    MM-Update doesn´t work
    12 Posts 2 Posters 2.0k Views 2 Watching
      sdetweil @kusselin
      @kusselin also apply wont install over same version, you have to use
      force
      instead
      i wont let you mess up your system accidentally
      because we aborted before doing the
      npm install, that still isnt done
      kusselinK 1 Reply Last reply Reply Quote 0
      • kusselinK Offline
        kusselin @sdetweil
        @sdetweil Hi Sam, I have not installed MM on the Raspi but in a Proxmox container Ubuntu 24…
        Sorry, but I don’t understand anything anymore…
        Can you please tell me step by step what I have to enter ?
        Thank you very much
        mm@MagicMirror-live:~/MagicMirror$ force
        Command 'force' not found, did you mean:
          command 'zforce' from deb gzip (1.12-1ubuntu1)
          command 'forge' from deb snap (2013-11-29-11)
        Try: sudo apt install <deb name>
          sdetweil @kusselin
          @kusselin proxmox is same as on pi. (i use vmware workststion)
          run the upgrade script again
          and replace the parm
          apply
          with
          force
          • kusselinK Offline
            kusselin @sdetweil
            @sdetweil aha ok, I didn’t know that…
            look now… does that fit now?
            mm@MagicMirror-live:~/MagicMirror$ bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)" force
            update log will be in /home/mm/MagicMirror/installers/upgrade.log
            doing test run = false
            Minimum Node version: v20.18.1
            Installed Node version: v20.18.1
            No Node.js upgrade necessary.
            Minimum npm version: V10.8.2
            Installed npm version: V10.8.2
            No npm upgrade necessary.
            saving custom.css
            upgrading from version 2.30.0 to 2.30.0
            fetching latest revisions
            > magicmirror@2.30.0 postinstall
            > npm run install-vendor && npm run install-fonts && echo "MagicMirror² installation finished successfully!
            > magicmirror@2.30.0 install-vendor
            > " && cd vendor && npm install --loglevel=error --no-audit --no-fund --no-update-notifier
            changed 3 packages in 5s
            > magicmirror@2.30.0 install-fonts
            > echo "Installing fonts ...
            > " && cd fonts && npm install --loglevel=error --no-audit --no-fund --no-update-notifier
            changed 2 packages in 3s
            > magicmirror@2.30.0 prepare
            > [ -f node_modules/.bin/husky ] && husky || echo no husky installed.
            no husky installed.
            added 479 packages in 47s
            126 packages are looking for funding
              run `npm fund` for details
            [sudo] password for mm:
            updating dependencies for active modules with package.json files
                    processing for module MMM-Fuel please wait
            added 17 packages, and audited 18 packages in 5s
            8 packages are looking for funding
            found 0 vulnerabilities
                    processing complete for module MMM-Fuel
                    processing for module MMM-RNV please wait
            added 27 packages, and audited 28 packages in 12s
                    processing complete for module MMM-RNV
                    processing for module MMM-PublicTransportHafas please wait
            > mmm-publictransporthafas@3.0.1 prepare
            > [ -f node_modules/.bin/husky ] && husky || echo husky is not installed.
            added 63 packages, and audited 64 packages in 20s
            19 packages are looking for funding
                    processing complete for module MMM-PublicTransportHafas
                    processing for module MMM-ioBroker please wait
            added 6 packages, and audited 7 packages in 2s
            1 package is looking for funding
                    processing complete for module MMM-ioBroker
                    processing for module MMM-COVID19-AMPEL please wait
            added 12 packages, and audited 13 packages in 2s
                    processing complete for module MMM-COVID19-AMPEL
                    processing for module MMM-Carousel please wait
            up to date, audited 1 package in 993ms
                    processing complete for module MMM-Carousel
                    processing for module MMM-Remote-Control please wait
            npm warn deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
            added 54 packages, and audited 55 packages in 6s
            12 packages are looking for funding
                    processing complete for module MMM-Remote-Control
            restoring custom.css
              sdetweil @kusselin
              @kusselin now it should start. unless that library is still a problem
              • kusselinK Offline
                kusselin @sdetweil
                @sdetweil you are once again my KING
                it runs after entering npm run server
                one question…what is a fetcher??
                [2025-01-14 19:24:04.725] [LOG]   Create new newsfetcher for url: https://www.n-tv.de/rss - Interval:                            300000
                [2025-01-14 19:24:04.734] [LOG]   Create new newsfetcher for url: http://www.tagesschau.de/xml/rss2 -
                …and does this mean that the next time I update, I should always replace the script with apply by -force correctly?
                  sdetweil @kusselin
                  @kusselin fetcher is the code in newsfeed and calendar that gets the data
                  no just use apply, we only do this at most 4 times a year
                  force is only needed to recover from user error
                  • kusselinK Offline
                    kusselin @sdetweil
                    @sdetweil thank you sam…topp service
