    MMM-CalendarExt3 only one calendar not updating
    35 Posts 4 Posters 22.0k Views 4 Watching
    • emloweE
      emlowe Module Developer @sdetweil
      I am on the develop branch
      The entire start is at 10:54:23
      [2025-01-27 10:54:23.207] [LOG] Starting MagicMirror: v2.31.0-develop
      I’m not sure when Ext3Agenda starts as there is no log item specific to that afaik - but I assume it’s sometime around:
      [2025-01-27 10:54:26.290] [LOG] No helper found for module: MMM-CalendarExt3Agenda.
      so Ext3 start is no earlier than 10:54:23 and the first broadcast was at 10:55:44 - this is much less than the 5 minutes I have manually configured for waitFetch.
      (in other words, I am waiting much longer than should be needed, but it does not work unless I manually refresh)
      The log at 11:01 is the second broadcast of the same calendar
      I am only pulling 5 days of data and not broadcasting past events, 23 is correct.
      hiddenOnStartup: true,
          broadcastEvents: true,
          broadcastPastEvents: false,
          maximumNumberOfDays: 5,
          maximumEntries: 100,
          fetchInterval: 5 * 60 * 1000,
              URL: "<redacted>"
      module: "MMM-CalendarExt3Agenda",
          showMiniMonthCalendar: false,
          firstDayOfWeek: 1,
          startDayIndex: 0,
          endDayIndex: 0,
          calendarSet: ['family'],
          waitFetch: 5 * 60 * 1000,
          refreshInterval: 7 * 60 * 1000,
        sdetweil @emlowe
        @emlowe ok, in the case of modules that only have a browser component ( no node helper) then
        starting application message is the start time
        another use just resolved the same issue w waitfetch, but he had multiple calendars
        https://forum.magicmirror.builders/topic/19359/mmm-calendarext3agenda-on-a-higher-screen-resolution?page=2
        emloweE 1 Reply Last reply
        • emloweE
          Further strangeness.
          Let’s say I change waitFetch to something that shouldn’t work (eg 5 seconds) - clearly, this doesn’t work since the first broadcast is after a minute or so.
          But if I manually refresh the browser as soon as I see the log entry about the broadcast - everything appears just fine.
          So for example, setting
          waitFetch: 5 * 1000,
          refreshInterval: 2 * 60 * 1000,
          Nothing will appear in the calendar - not at start (expected) and not after 2 mins (1 refresh), or 4 mins, or 10 mins or however long I want to wait - nothing.
          But if I manually refresh - everything appears right away as long as I refresh after the broadcast log line
            sdetweil @emlowe
            @MMRIZE will have to advise. this is the depth of my knowledge
            i work on the default calendar
            well, one thing
            when you refresh the page, all the modules web components are reloaded. the default cal sends a request to its node helper to get events. and it has them already, so sends immediately
            and of course because the default cal will be shown, its shows with the correct events, right??
            • emloweE
              Yea, I believe the default calender is working and broadcasting correctly - not sure exactly where Ext3Agenda is having problems - but I have a few ideas I plan to try out.
              • emloweE
                emlowe Module Developer @emlowe
                Bah! I have to apologize - I was on the develop branch but apparently, I was some commits behind and I think I was missing the commit that fixed the “clipping” problem
                I made sure to update to the head of develop and things are working much better now. So it seems all along it has been the known issue
                Doh!
                • emloweE
                  Actually have to take this back. Currently testing running in server only mode and a browser so I can see the console easier
                  When I see in the log this line:
                  [2025-01-27 13:52:24.893] [INFO] Calendar-Fetcher: Broadcasting 22 events from <redacted>
                  I can say that modules are NOT getting any calendar notifications, despite this log entry. They are not broadcast. I added some code to Ext3Agenda to print out when it gets any notification, and it never gets any CAL items. (I see it getting DOM_CREATED, DOM_UPDATED, etc,etc)
                  I see in the console log the following:
                  sorting events count=0
                  slicing events total maxcount=100
                  which seems odd given that the helper reported broadcasting 22 events. Those items repeat in the console log , but it’s always sorting events count=0
                  UNTIL I refresh the browser - Now I see the Ext3Agenda module getting CALENDER_EVENTS and sorting events count=22
                  • emloweE
                    I guess I should have run some tests with just the standard calendar module.
