    MMM-CalendarExt3Agenda on a higher screen resolution?
    12 Posts 3 Posters 3.9k Views 3 Watching
      MMRIZE @sdetweil
      Thanks for your explanation always.
      I’ll add small message in the screen on waiting - “Waiting calendar fetch…” or something informative in the next update…
      R 1 Reply Last reply
        rkorell Module Developer @MMRIZE
        @MMRIZE @sdetweil ,
        thanks for this.
        I’ve played around with waitFetch which doesn’t help.
        But with your justification I have to investigate deeper and find the right value.
        Warmest regards,
        Ralf
          rkorell Module Developer @rkorell
          I have set refreshinterval at 180000 - 3 Minutes.
          this may triggers appearance of MMM-CalendarExt3Agenda …
          I’m not able to identify the startup of MMM-CalendarExt3Agenda in the log.
          If I consider the difference between Mirror-startup and first calender fetching as the “right” fetching time
          [2025-01-24 10:44:49.288] [LOG]   Starting MagicMirror: v2.30.0
          [2025-01-24 10:45:05.760] [INFO]  Calendar-Fetcher: Broadcasting 22 events from https://www.feiertage-deutschland.de/
          [2025-01-24 10:45:06.206] [INFO]  Calendar-Fetcher: Broadcasting 21 events from https://calendar.google.com/calendar
          it should be around 16,9 seconds - is this the right assumption?.
          At least with
          waitFetch:  17000,  //  start: 0:45:06.206 -  first calender fetch: 10:44:49.288 = 16.918 ms
          MMM-CalendarExt3Agenda appears “faster” than before …
            sdetweil @rkorell
            @rkorell you want more than last calendar for wait fetch
              @sdetweil , sorry, I didn’t get you…
              what do you mean by this?
              Ralf
                sdetweil @rkorell
                @rkorell you want the time til after the LAST calendar broadcast not the first
                10:45:06.206
                He wants to wait til ALL the data is present
                So waitFetch: 19*1000
                  O.K. , sorry my fault…Wrong expression from my side “first fetch” means first complete fetch (so ALL data fetched).
                  In addition I accidentally switched the begin and end…
                  So correct view is
                  waitFetch:  17000,  //  MM starts: 10:44:49.288   minus  complete calender fetch at: 10:45:06.206 = 16.918 ms
                  Sorry for my mistake.
                  And thanks for your explanation!
                  Warmest regards,
                  Ralf
                    sdetweil @rkorell
                    @rkorell and did that work?
                      @sdetweil , sorry - being offline for a while…
                      Yes, seems to work.
                      As you was afraid of, it takes LOOOONG until calender shows but earlier as without your suggested modification.
                      Thanks again!
                      Warmest regards,
                      Ralf
                      • R rkorell has marked this topic as solved on
                        sdetweil @rkorell
                        @rkorell awesome
