    weather forecast does not show on screen
    7 Posts 2 Posters 1.3k Views 2 Watching
    • kusselinK Offline
      kusselin
      Hello together…all a happy new year.
      what is my mistake becaus the forecast does not show…here is my config…
      MM is on update also the adapter.
      for infos thanks a lot
                  module: "MMM-OpenmapWeather",
                  position: "top_right",    // This can be any of the regions.
                                          // Best results in left or right regions.
                  locationID: "2xxx4", //Location ID from http://openweathermap.org/help/city_list.txt
                  appid: "xxxxxxxxx8",  //openweathermap.org API key
                        colorIcon: true
      			module: "weather",
      			header: "Weather Forecast",
      				type: "forecast",
      				locationID: "xxxxxxx", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
      				apiKey: "xxxf9xxx1xxxx"
        sdetweil @kusselin
        @kusselin did you get the new API key (v3) which requires credit card backing,
        AND location/locationID are not supported on 3.0, have to use lat/lon
        (and header title needs to be set manually)
        kusselinK 1 Reply Last reply Reply Quote 0
        • kusselinK Offline
          kusselin @sdetweil
          @sdetweil aha…thanks for the info…I didn’t know that…on my old system (not yet v 3.0) the prediction is still running…but o.k. now I know thanks to you.
          One question: is the forecast module this then here:
          https://github.com/Tom-Hirschberger/MMM-OpenWeatherForecast
          when not…can you send me the link please
            sdetweil @kusselin
            @kusselin on the module, you can use that or the default weather module supports forecast too
            • kusselinK Offline
              kusselin @sdetweil
              @sdetweil said in weather forecast does not show on screen:
              Hi sam, how can i unstand this with standard module an forecast display?
              what must i do?
                sdetweil @kusselin
                @kusselin from https://docs.magicmirror.builders/modules/weather.html#configuration-options
                  @kusselin did you get forecast to work?
