    Default Calendar stuck on loading
    55 Posts 2 Posters 16.2k Views 2 Watching
      sdetweil @rushmuzik
      @rushmuzik did firefox come up? those messages are from the server side
      but they were initiated by the browser side so some browser started loading the page from the server
        rushmuzik @sdetweil
        @sdetweil Yes, it came up and is running. Everything is working except the calendar. Just stuck at loading…
          sdetweil @rushmuzik
          @rushmuzik and there should be messages on the server side
            rushmuzik @sdetweil
            @sdetweil Strangly I didnt see any fetch messages for the calendar.
              sdetweil @rushmuzik
              @rushmuzik interesting, can you show messages after
              the point your browser at message
              those would be after the browser loads the web page
                rushmuzik @sdetweil
                @sdetweil This is as far as it goes. for some reason I dont get “Create new calendarfetcher for url:”
                  sdetweil @rushmuzik
                  @rushmuzik weird
                  can you
                  open the developers window and find the console tab and see if there is an error
                  i don’t know for sure how to do that on firefox. i will check it out in the morning running this way
                    rushmuzik @sdetweil
                    @sdetweil Definitely appears to be some errors in the console. Its CTRL + SHIFT + I to access it in Firefox
                      sdetweil @rushmuzik
                      @rushmuzik thanks will review
                        @rushmuzik OK i tested on my desktop ubuntu, and on pi4 with latest PI os (bookworm) 64bit.
                        I do not see that
                        what machine are you on? can u show the startup info section
                        this output comes after Launching application
                        [2024-12-19 08:19:24.759] [INFO]  System information:
                        ### SYSTEM:   manufacturer: ; model: ; virtual: false
                        ### OS:       platform: linux; distro: Debian GNU/Linux; release: 12; arch: arm64; kernel: 6.6.51+rpt-rpi-v8
                        ### VERSIONS: electron: 31.7.3; used node: 20.18.0; installed node: 20.9.0; npm: 10.1.0; pm2: 5.4.2
                        ### OTHER:    timeZone: America/Chicago; ELECTRON_ENABLE_GPU: undefined
                        S R 2 Replies Last reply Reply Quote 0
                          @rushmuzik
                          given the error you showed, can you try list change
                          edit MagicMirror/js/server.js
                          and down at the bottom
                          	this.close = function () {
                          		return new Promise((resolve) => {
                          			for (const socket of serverSockets.values()) {
                          				socket.close();   //<--- add this line
                          				socket.destroy();
                          save and restart MagicMirror
                            rushmuzik @sdetweil
                            @sdetweil This is what I’m using. with Firefox ESR as the browser because Chromium and regular firefox are no longer supported on a Pi zero. Also, I’m using an API to connect to my Tempest weather station and that works fine. In addition all the other default modules work as they should except for calendar.
                              sdetweil @rushmuzik
                              @rushmuzik pi zero. ok… let me set that up
                                rushmuzik @sdetweil
                                @sdetweil These are the steps I followed to set it up
                                https://www.davidgagne.net/2024/05/30/how-to-get-magicmirror-to-run-on-a-raspberry-pi-zero-w-rev-1-1/
                                  sdetweil @rushmuzik
                                  @rushmuzik ok, but because you said yes on step 2 to pm2
                                  you don’t need step 8 as it causes a duplicate app definition, which will cause TWO to start
                                  pm2 status
                                  will show you the apps defined
                                    rushmuzik @sdetweil
                                    @sdetweil How do I fix that? Is there a way to undo? This is what I see in pm2 status
                                      sdetweil @rushmuzik
                                      @rushmuzik you only have 1, so no issue…
                                      pm2 --help
                                      has lots of options
                                        rushmuzik @sdetweil
                                        @sdetweil ok. Where would you suggest I go from here? COuld it be the Firefox ESR causing the issue?
                                          sdetweil @rushmuzik
                                          @rushmuzik I don’t know yet… I posted a potential fix for you to try, based on the error shown
                                            rushmuzik @sdetweil
                                            @sdetweil Yes, I saw that. I tried it. It did’t work.
                                            I wonder if something in here might help
                                            • 2 / 3
