    MM-Watcher - MagicMirror Config.js Auto-Refresh Script
    10 Posts 3 Posters 1.8k Views 3 Watching
    • plainbrokeP Offline
      plainbroke @chrisfr1976
      @chrisfr1976
                  "name":"mm",
                  "script":"./mm.sh",
                  "cwd":"/home/pi",
                  "watch":[
                      "//home/pi/MagicMirror/css/custom.css",
                      "/home/pi/MagicMirror/config/config.js"
      I use a file called mm.json ,don’t remember where I got this info, but it still works great. I have it and a copy of the mm.sh in the /home/pi/ folder… the one your setup goes to when you do cd then enter.
      this is the code inside it.
      pm2 delete all that have to do with MagicMirror startup.
      Then do a pm2 start mm.json then pm2 save and PM2 saves it as mm.
      Now anytime I change something in config.js MagicMirror restarts.
      I wish I was smart enough with code to figure out how to get it to restart when I modify the custom.css too.
      S C 3 Replies Last reply Reply Quote 0
        sdetweil @plainbroke
        @plainbroke great!!! i will fix my json file !!!thanks
          chrisfr1976 @plainbroke
          @plainbroke
          my mm.sh also restarts the mirror. But my intention with was doing only a refresh to save a lot of time. My restarts script sleeps 15s before it is executed. So i created a seperate refresh script.
          Regards, Chris.
            @chrisfr1976
            Ok mine doesn’t wait. I usually do a list of changes I have researched.
            So the complete restart of MM is ok for me.
            Right now trying to figure out a couple of modules that are not loading…
              @plainbroke interesting, my file and your have just two changes
              1. you have the cwd: setting
              2. you have followSymlinks (which we don’t have any of)
              I added cwd to mine and now MM restarts… weird
                plainbroke @sdetweil
                Glad it works for you.
                I have no Idea where it came from. I would guess from someone on this forum.
                  @plainbroke well, mine looks nearly identical… just missing the cwd…
                  I opened an issue about this 2 years ago, never got a response…
                  and adding cwd (current working directory)
                  I don’t know how that matters… but whatever… it works now…
