    MMM-FroniusSolar family modules
    31 Posts 5 Posters 13.1k Views 5 Watching
    • A
      alfi153 @chrisfr1976
      @chrisfr1976
      I try to use Version 3.
      The ip is correct
      i have activated the API on my Fronius Gen24
      is it possible to get any Log file?
      • A
        • A
          @chrisfr1976
          i fixed it
          i had to install node-fetch
          Thank you
          C S 2 Replies Last reply
            chrisfr1976 @alfi153
            @alfi153 Hi,
            I think I’ve misunderstood this conversation a little bit.
            • you’re using MMM-FroniusSolar3 from me (ChrisF1976 on GitHub).
            • On your Fronius Symo GEN24 you activated the SolarApi.
            • In the config.js you used the correct IP
            I just started it on my mirror and it works without any problems. I also deleted it completely and reinstalled it with “git clone…”.
            So the only reason I can imagine is, that there is a collision in the node_helper.js. I used only “SET_CONFIG” to data exchange. Maybe other modules use this, too. I had a lot of collisions already :-)
            Go to the node_helper.js and replace:
                socketNotificationReceived: function (notification, payload) {
                    if (notification === "Solar3_SET_CONFIG") { //Solar3_ added to avoid collision with other modules
            Then go to the MMM-FroniusSolar3.js and replace:
                start: function () {
                    this.solarData = null;
                    this.solarSOC = null;
                    console.log("[MMM-FroniusSolar] Sending configuration to node_helper...");
                    this.sendSocketNotification("Solar3_SET_CONFIG", this.config); // Send configuration to node_helper with more specific name
                    this.scheduleUpdate();
            I this helps, please tell me. Then I’ll update it in general also for the other modules.
            If it doesn’t help, please look into the logs (for example with pm2 log mm) and also in logs of electron (I think ctrl+I was the command). I’m running a separate instance on server mode with the port 8081 and a separate config2 to find those errors. I hope you can find the error!
            Regards, Chris.
            A 1 Reply Last reply
              @alfi153 Okay, there was a delay in your message. Glad to her that everything is okay now. If you need any assistance please let me know:)
              Regards, Chris.
                sdetweil @alfi153
                @alfi153 @chrisfr1976 the current versions of nodejs since 18 have fetch built in. if the module does
                const fetch = require(‘node-fetch’)
                you can comment out that line and the fetch syntax is the same
                C 1 Reply Last reply
                  sdetweil @chrisfr1976
                  @chrisfr1976 everyone with reputation below 2 has every post reviewed (by me) before going live. sometimes i sleep! or do other things. lol
                  • A
                    @chrisfr1976
                    Hello Chris
                    FYI.
                    They remove node fetch from the magic mirror package on the last release as we drop back to the integrated fetch that’s provided in node and in the electron browser unfortunately that breaks a bunch of modules.
                    Just remove the the line const fetch = require(“fetch”); in the file node-helper.js in the module’s directory.
                    I Have removed the line, and now it works
                    • W
                      waynerob11
                      Tried to install 2 and 3 on an RPI 3B+ running 64
                      bookworm - will not even load and throws a .js error - IP address configured and did copy and paste for the config.js - mm just stalls
                        chrisfr1976 @sdetweil
                        I’ve updated the node _helper.js.
                        //const fetch = require("node-fetch");
                        If some has trouble it can be reactivated. Maybe I hab installed node_helper in the past manually. I don’t remember. Until now I had no errors from that. But yes, it woks well without this line.
                        Regards, Chris.
                        W 1 Reply Last reply
                          chrisfr1976 @waynerob11
                          @waynerob11
                          Please send the error massage that you receive. I want to help you!
                          Regards, Chris.
                          • W
                            waynerob11 @chrisfr1976
                            @chrisfr1976
                            Thanks for your response - I am attempting to install Fronius Solar 2 and have commented out the line in node-helper.js as advised in a previous post ( //const fetch = require(“node-fetch”);) and ran MM.
