    Calendar Logic Changes
    9 Posts 2 Posters 2.2k Views 2 Watching
    • BKeyportB Offline
      @sdetweil I see the problem, I think.
      The logs I was using was in the console, those logs don’t show the source - PM2’s logs do.
      I think something has changed in how it’s putting together the entries.
      It used to be that maximumEntries: 99 - now it’s appearing to sort different or reach back further, so I need maximumEntries: 999 to see all my calendars show up.
      I do have past events active - as I like to see where I had things happen, just in case I need it…
      • BKeyportB Offline
        Ok, Sam - here’s what I got so far:
        Calendar Entries Calendar
        Huskies 12 https://gohuskies.com/calendar.ashx/calendar.ics?sport_id=3.
        Kraken 44 https://calendar.google.com/calendar/ical/a6fras24hof5ibrk9q1aeg0igg%40group.calendar.google.com/private-147cebc733aab31784e2ab7f18c13cbc/basic.ics.
        Main 334 [Not public]
        Mariners 247 https://calendar.google.com/calendar/ical/61db9ccd2c8e6f23041e3f43c30e7427f6bada47d75a73f673085d9cdbb02a03%40group.calendar.google.com/private-9781d54d004a17abd9f8647eabfa7e68/basic.ics.
        Seahawks 20 https://www.seahawks.com/api/addToCalendar/ag/d?text=Seattle+Seahawks+Games.
        Sounders No Data https://calendar.google.com/calendar/ical/3vejg64nfe9hk5odcphufgis14%40group.calendar.google.com/private-ae3d986ef6488a425755baf7198a1c99/basic.ics.
        Utilities 107 https://recollect.a.ssl.fastly.net/api/places/BC71002A-F27F-11E8-B5B7-6853A40EAB6C/services/579/events.en-US.ics?client_id=91264B66-7113-11ED-8C28-2101D6C077E5.
        ARES Parsing https://calendar.google.com/calendar/ical/5hsiiq8t4lh01m2fge21688vtjmj6e6s%40import.calendar.google.com/public/basic.ics.
        Holidays 55 https://calendar.google.com/calendar/ical/en.usa%23holiday%40group.v.calendar.google.com/public/basic.ics.
        The calendar marked “No data” isn’t currently working from host, It can be ignored.
        The calendar marked “Parsing” is spitting out data in debug mode, but when calendar turns around and broadcasts, it’ll broadcast zero entries. Only truly private URL has been blanked.
        here’s my config - minus the calendars:
                                module: "calendar", // Built in
                                //position: "top_center",  // Currently hidden
                                classes: "page1 page2 page3",
                                        animationSpeed: 0,
                                        broadcastEvents: true,
                                        broadcastPastEvents: true,
                                        fetchInterval: 60000, // minimum 1 minute.
                                        maximumEntries: 999999,
          sdetweil @BKeyport
          @BKeyport fetch every minute is too often. also we increased the fetch timeout to 30 seconds, so there may not be enough tine to parse before another fetch
          if running w pm2 ALL console messages are captured as you dont have an active console running.
          i would stop using pm2 while diagnosing, just use npm start
          what do you mean one cal is outputing debug? w default cal its all or nothing per instance
          id like to see that log, email to me
            @BKeyport fix see
            https://forum.magicmirror.builders/topic/19282/version-2-30-0-calendar-fix-for-clipping-broadcast-events
            • BKeyportB Offline
              @sdetweil That fix helped. A minor configuration error fix helped too. I think I’ve got it back working the way I wanted it.
                sdetweil @BKeyport
                @BKeyport awesome
