    MMM-CalendarExt3Agenda on a higher screen resolution?
    12 Posts 3 Posters 2.8k Views 3 Watching
      sdetweil @rkorell
      @rkorell i don’t think the screen change has anything to do with it
      the Ex3 family of modules gets their data from the default calender.
      if you look at the pm2 logs, you can see timestamps of when the data is sent…
      the Ext3 modules, try NOT to ‘flash’ on every change, and he doesn’t KNOW how many calendars there are, or how long they will take to process…
      so, he has a couple config parms that control it
      waitFetch:5000 (5 seconds)
      wait THAT long from first incoming block of messages, then display the calendar
      anything that comes it LATER, has to wait for the refreshInterval 1800000 milliseconds
      or 30 minutes… oops… a LONG time
      SO, the default calendar is taking a little longer in this release(2.30.0), so I bet that calendar missed the waitFetch time limit
      so I suggest looking at the pm2 logs messages and get the elapsed time from start to finish and set the waitFetch a little longer than that…
      NOW, this WILL cause the calendar NOT to display AT ALL for a little longer
      its a catch-22
      OR change the refreshInterval to faster…
      be careful, its takes work to do the refresh
      and refreshing when there are no changes (once a minute say) takes system resources away from other modules…
        MMRIZE @sdetweil
        Thanks for your explanation always.
        I’ll add small message in the screen on waiting - “Waiting calendar fetch…” or something informative in the next update…
          rkorell @MMRIZE
          @MMRIZE @sdetweil ,
          thanks for this.
          I’ve played around with waitFetch which doesn’t help.
          But with your justification I have to investigate deeper and find the right value.
          Warmest regards,
          Ralf
            rkorell @rkorell
            I have set refreshinterval at 180000 - 3 Minutes.
            this may triggers appearance of MMM-CalendarExt3Agenda …
            I’m not able to identify the startup of MMM-CalendarExt3Agenda in the log.
            If I consider the difference between Mirror-startup and first calender fetching as the “right” fetching time
            [2025-01-24 10:44:49.288] [LOG]   Starting MagicMirror: v2.30.0
            [2025-01-24 10:45:05.760] [INFO]  Calendar-Fetcher: Broadcasting 22 events from https://www.feiertage-deutschland.de/
            [2025-01-24 10:45:06.206] [INFO]  Calendar-Fetcher: Broadcasting 21 events from https://calendar.google.com/calendar
            it should be around 16,9 seconds - is this the right assumption?.
            At least with
            waitFetch:  17000,  //  start: 0:45:06.206 -  first calender fetch: 10:44:49.288 = 16.918 ms
            MMM-CalendarExt3Agenda appears “faster” than before …
              sdetweil @rkorell
              @rkorell you want more than last calendar for wait fetch
                rkorell @sdetweil
                @sdetweil , sorry, I didn’t get you…
                what do you mean by this?
                Ralf
                  sdetweil @rkorell
                  @rkorell you want the time til after the LAST calendar broadcast not the first
                  10:45:06.206
                  He wants to wait til ALL the data is present
                  So waitFetch: 19*1000
                    rkorell @sdetweil
                    O.K. , sorry my fault…Wrong expression from my side “first fetch” means first complete fetch (so ALL data fetched).
                    In addition I accidentally switched the begin and end…
                    So correct view is
                    waitFetch:  17000,  //  MM starts: 10:44:49.288   minus  complete calender fetch at: 10:45:06.206 = 16.918 ms
                    Sorry for my mistake.
                    And thanks for your explanation!
                    Warmest regards,
                    Ralf
                      sdetweil @rkorell
                      @rkorell and did that work?
                        rkorell @sdetweil
                        @sdetweil , sorry - being offline for a while…
                        Yes, seems to work.
                        As you was afraid of, it takes LOOOONG until calender shows but earlier as without your suggested modification.
                        Thanks again!
                        Warmest regards,
                        Ralf
                        • R rkorell has marked this topic as solved on