                            It all loaded OK with no errors but it doesn’t show up on the dashboard, doesn’t even say loading. IP address is correct.
                            Wayne
                            C W 3 Replies Last reply
                              @waynerob11 Hello,
                              I’ve created a version with console.logs inside. Go to the MMM-FroniusSolar2 module folder and replace the files with this content:
                              MMM-FroniusSolar2.js:
                              Module.register("MMM-FroniusSolar2", {
                                  defaults: {
                                      InverterIP: "192.168.178.134",
                                      updateInterval: 60000, // Update every 60 seconds
                                      icons: {
                                          P_Akku: "mdi:car-battery",
                                          P_Grid: "mdi:transmission-tower",
                                          P_Load: "mdi:home-lightbulb",
                                          P_PV: "mdi:solar-panel-large",
                                      Radius: 80, // Radius for the SVG gauges
                                      MaxPower: 1000, // Maximum power for grid, house, and battery
                                      MaxPowerPV: 10400, // Maximum power for solar PV
                                      ShowText: true,
                                      TextMessge: [
                                          { about: "600", Text: "Leicht erhöhter Netzbezug.", color: "#999" },
                                          { about: "1000", Text: "Über 1 KW Netzbezug!", color: "#ffffff" },
                                          { about: "1500", Text: "Über 1,5KW Netzbezug.", color: "#eea205" },
                                          { about: "2500", Text: "Über 2,5KW aus dem Netz!", color: "#ec7c25" },
                                          { about: "5000", Text: "Auto lädt, richtig? Nächstes Mal auf Sonne warten.", color: "#cc0605" },
                                          { less: "-500", Text: "Sonne scheint! Mehr als 500W frei.", color: "#f8f32b" },
                                          { less: "-2000", Text: "Wäsche waschen! Über 2KW freie Energie!", color: "#00bb2d" },
                                          { less: "-4000", Text: "Auto laden! Über 4KW freie Energie!", color: "#f80000" },
                                      debug: true, // Set to true to enable debug logging
                                      if (this.config.debug) {
                                          console.log("[MMM-FroniusSolar2] Starting module with config:", this.config);
                                      this.solarSOC = null; // Added for SOC
                                      console.log("[MMM-FroniusSolar2] Sending configuration to node_helper...");
                                      this.sendSocketNotification("SET_CONFIG", this.config); // Send configuration to node_helper
                                      this.scheduleUpdate(); // Schedule periodic updates
                                  getStyles: function () {
                                      return ["MMM-FroniusSolar2.css", "https://code.iconify.design/2/2.2.1/iconify.min.js"];
                                  scheduleUpdate: function () {
                                          console.log("[MMM-FroniusSolar2] Scheduling updates every", this.config.updateInterval, "ms");
                                      const self = this;
                                      setInterval(function () {
                                          if (self.config.debug) {
                                              console.log("[MMM-FroniusSolar2] Requesting data update from node_helper...");
                                          self.sendSocketNotification("GET_FRONIUS_DATA");
                                      }, this.config.updateInterval);
                                      if (notification === "FRONIUS_DATA") {
                                              console.log("[MMM-FroniusSolar2] Received FRONIUS_DATA:", payload);
                                          this.solarData = {
                                              P_Akku: Math.round(payload.P_Akku || 0),
                                              P_Grid: Math.round(payload.P_Grid || 0),
                                              P_Load: Math.round(payload.P_Load || 0),
                                              P_PV: Math.round(payload.P_PV || 0),
                                          this.solarSOC =
                                              payload.Inverters &&
                                              payload.Inverters["1"] &&
                                              payload.Inverters["1"].SOC
                                                  ? Math.round(payload.Inverters["1"].SOC)
                                                  : 0; // Fallback to 0 if SOC is undefined
                                              console.log("[MMM-FroniusSolar2] Processed solarData:", this.solarData, "SOC:", this.solarSOC);
                                          this.updateDom();
                                  getDom: function () {
                                          console.log("[MMM-FroniusSolar2] Rendering DOM");
                                      const wrapper = document.createElement("div");
                                      wrapper.className = "solar2-wrapper";
                                      if (!this.solarData) {
                                          wrapper.innerHTML = "Loading...";
