    MM-Update doesn´t work
    12 Posts 2 Posters 2.1k Views 2 Watching
    • kusselinK Offline
      kusselin
      hi @all,
      what is my problem? i tryd to update my MM but i have errors. Can anyone help me please.
      I read that the engine is not compatible but what must i do now??
      Ahh the node and npm version are not correct but i don´t know how the linux commandline must be?? Can anyone write here the line command for me in puuty to update
      Thanks a lot
      mm@MagicMirror-live:~/MagicMirror$ npm run server
      > magicmirror@2.30.0 server
      > node ./serveronly
      node:internal/modules/cjs/loader:1051
        throw err;
      Error: Cannot find module 'undici'
      Require stack:
      - /home/mm/MagicMirror/js/app.js
      - /home/mm/MagicMirror/serveronly/index.js
          at Module._resolveFilename (node:internal/modules/cjs/loader:1048:15)
          at Module._resolveFilename (/home/mm/MagicMirror/node_modules/module-alias/index.js:49:29)
          at Module._load (node:internal/modules/cjs/loader:901:27)
          at Module.require (node:internal/modules/cjs/loader:1115:19)
          at require (node:internal/modules/helpers:130:18)
          at Object.<anonymous> (/home/mm/MagicMirror/js/app.js:15:40)
          at Module._compile (node:internal/modules/cjs/loader:1241:14)
          at Module._extensions..js (node:internal/modules/cjs/loader:1295:10)
          at Module.load (node:internal/modules/cjs/loader:1091:32)
          at Module._load (node:internal/modules/cjs/loader:938:12)
          at Object.<anonymous> (/home/mm/MagicMirror/serveronly/index.js:1:13)
          at Module.load (node:internal/modules/cjs/loader:1091:32) {
        code: 'MODULE_NOT_FOUND',
        requireStack: [
          '/home/mm/MagicMirror/js/app.js',
          '/home/mm/MagicMirror/serveronly/index.js'
      Node.js v20.9.0
      and
      mm@MagicMirror-live:~/MagicMirror$ git pull && npm run install-mm
      Already up to date.
      > magicmirror@2.30.0 install-mm
      > npm install --no-audit --no-fund --no-update-notifier --only=prod --omit=dev
      npm ERR! code EBADENGINE
      npm ERR! engine Unsupported engine
      npm ERR! engine Not compatible with your version of node/npm: magicmirror@2.30.0
      npm ERR! notsup Not compatible with your version of node/npm: magicmirror@2.30.0
      npm ERR! notsup Required: {"node":">=20.18.1 <21 || >=22"}
      npm ERR! notsup Actual:   {"npm":"10.1.0","node":"v20.9.0"}
      npm ERR! A comp
      • kusselinK Offline
        kusselin @sdetweil
        @sdetweil aha ok, I didn’t know that…
        look now… does that fit now?
        mm@MagicMirror-live:~/MagicMirror$ bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)" force
        update log will be in /home/mm/MagicMirror/installers/upgrade.log
        doing test run = false
        Minimum Node version: v20.18.1
        Installed Node version: v20.18.1
        No Node.js upgrade necessary.
        Minimum npm version: V10.8.2
        Installed npm version: V10.8.2
        No npm upgrade necessary.
        saving custom.css
        upgrading from version 2.30.0 to 2.30.0
        fetching latest revisions
        > magicmirror@2.30.0 postinstall
        > npm run install-vendor && npm run install-fonts && echo "MagicMirror² installation finished successfully!
        > magicmirror@2.30.0 install-vendor
        > " && cd vendor && npm install --loglevel=error --no-audit --no-fund --no-update-notifier
        changed 3 packages in 5s
        > magicmirror@2.30.0 install-fonts
        > echo "Installing fonts ...
        > " && cd fonts && npm install --loglevel=error --no-audit --no-fund --no-update-notifier
        changed 2 packages in 3s
        > magicmirror@2.30.0 prepare
        > [ -f node_modules/.bin/husky ] && husky || echo no husky installed.
        no husky installed.
        added 479 packages in 47s
        126 packages are looking for funding
          run `npm fund` for details
        [sudo] password for mm:
        updating dependencies for active modules with package.json files
                processing for module MMM-Fuel please wait
        added 17 packages, and audited 18 packages in 5s
        8 packages are looking for funding
        found 0 vulnerabilities
                processing complete for module MMM-Fuel
                processing for module MMM-RNV please wait
        added 27 packages, and audited 28 packages in 12s
                processing complete for module MMM-RNV
                processing for module MMM-PublicTransportHafas please wait
        > mmm-publictransporthafas@3.0.1 prepare
        > [ -f node_modules/.bin/husky ] && husky || echo husky is not installed.
