    Calendar is showing a day late
    calendar
    5 Posts 2 Posters 1.0k Views 2 Watching
      angeliKITTYx
      calendar
      Every color on here is a different Google calendar. For some reason, my two newest calendars, trash and recycling schedule (🗑️&♻️) are showing up a day late.
      On Google, they’re on Tuesdays. They originally showed on Tuesdays, but around DST, they started showing up on Wednesday. I don’t know if it messed up exactly on DST. I just noticed it a few days after.
      I checked my calendar settings and the time zone is set the same as all of my other calendars that are behaving correctly. All of my other repetitive all-day events are showing correctly.
      Any idea what’s causing this?
        sdetweil @angeliKITTYx
        @angeliKITTYx the calendar module has problems.
        an updated version is coming on next release Jan 1, which should resolve these problems.
        you can test it now by using the develop branch where all the changed are staged.
        see this
        https://forum.magicmirror.builders/topic/14327/testing-new-fixes-or-solving-current-problems-with-next-release-code
        for how to get the develop branch ready.
        note you will need to run
        npm run install-mm
        if you use my upgrade script, it will switch you back to the master branch for you before upgrading
        A 2 Replies Last reply Reply Quote 0
          angeliKITTYx @sdetweil
          @sdetweil thanks Sam! I’ll just wait until the update on the first. I appreciate the quick reply!
            @sdetweil happy new year! Since the first of the year, a few of my calendars aren’t showing up at all. I have 7 different calendars loaded in my module, but only 2 of them show up now when I launch MM. Is there something I can do to fix them?
              @angeliKITTYx this is showing in CalendarExt3??? or default view??
              if Ext3, did you put on the fix for broadcast clipping??
              see https://forum.magicmirror.builders/topic/19282/version-2-30-0-calendar-fix-for-clipping-broadcast-events
