuzik you only have 1, so no issue…
        pm2 --help
        has lots of options
          rushmuzik @sdetweil
          @sdetweil ok. Where would you suggest I go from here? COuld it be the Firefox ESR causing the issue?
            sdetweil @rushmuzik
            @rushmuzik I don’t know yet… I posted a potential fix for you to try, based on the error shown
              rushmuzik @sdetweil
              @sdetweil Yes, I saw that. I tried it. It did’t work.
              I wonder if something in here might help
                sdetweil @rushmuzik
                @rushmuzik no idea…
                trying to get ff installed
                  @rushmuzik well i can recreate it. its a bug in firefox. trying to find a workaround, 3 so far dont
                    rushmuzik @sdetweil
                    @sdetweil OK so I’m not crazy! Good to know! It amazes me how much you know!
                      sdetweil @rushmuzik
                      @rushmuzik just learned about this today, and google has a lot of info. wading thru it is time consuming.
                        rushmuzik @sdetweil
                        @sdetweil Absolutely. I appreciate all the attention you’ve given to this so far. You have been a big help to the community.
                          rushmuzik @sdetweil
                          @sdetweil I’ve searched all over google but I still haven’t found a viable solution.
                          Do you think a previous socket.io version would fix the problem? my current version is 4.8.1
                            sdetweil @rushmuzik
                            @rushmuzik no idea yet
                              rushmuzik @sdetweil
                              @sdetweil The socket.io GIT lists this as a possible solution to the bad request error however I’m not quite sure where to put it.
                              Installation: npm i http-proxy
                              const httpProxy = require(“http-proxy”);
                              httpProxy
                              .createProxyServer({
                              target: “http://localhost:3000”,
                              ws: true,
                              .listen(80);
                                sdetweil @rushmuzik
                                @rushmuzik me either. socket.io is setup in server.js
                                  rushmuzik @sdetweil
                                  @sdetweil I’m suspecting it might be an update to the socket.io in the recent 2.29 release which I’m using. I suspect 2.28 or prior my not have this issue
                                    sdetweil @rushmuzik
                                    @rushmuzik 2.29 uses socket.io 4.8 where 2.28 uses 4.7.5
                                    you could install 4.7.5
                                    cd~/MagicMirror
                                    npm remove  socket.io
                                    npm install socket.io@4.7.5
                                    i have company today so it will tomorrow really before i can test
                                      rushmuzik @sdetweil
                                      @sdetweil I reverted back to socket.io@4.7.2 that was used on MagicMirror@2.26.0 and that fixed the issue! I tried socket.io@4.7.5 but that didnt work. So I went back to @4.7.2 and that fixed it. It might just be a compatibility issue with Firefox ESR. Mystery Solved! Thanks for all your help!
                                        sdetweil @rushmuzik
                                        @rushmuzik awesome!!! thanks for the feedback
                                          rushmuzik @sdetweil
                                          @sdetweil Thanks for all you do to help the MM community!
                                            sdetweil @rushmuzik
                                            @rushmuzik that change to socket.io@4.7.2 didn’t help my pi0w MM with firefox (running on next release or 2.29.0)
                                            • 2 / 3