        added 63 packages, and audited 64 packages in 20s
        19 packages are looking for funding
                processing complete for module MMM-PublicTransportHafas
                processing for module MMM-ioBroker please wait
        added 6 packages, and audited 7 packages in 2s
        1 package is looking for funding
                processing complete for module MMM-ioBroker
                processing for module MMM-COVID19-AMPEL please wait
        added 12 packages, and audited 13 packages in 2s
                processing complete for module MMM-COVID19-AMPEL
                processing for module MMM-Carousel please wait
        up to date, audited 1 package in 993ms
                processing complete for module MMM-Carousel
                processing for module MMM-Remote-Control please wait
        npm warn deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
        added 54 packages, and audited 55 packages in 6s
        12 packages are looking for funding
                processing complete for module MMM-Remote-Control
        restoring custom.css
          sdetweil @kusselin
          @kusselin yes, you need a newer node version for this release as documented in the release notes and the published release page here
          if you had used my upgrade script it would have fixed this
          kusselinK 1 Reply Last reply Reply Quote 0
          • kusselinK Offline
            kusselin @sdetweil
            @sdetweil said in MM-Update doesn´t work:
            Hi thanks, is this this script
            bash -c “$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)”
            or this
            bash -c “$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/raspberry.sh)”
            look please:
            mm@MagicMirror-live:~/MagicMirror$ bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)" apply
            Installed Node version: v20.9.0
            installing correct version of node and npm, please wait
            saving custom.css
            local version 2.30.0 already same as master 2.30.0
            mm@MagicMirror-live:~/MagicMirror$ npm start server
            > magicmirror@2.30.0 start
            > npm run start:x11 server
            > magicmirror@2.30.0 start:x11
            > DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js server
            /home/mm/MagicMirror/node_modules/electron/dist/electron: error while loading shared libraries: libnss3.so: cannot open shared object file: No such file or directory
              sdetweil @kusselin
              @kusselin raspberry is install new
              upgrade is upgrade w
              apply
              as a parameter
              without parameter it does a check but makes no changes
              anyhow, looks like electron has a new dependency, 1st I’ve seen that
              that would take some apt command to install
                sdetweil @kusselin
                @kusselin also apply wont install over same version, you have to use
                force
                instead
                i wont let you mess up your system accidentally
                because we aborted before doing the
                npm install, that still isnt done
                • kusselinK Offline
                  kusselin @sdetweil
                  @sdetweil Hi Sam, I have not installed MM on the Raspi but in a Proxmox container Ubuntu 24…
                  Sorry, but I don’t understand anything anymore…
                  Can you please tell me step by step what I have to enter ?
                  Thank you very much
                  mm@MagicMirror-live:~/MagicMirror$ force
                  Command 'force' not found, did you mean:
                    command 'zforce' from deb gzip (1.12-1ubuntu1)
                    command 'forge' from deb snap (2013-11-29-11)
                  Try: sudo apt install <deb name>
                    sdetweil @kusselin
                    @kusselin proxmox is same as on pi. (i use vmware workststion)
                    run the upgrade script again
                    and replace the parm
                    apply
                    with
                    force
                    • kusselinK Offline
                      kusselin @sdetweil
                      saving custom.css
                      no husky installed.
                        sdetweil @kusselin
                        @kusselin now it should start. unless that library is still a problem
                        • kusselinK Offline
                          kusselin @sdetweil
                          @sdetweil you are once again my KING
                          it runs after entering npm run server
                          one question…what is a fetcher??
                          [2025-01-14 19:24:04.725] [LOG]   Create new newsfetcher for url: https://www.n-tv.de/rss - Interval:                            300000
                          [2025-01-14 19:24:04.734] [LOG]   Create new newsfetcher for url: http://www.tagesschau.de/xml/rss2 -
                          …and does this mean that the next time I update, I should always replace the script with apply by -force correctly?
                            sdetweil @kusselin
                            @kusselin fetcher is the code in newsfeed and calendar that gets the data
                            no just use apply, we only do this at most 4 times a year
                            force is only needed to recover from user error
                            • kusselinK Offline
                              kusselin @sdetweil
                              @sdetweil thank you sam…topp service
