    Default Calendar stuck on loading
    55 Posts 2 Posters 15.1k Views 2 Watching
      rushmuzik @sdetweil
      @sdetweil Definitely appears to be some errors in the console. Its CTRL + SHIFT + I to access it in Firefox
        sdetweil @rushmuzik
        @rushmuzik thanks will review
          @rushmuzik OK i tested on my desktop ubuntu, and on pi4 with latest PI os (bookworm) 64bit.
          I do not see that
          what machine are you on? can u show the startup info section
          this output comes after Launching application
          [2024-12-19 08:19:24.759] [INFO]  System information:
          ### SYSTEM:   manufacturer: ; model: ; virtual: false
          ### OS:       platform: linux; distro: Debian GNU/Linux; release: 12; arch: arm64; kernel: 6.6.51+rpt-rpi-v8
          ### VERSIONS: electron: 31.7.3; used node: 20.18.0; installed node: 20.9.0; npm: 10.1.0; pm2: 5.4.2
          ### OTHER:    timeZone: America/Chicago; ELECTRON_ENABLE_GPU: undefined
          S R 2 Replies Last reply Reply Quote 0
            @rushmuzik
            given the error you showed, can you try list change
            edit MagicMirror/js/server.js
            and down at the bottom
            	this.close = function () {
            		return new Promise((resolve) => {
            			for (const socket of serverSockets.values()) {
            				socket.close();   //<--- add this line
            				socket.destroy();
            save and restart MagicMirror
              rushmuzik @sdetweil
              @sdetweil This is what I’m using. with Firefox ESR as the browser because Chromium and regular firefox are no longer supported on a Pi zero. Also, I’m using an API to connect to my Tempest weather station and that works fine. In addition all the other default modules work as they should except for calendar.
                sdetweil @rushmuzik
                @rushmuzik pi zero. ok… let me set that up
                  rushmuzik @sdetweil
                  @sdetweil These are the steps I followed to set it up
                  https://www.davidgagne.net/2024/05/30/how-to-get-magicmirror-to-run-on-a-raspberry-pi-zero-w-rev-1-1/
                    sdetweil @rushmuzik
                    @rushmuzik ok, but because you said yes on step 2 to pm2
                    you don’t need step 8 as it causes a duplicate app definition, which will cause TWO to start
                    pm2 status
                    will show you the apps defined
                      rushmuzik @sdetweil
                      @sdetweil How do I fix that? Is there a way to undo? This is what I see in pm2 status
                        sdetweil @rushmuzik
                        @rushmuzik you only have 1, so no issue…
                        pm2 --help
                        has lots of options
                          rushmuzik @sdetweil
                          @sdetweil ok. Where would you suggest I go from here? COuld it be the Firefox ESR causing the issue?
                            sdetweil @rushmuzik
                            @rushmuzik I don’t know yet… I posted a potential fix for you to try, based on the error shown
                              rushmuzik @sdetweil
                              @sdetweil Yes, I saw that. I tried it. It did’t work.
                              I wonder if something in here might help
                                sdetweil @rushmuzik
                                @rushmuzik no idea…
                                trying to get ff installed
                                  @rushmuzik well i can recreate it. its a bug in firefox. trying to find a workaround, 3 so far dont
                                    rushmuzik @sdetweil
                                    @sdetweil OK so I’m not crazy! Good to know! It amazes me how much you know!
                                      sdetweil @rushmuzik
                                      @rushmuzik just learned about this today, and google has a lot of info. wading thru it is time consuming.
                                        rushmuzik @sdetweil
                                        @sdetweil Absolutely. I appreciate all the attention you’ve given to this so far. You have been a big help to the community.
                                          rushmuzik @sdetweil
                                          @sdetweil I’ve searched all over google but I still haven’t found a viable solution.
                                          Do you think a previous socket.io version would fix the problem? my current version is 4.8.1
                                            sdetweil @rushmuzik
                                            @rushmuzik no idea yet
                                            • 2 / 3