                                          return wrapper;
                                      const radius = this.config.Radius || 80;
                                      const strokeWidth = 12;
                                      const svgSize = 350; // Adjusted SVG height for labels and padding
                                      // Recalculate house consumption
                                      const outerPower = this.solarData.P_Grid + this.solarData.P_Akku + this.solarData.P_PV;
                                      // Fixed positions for the gauges in dice layout
                                      const positions = {
                                          PV: { x: 75, y: 75 },
                                          Grid: { x: 225, y: 75 },
                                          Akku: { x: 75, y: 225 },
                                          House: { x: 225, y: 225 }
                                      // Define colors for gauges
                                      const gridColor = this.solarData.P_Grid >= 0 ? "#808080" : "#add8e6"; // Gray for positive, light blue for negative
                                      const akkuColor = "#00ff00"; // Always green
                                      const pvColor = "#ffff00"; // Always yellow
                                      // House Gauge: Logic for color determination
                                      let houseColor;
                                      if (this.solarData.P_Akku - 100 > Math.abs(this.solarData.P_Grid)) {
                                          houseColor = "#a3c49f"; // Light green for high battery activity
                                      } else if (this.solarData.P_Grid > 150) {
                                          houseColor = "#808080"; // Gray for high grid consumption
                                      } else if (outerPower > 0) {
                                          houseColor = "#00ff00"; // Green for positive power flow
                                      } else {
                                          houseColor = "#1f84ff"; // Light blue
                                          console.log("[MMM-FroniusSolar2] Gauge colors determined:",
                                              { pvColor, gridColor, akkuColor, houseColor });
                                      // Create unified SVG
                                      const svg = document.createElementNS("http://www.w3.org/2000/svg", "svg");
                                      svg.setAttribute("width", svgSize);
                                      svg.setAttribute("height", svgSize);
                                      svg.setAttribute("viewBox", "0 -20 300 350"); // Adjusted viewBox to fix label cutoff
                                      svg.style.margin = "auto"; // Center the SVG
                                      // Define glow effect
                                      const defs = document.createElementNS("http://www.w3.org/2000/svg", "defs");
                                      defs.innerHTML = `
                                          <filter id="glow">
                                              <feGaussianBlur in="SourceGraphic" stdDeviation="4" result="blurred" />
                                              <feMerge>
                                                  <feMergeNode in="blurred" />
                                                  <feMergeNode in="SourceGraphic" />
                                              </feMerge>
                                          </filter>
                                      svg.appendChild(defs);
                                      // Function to create a line
                                      const createLine = (x1, y1, x2, y2, color) => {
                                              console.log("[MMM-FroniusSolar2] Creating line:", { x1, y1, x2, y2, color });
                                          const line = document.createElementNS("http://www.w3.org/2000/svg", "line");
                                          line.setAttribute("x1", x1);
                                          line.setAttribute("y1", y1);
                                          line.setAttribute("x2", x2);
                                          line.setAttribute("y2", y2);
                                          line.setAttribute("stroke", color);
                                          line.setAttribute("stroke-width", "4");
                                          line.setAttribute("class", "flow-lines");
                                          return line;
                                      // Add flow lines based on power conditions
                                      if (this.solarData.P_Akku < -10 && this.solarData.P_PV > 0 ) {
                                          svg.appendChild(createLine(positions.PV.x, positions.PV.y + radius, positions.Akku.x, positions.Akku.y - radius, "#ffff00"));
                                      if (this.solarData.P_PV > 10) {
                                          svg.appendChild(createLine(positions.PV.x + (radius * 0.7071), positions.PV.y + (radius * 0.7071), positions.House.x - (radius * 0.7071), positions.House.y - (radius * 0.7071), "#ffff00"));
                                      if (this.solarData.P_Grid > 10) {
                                          svg.appendChild(createLine(positions.Grid.x, positions.Grid.y + radius, positions.House.x, positions.House.y - radius, "#808080"));
                                      if (this.solarData.P_Akku > 10) {
                                          svg.appendChild(createLine(positions.Akku.x + radius, positions.Akku.y, positions.House.x - radius, positions.House.y, "#00ff00"));
