    MMM-CalendarExt3Agenda on a higher screen resolution?
    12 Posts 3 Posters 3.8k Views 3 Watching
      rkorell Module Developer
      Dear team,
      I have upgraded my monitor and so I could use a higher resolution for the screen.
      Coming from 1.920x1.080 I’ve tried 2.560x1.440 which really looks great.
      Unfortunately MMM-CalendarExt3Agenda (which I use for calendar representation) disappears after every single restart of the mirror.
      This is true for the display itself as well as for a headless (remote) VNC session.
      Interesting enough the webbrowser SHOWS the module!
      After some time has passed calender appears suddenly (not sure which event this triggers).
      Currently I’m clueless.
      (It happens earlier that MMM-CalendarExt3Agenda disappeared after a Raspberry-Reboot but a restart of MagigMirror corrects this)
      Any idea/hint from the experts?
      Thanks a LOT!
      Regards,
      Ralf
        sdetweil @rkorell
        @rkorell i don’t think the screen change has anything to do with it
        the Ex3 family of modules gets their data from the default calender.
        if you look at the pm2 logs, you can see timestamps of when the data is sent…
        the Ext3 modules, try NOT to ‘flash’ on every change, and he doesn’t KNOW how many calendars there are, or how long they will take to process…
        so, he has a couple config parms that control it
        waitFetch:5000 (5 seconds)
        wait THAT long from first incoming block of messages, then display the calendar
        anything that comes it LATER, has to wait for the refreshInterval 1800000 milliseconds
        or 30 minutes… oops… a LONG time
        SO, the default calendar is taking a little longer in this release(2.30.0), so I bet that calendar missed the waitFetch time limit
        so I suggest looking at the pm2 logs messages and get the elapsed time from start to finish and set the waitFetch a little longer than that…
        NOW, this WILL cause the calendar NOT to display AT ALL for a little longer
        its a catch-22
        OR change the refreshInterval to faster…
        be careful, its takes work to do the refresh
        and refreshing when there are no changes (once a minute say) takes system resources away from other modules…
          MMRIZE @sdetweil
          Thanks for your explanation always.
          I’ll add small message in the screen on waiting - “Waiting calendar fetch…” or something informative in the next update…
            rkorell Module Developer @MMRIZE
            @MMRIZE @sdetweil ,
            thanks for this.
            I’ve played around with waitFetch which doesn’t help.
            But with your justification I have to investigate deeper and find the right value.
            Warmest regards,
            Ralf
              rkorell Module Developer @rkorell
              I have set refreshinterval at 180000 - 3 Minutes.
              this may triggers appearance of MMM-CalendarExt3Agenda …
              I’m not able to identify the startup of MMM-CalendarExt3Agenda in the log.
              If I consider the difference between Mirror-startup and first calender fetching as the “right” fetching time
              [2025-01-24 10:44:49.288] [LOG]   Starting MagicMirror: v2.30.0
              [2025-01-24 10:45:05.760] [INFO]  Calendar-Fetcher: Broadcasting 22 events from https://www.feiertage-deutschland.de/
              [2025-01-24 10:45:06.206] [INFO]  Calendar-Fetcher: Broadcasting 21 events from https://calendar.google.com/calendar
              it should be around 16,9 seconds - is this the right assumption?.
              At least with
              waitFetch:  17000,  //  start: 0:45:06.206 -  first calender fetch: 10:44:49.288 = 16.918 ms
              MMM-CalendarExt3Agenda appears “faster” than before …
                sdetweil @rkorell
                @rkorell you want more than last calendar for wait fetch
                  @sdetweil , sorry, I didn’t get you…
                  what do you mean by this?
                  Ralf
                    sdetweil @rkorell
                    @rkorell you want the time til after the LAST calendar broadcast not the first
                    10:45:06.206
                    He wants to wait til ALL the data is present
                    So waitFetch: 19*1000
                      O.K. , sorry my fault…Wrong expression from my side “first fetch” means first complete fetch (so ALL data fetched).
                      In addition I accidentally switched the begin and end…
                      So correct view is
                      waitFetch:  17000,  //  MM starts: 10:44:49.288   minus  complete calender fetch at: 10:45:06.206 = 16.918 ms
                      Sorry for my mistake.
                      And thanks for your explanation!
                      Warmest regards,
                      Ralf
                        sdetweil @rkorell
                        @rkorell and did that work?
                          @sdetweil , sorry - being offline for a while…
                          Yes, seems to work.
                          As you was afraid of, it takes LOOOONG until calender shows but earlier as without your suggested modification.
                          Thanks again!
                          Warmest regards,
                          Ralf
                          • R rkorell has marked this topic as solved on
                            sdetweil @rkorell
                            @rkorell awesome
