    MMM-CalendarExt3 only one calendar not updating
    35 Posts 4 Posters 22.0k Views 4 Watching
    • emloweE
      emlowe Module Developer @sdetweil
      Was out for a week - some more details:
      Here are relevant log entries:
      0|MagicMirror | [2025-01-27 10:54:33.580] [LOG] Launching application.
      0|MagicMirror | [2025-01-27 10:54:50.855] [LOG] Create new calendarfetcher for url: - Interval: 300000
      0|MagicMirror | [2025-01-27 10:55:44.585] [INFO] Calendar-Fetcher: Broadcasting 23 events from
      0|MagicMirror | [2025-01-27 11:01:33.443] [INFO] Calendar-Fetcher: Broadcasting 23 events from
      So that was about a minute to broadcast the first time, and then it follows the refresh interval reasonably closes.
      I have the Ext3 module waitFetch set to 5 minutes (5 * 60 *1000) - well after the first broadcast. When the Ext3 module draws after 5 minutes, there is nothing in it, and it is empty with no events whatsoever. It’s like it has no data at all.
      I have the Ext3 module refreshInterval set to 7 minutes (7 * 60 * 1000) - after the 7 minutes the module will refresh and it remains empty despite the calendar having done two broadcasts. The Ext3 module will remain empty for hours.
      However, if I manually refresh the browser using the remotecontrol module - the Ext3 module takes 5 minutes to appear (based on waitFetch but will have all the data)
        sdetweil @emlowe
        @emlowe waitfetch is from CalendarExt3 start to latest broadcast
        i cannot see start but latest is at 11:01:33
        find start time and subtract. add a couple seconds for variability
        his default waitfetch is 5 SECONDS
        Then after that, next screen refresh is at updateInterval time
        also 23 events seems small, if this is mm v2.23.0, you did put on the clipping fixes right?
        is this the SAME calendar broadcasting?
        then to its first broadcast from ext3 start
        emloweE 1 Reply Last reply
        • emloweE
          I am on the develop branch
          The entire start is at 10:54:23
          [2025-01-27 10:54:23.207] [LOG] Starting MagicMirror: v2.31.0-develop
          I’m not sure when Ext3Agenda starts as there is no log item specific to that afaik - but I assume it’s sometime around:
          [2025-01-27 10:54:26.290] [LOG] No helper found for module: MMM-CalendarExt3Agenda.
          so Ext3 start is no earlier than 10:54:23 and the first broadcast was at 10:55:44 - this is much less than the 5 minutes I have manually configured for waitFetch.
          (in other words, I am waiting much longer than should be needed, but it does not work unless I manually refresh)
          The log at 11:01 is the second broadcast of the same calendar
          I am only pulling 5 days of data and not broadcasting past events, 23 is correct.
          hiddenOnStartup: true,
              broadcastEvents: true,
              broadcastPastEvents: false,
              maximumNumberOfDays: 5,
              maximumEntries: 100,
              fetchInterval: 5 * 60 * 1000,
                  URL: "<redacted>"
          module: "MMM-CalendarExt3Agenda",
              showMiniMonthCalendar: false,
              firstDayOfWeek: 1,
              startDayIndex: 0,
              endDayIndex: 0,
              calendarSet: ['family'],
              waitFetch: 5 * 60 * 1000,
              refreshInterval: 7 * 60 * 1000,
            sdetweil @emlowe
            @emlowe ok, in the case of modules that only have a browser component ( no node helper) then
            starting application message is the start time
            another use just resolved the same issue w waitfetch, but he had multiple calendars
            https://forum.magicmirror.builders/topic/19359/mmm-calendarext3agenda-on-a-higher-screen-resolution?page=2
            • emloweE
              Further strangeness.
              Let’s say I change waitFetch to something that shouldn’t work (eg 5 seconds) - clearly, this doesn’t work since the first broadcast is after a minute or so.
              But if I manually refresh the browser as soon as I see the log entry about the broadcast - everything appears just fine.
              So for example, setting
              waitFetch: 5 * 1000,
              refreshInterval: 2 * 60 * 1000,
              Nothing will appear in the calendar - not at start (expected) and not after 2 mins (1 refresh), or 4 mins, or 10 mins or however long I want to wait - nothing.
              But if I manually refresh - everything appears right away as long as I refresh after the broadcast log line
                sdetweil @emlowe
                @MMRIZE will have to advise. this is the depth of my knowledge
                i work on the default calendar
                well, one thing
                when you refresh the page, all the modules web components are reloaded. the default cal sends a request to its node helper to get events. and it has them already, so sends immediately
                and of course because the default cal will be shown, its shows with the correct events, right??
                • emloweE
                  Yea, I believe the default calender is working and broadcasting correctly - not sure exactly where Ext3Agenda is having problems - but I have a few ideas I plan to try out.