                                      if (this.solarData.P_Grid < -10 && this.solarData.P_PV > Math.abs(this.solarData.P_Grid)) {
                                          svg.appendChild(createLine(positions.PV.x + radius, positions.PV.y, positions.Grid.x - radius, positions.Grid.y, "#add8e6"));
                                      if (this.solarData.P_Grid < -10 && this.solarData.P_PV <= 0) {
                                          svg.appendChild(createLine(positions.Akku.x + (radius * 0.7071), positions.Akku.y - (radius * 0.7071), positions.Grid.x - (radius * 0.7071), positions.Grid.y + (radius * 0.7071), "#00ff00"));
                                      if (this.solarData.P_PV <= 0 && this.solarData.P_Akku < -10) {
                                          svg.appendChild(createLine(positions.Grid.x - (radius * 0.7071), positions.Grid.y + (radius * 0.7071), positions.Akku.x + (radius * 0.7071), positions.Akku.y - (radius * 0.7071), "#808080"));
                                      // Function to create a gauge
                                      const createGauge = (x, y, mainValue, subValue, percentage, color, label, icon, labelPosition) => {
                                              console.log("[MMM-FroniusSolar2] Creating gauge:", { label, mainValue, subValue, percentage, color });
                                          const group = document.createElementNS("http://www.w3.org/2000/svg", "g");
                                          group.setAttribute("transform", `translate(${x},${y})`);
                                          // Circle Background
                                          const bgCircle = document.createElementNS("http://www.w3.org/2000/svg", "circle");
                                          bgCircle.setAttribute("cx", 0);
                                          bgCircle.setAttribute("cy", 0);
                                          bgCircle.setAttribute("r", radius);
                                          bgCircle.setAttribute("stroke", "#e0e0e0");
                                          bgCircle.setAttribute("opacity", "1");
                                          bgCircle.setAttribute("stroke-width", strokeWidth);
                                          bgCircle.setAttribute("fill", "none");
                                          group.appendChild(bgCircle);
                                          // Circle Progress with glow
                                          const progressCircle = document.createElementNS("http://www.w3.org/2000/svg", "circle");
                                          progressCircle.setAttribute("cx", 0);
                                          progressCircle.setAttribute("cy", 0);
                                          progressCircle.setAttribute("r", radius);
                                          progressCircle.setAttribute("stroke", color);
                                          progressCircle.setAttribute("stroke-width", strokeWidth);
                                          progressCircle.setAttribute("fill", "none");
                                          progressCircle.setAttribute("stroke-dasharray", `${percentage * 2 * Math.PI * radius} ${2 * Math.PI * radius}`);
                                          progressCircle.setAttribute("transform", "rotate(-90 0 0)");
                                          progressCircle.setAttribute("filter", "url(#glow)"); // Apply glow filter
                                          group.appendChild(progressCircle);
                                          // Main Text
                                          const mainText = document.createElementNS("http://www.w3.org/2000/svg", "text");
                                          mainText.setAttribute("x", 0);
                                          mainText.setAttribute("y", 6); // Adjusted y position for main text
                                          mainText.setAttribute("text-anchor", "middle");
                                          mainText.setAttribute("font-size", "22px");
                                          mainText.setAttribute("fill", "#ffffff");
                                          mainText.textContent = mainValue;
                                          group.appendChild(mainText);
                                          // Sub Text
                                          if (subValue) {
                                              const subText = document.createElementNS("http://www.w3.org/2000/svg", "text");
                                              subText.setAttribute("x", 0);
                                              subText.setAttribute("y", 25); // Adjusted y position for sub text
                                              subText.setAttribute("text-anchor", "middle");
                                              subText.setAttribute("font-size", "16px");
                                              subText.setAttribute("fill", "#ffffff");
                                              subText.textContent = subValue;
                                              group.appendChild(subText);
                                          // Label with foreignObject for icon
                                          const labelY = labelPosition === "top" ? -(radius + 45) : radius + 15; // Increased offset for top labels
                                          const labelContainer = document.createElementNS("http://www.w3.org/2000/svg", "foreignObject");
                                          labelContainer.setAttribute("x", -radius - 20);
                                          labelContainer.setAttribute("y", labelY);
                                          labelContainer.setAttribute("text-anchor", "middle");
                                          labelContainer.setAttribute("width", radius * 2);
                                          labelContainer.setAttribute("height", labelPosition === "top" ? 60 : 40); // Adjusted label height
                                          labelContainer.innerHTML = `
                                              <div xmlns="http://www.w3.org/1999/xhtml" style="display: flex; align-items: center; justify-content: center; text-align: center; font-size: 20px; color: white;">
                                                  <span class="iconify" data-icon="${icon}" style="margin-right: 5px;"></span>
                                                  ${label}
                                              </div>
                                          group.appendChild(labelContainer);
                                          return group;
                                      // Add gauges to SVG
                                      svg.appendChild(createGauge(
                                          positions.PV.x,
                                          positions.PV.y,
                                          `${this.solarData.P_PV || 0} W`,
                                          null,
                                          Math.min((this.solarData.P_PV || 0) / this.config.MaxPowerPV, 1),
                                          pvColor,
                                          "PV",
                                          this.config.icons.P_PV,
                                          "top"
                                          positions.Grid.x,
                                          positions.Grid.y,
                                          `${this.solarData.P_Grid || 0} W`,
                                          null,
                                          Math.min(Math.abs(this.solarData.P_Grid || 0) / this.config.MaxPower, 1),
                                          gridColor,
                                          "Grid",
                                          this.config.icons.P_Grid,
                                          "top"
                                          positions.Akku.x,
                                          positions.Akku.y,
                                          `${this.solarSOC || 0}%`,
                                          `${this.solarData.P_Akku || 0} W`,
                                          Math.min(this.solarSOC / 100, 1),
                                          akkuColor,
                                          "Akku",
                                          this.config.icons.P_Akku,
                                          "bottom"
                                          positions.House.x,
                                          positions.House.y,
                                          `${outerPower || 0} W`,
                                          null,
                                          Math.min(Math.abs(outerPower || 0) / this.config.MaxPower, 1),
                                          houseColor,
                                          "House",
                                          this.config.icons.P_Load,
                                          "bottom"
                                      wrapper.appendChild(svg);
                                      // Add dynamic text message below the gauge
                                      if (this.config.ShowText) {
                                          const textMessageDiv = document.createElement("div");
                                          textMessageDiv.className = "text-message2";
                                          const messageConfig = this.config.TextMessge || [];
                                          let selectedMessage = null;
                                          for (const message of messageConfig) {
                                              if (
                                                  (message.about && this.solarData.P_Grid > parseInt(message.about)) ||
                                                  (message.less && this.solarData.P_Grid < parseInt(message.less))
                                                  // If no message is selected yet, or the new match is more specific
                                                  if (
                                                      !selectedMessage ||
                                                      (message.about && parseInt(message.about) > parseInt(selectedMessage.about || -Infinity)) ||
                                                      (message.less && parseInt(message.less) < parseInt(selectedMessage.less || Infinity))
                                                      selectedMessage = message;
                                          if (selectedMessage) {
                                                  console.log("[MMM-FroniusSolar2] Selected text message:", selectedMessage);
                                              textMessageDiv.innerHTML = `
                                                  <span style="color: ${selectedMessage.color}; font-size: 18px;">
                                                      ${selectedMessage.Text}
                                                  </span>
                                          } else {
                                                  <span style="color: #999; font-size: 16px;">
                                                      PV Anlage läuft...