                  • emloweE
                    emlowe Module Developer @emlowe
                    Bah! I have to apologize - I was on the develop branch but apparently, I was some commits behind and I think I was missing the commit that fixed the “clipping” problem
                    I made sure to update to the head of develop and things are working much better now. So it seems all along it has been the known issue
                    Doh!
                    • emloweE
                      Actually have to take this back. Currently testing running in server only mode and a browser so I can see the console easier
                      When I see in the log this line:
                      [2025-01-27 13:52:24.893] [INFO] Calendar-Fetcher: Broadcasting 22 events from <redacted>
                      I can say that modules are NOT getting any calendar notifications, despite this log entry. They are not broadcast. I added some code to Ext3Agenda to print out when it gets any notification, and it never gets any CAL items. (I see it getting DOM_CREATED, DOM_UPDATED, etc,etc)
                      I see in the console log the following:
                      sorting events count=0
                      slicing events total maxcount=100
                      which seems odd given that the helper reported broadcasting 22 events. Those items repeat in the console log , but it’s always sorting events count=0
                      UNTIL I refresh the browser - Now I see the Ext3Agenda module getting CALENDER_EVENTS and sorting events count=22
                      • emloweE
                        I guess I should have run some tests with just the standard calendar module.
                        Now just using the standard calendar module - and it just says “Loading” despite having also printed “Broadcasting 22 events from”
                          sdetweil @emlowe
                          @emlowe as you updated to the develop branch, did you also redo the npm run install-mm
                          • emloweE
                            I did yes - so the current test results are this
                            The calendar did eventually appear - but it took quite some time - I wasn’t watching, so I don’t know when exactly - I’ll test again. But it was several minutes after the log output of “broadcasting 22 events”
                              sdetweil @emlowe
                              @emlowe the default for ext3 is 30 mins
                              if missed at waitFetch
                              only see the timing in
                              pm2 log
                              default calendar working, right?
                              • emloweE
                                @sdetweil No, I’m stopped testing Ext3 and I am only testing the default calendar.
                                it is not working - I see Loading... for some number of minutes or hours, I haven’t determined any consistency. This test run is now past 45 mins and it still says Loading… despite having broadcast the events 9 times:
                                [2025-01-27 14:25:24.525] [LOG]   Starting MagicMirror: v2.31.0-develop
                                [2025-01-27 14:25:31.806] [LOG]   Create new calendarfetcher for URL ...
                                [2025-01-27 14:26:21.083] [INFO]  Calendar-Fetcher: Broadcasting 22 events from ...
                                [2025-01-27 14:32:08.812] [INFO]  Calendar-Fetcher: Broadcasting 22 events from ...
                                [2025-01-27 14:37:55.863] [INFO]  Calendar-Fetcher: Broadcasting 22 events from
                                [2025-01-27 14:43:42.948] [INFO]  Calendar-Fetcher: Broadcasting 22 events from
                                [2025-01-27 14:49:30.144] [INFO]  Calendar-Fetcher: Broadcasting 22 events from
                                [2025-01-27 15:12:37.552] [INFO]  Calendar-Fetcher: Broadcasting 21 events from
                                still says Loading ... - if I refresh the browser page - then they all appear immediately
                                  sdetweil @emlowe
                                  @emlowe can you extract those events out to a file
                                  curl -sL theurl >somefile.txt
                                  and share the file and your calendar config in an email to me
                                  same userid at gmail
                                  so i can look at it
                                  one other thing is open the developers window console tab
                                  ctrl-shift-i, select the console tab
                                  or do
                                  npm run start:dev
                                  and see if there are any errors
                                  the browser side broadcasts so it GOT the events block
                                  then it processes for the ui
                                  • emloweE
                                    @sdetweil No errors in the console log
                                    If I wait long enough where this seems anywhere between 15min to an hour or more, they do appear without a manual refresh.
                                    maybe it’s a complexity issue - when I curl the calender link (it’s a google private ICS link) - the resulting file is 4.8MB - I imagine parsing that is somewhat time-consuming
                                      sdetweil @emlowe
                                      @emlowe yes, and new code takes longer than old with lots of events
                                      what is the calendar refreshinterval
                                      • emloweE
                                        @sdetweil You mean fetchInterval: 5 * 60 * 1000?
                                        the calendar module doesn’t have refreshinterval does it?
                                          sdetweil @emlowe
                                          @emlowe fetchInterval is same
                                          • emloweE
                                            I added various log outputs to node_helper.js and calendar.js
                                            node_helper is sending the socket notification for CALENDAR_EVENTS
                                            this is not received by the front end code in calendar.js
                                            I don’t know what happens to it, but I added logging to print out in calendar.js whenever the socketNotificationReceived handler is called and it doesn’t print.
                                            (unless I refresh the page - at which point it does)
                                            emloweE S 3 Replies Last reply