                                                  </span>
                                          wrapper.appendChild(textMessageDiv);
                                      return wrapper;
                              node_helper.js::
                              const NodeHelper = require("node_helper");
                                  config: null, // Initially, no config is set
                                      console.log("[MMM-FroniusSolar2] Node helper started");
                                      console.log("[MMM-FroniusSolar2] Received socket notification:", notification, payload);
                                      if (notification === "SET_CONFIG") {
                                          this.config = payload;
                                              console.log("[MMM-FroniusSolar2] Configuration received:", this.config);
                                          this.startFetchingData();
                                      } else if (notification === "GET_FRONIUS_DATA") {
                                          if (!this.config) return;
                                              console.log("[MMM-FroniusSolar2] GET_FRONIUS_DATA triggered");
                                          this.getFroniusData();
                                  startFetchingData: function () {
                                      if (this.config && this.config.InverterIP) {
                                              console.log("[MMM-FroniusSolar2] Starting data fetch interval for IP", this.config.InverterIP);
                                          this.fetchInterval = setInterval(() => {
                                          }, 60000); // Fetch data every 60 seconds
                                  getFroniusData: function () {
                                      if (!this.config || !this.config.InverterIP) return;
                                      const url = `http://${this.config.InverterIP}/solar_api/v1/GetPowerFlowRealtimeData.fcgi`;
                                          console.log("[MMM-FroniusSolar2] Fetching data from URL:", url);
                                      fetch(url)
                                          .then(response => {
                                                  console.log("[MMM-FroniusSolar2] Response received:", response);
                                              if (!response.ok) {
                                                  throw new Error(`HTTP error!`);
                                              return response.json();
                                          .then(data => {
                                                  console.log("[MMM-FroniusSolar2] JSON data received:", data);
                                              const siteData = data.Body.Data.Site;
                                              const inverterData = data.Body.Data.Inverters ? data.Body.Data.Inverters["1"] : {};
                                              const result = {
                                                  P_Akku: siteData.P_Akku || 0,
                                                  P_Grid: siteData.P_Grid || 0,
                                                  P_Load: siteData.P_Load || 0,
                                                  P_PV: siteData.P_PV || 0,
                                                  Inverters: { "1": { SOC: inverterData.SOC || 0 } },
                                                  console.log("[MMM-FroniusSolar2] Parsed result:", result);
                                              this.sendSocketNotification("FRONIUS_DATA", result);
                                          .catch(error => {
                                              console.error("[MMM-FroniusSolar2] Error fetching data:", error);
                              This will create a lot of log entry. So only use this temporary. If you see any errors you can’t solve, please send me the logs.
                              Later use pm2 flush to clear the logs. The log-file size will increase with this version quite fast.
                              Regards, Chris.
                                @waynerob11
                                is this issue solved now?
                                Regards, Chris.
                                • T
                                  TomOMaley
                                  Hi, does meanwhil one of your fronius modules work whithout Problems? Tried the second one but no display at all. What changes in the config etc. are still necessary?
                                  Regards Walter
                                    chrisfr1976 @TomOMaley
                                    @TomOMaley
                                    All modules work without any problems on my mirror. No errors, nothing in the logs and it gets data every 2 seconds.
                                    To go to the chat and post a mimimi only is not that helpful to find the error. Use the log-version above then you‘ll find your error.
                                    Read the doc, install the latest module, enter a correct ip and activate the api in your inverter. I cannot see any more I can do here. At least post an error log or somerhing helpful.
                                    Regards, Chris.
                                    T 1 Reply Last reply
                                    • T
                                      TomOMaley @chrisfr1976
                                      @chrisfr1976 Dear Chris, I apologize for my unqualified question. Regards
                                      • W
                                        waynerob11 @waynerob11
                                        Hi Chris,
                                        Don’t know what I did but it’s all working now - only problem is all the circles are bunched up.
                                        Also, how can I enlarge and bold the fonts
                                        @waynerob11
                                        C W 2 Replies Last reply
                                          @waynerob11
                                          please send a screenshot to understand clearly what you like to do.
                                          Regards, Chris.
                                          • W