                    Now just using the standard calendar module - and it just says “Loading” despite having also printed “Broadcasting 22 events from”
                      sdetweil @emlowe
                      @emlowe as you updated to the develop branch, did you also redo the npm run install-mm
                      • emloweE
                        I did yes - so the current test results are this
                        The calendar did eventually appear - but it took quite some time - I wasn’t watching, so I don’t know when exactly - I’ll test again. But it was several minutes after the log output of “broadcasting 22 events”
                          sdetweil @emlowe
                          @emlowe the default for ext3 is 30 mins
                          if missed at waitFetch
                          only see the timing in
                          pm2 log
                          default calendar working, right?
                          • emloweE
                            @sdetweil No, I’m stopped testing Ext3 and I am only testing the default calendar.
                            it is not working - I see Loading... for some number of minutes or hours, I haven’t determined any consistency. This test run is now past 45 mins and it still says Loading… despite having broadcast the events 9 times:
                            [2025-01-27 14:25:24.525] [LOG]   Starting MagicMirror: v2.31.0-develop
                            [2025-01-27 14:25:31.806] [LOG]   Create new calendarfetcher for URL ...
                            [2025-01-27 14:26:21.083] [INFO]  Calendar-Fetcher: Broadcasting 22 events from ...
                            [2025-01-27 14:32:08.812] [INFO]  Calendar-Fetcher: Broadcasting 22 events from ...
                            [2025-01-27 14:37:55.863] [INFO]  Calendar-Fetcher: Broadcasting 22 events from
                            [2025-01-27 14:43:42.948] [INFO]  Calendar-Fetcher: Broadcasting 22 events from
                            [2025-01-27 14:49:30.144] [INFO]  Calendar-Fetcher: Broadcasting 22 events from
                            [2025-01-27 15:12:37.552] [INFO]  Calendar-Fetcher: Broadcasting 21 events from
                            still says Loading ... - if I refresh the browser page - then they all appear immediately
                              sdetweil @emlowe
                              @emlowe can you extract those events out to a file
                              curl -sL theurl >somefile.txt
                              and share the file and your calendar config in an email to me
                              same userid at gmail
                              so i can look at it
                              one other thing is open the developers window console tab
                              ctrl-shift-i, select the console tab
                              or do
                              npm run start:dev
                              and see if there are any errors
                              the browser side broadcasts so it GOT the events block
                              then it processes for the ui
                              • emloweE
                                @sdetweil No errors in the console log
                                If I wait long enough where this seems anywhere between 15min to an hour or more, they do appear without a manual refresh.
                                maybe it’s a complexity issue - when I curl the calender link (it’s a google private ICS link) - the resulting file is 4.8MB - I imagine parsing that is somewhat time-consuming
                                  sdetweil @emlowe
                                  @emlowe yes, and new code takes longer than old with lots of events
                                  what is the calendar refreshinterval
                                  • emloweE
                                    @sdetweil You mean fetchInterval: 5 * 60 * 1000?
                                    the calendar module doesn’t have refreshinterval does it?
                                      sdetweil @emlowe
                                      @emlowe fetchInterval is same
                                      • emloweE
                                        I added various log outputs to node_helper.js and calendar.js
                                        node_helper is sending the socket notification for CALENDAR_EVENTS
                                        this is not received by the front end code in calendar.js
                                        I don’t know what happens to it, but I added logging to print out in calendar.js whenever the socketNotificationReceived handler is called and it doesn’t print.
                                        (unless I refresh the page - at which point it does)
                                        emloweE S 3 Replies Last reply
                                        • emloweE
                                          Something even stranger - if I immediately refresh the page it also works. Here I mean is:
                                          npm run server
                                          got to browser and bring up host:8080
                                          calendar will say “Loading” for a very long time
                                          (despite the events getting broadcast)
                                          But if I :
                                          npm run server
                                          go to browser and bring up host:8080
                                          calender says “Loading”
                                          Refresh the page immediately
                                          calendar says “Loading”
                                          calendar will immediately show the events as soon as the events are broadcast
                                            sdetweil @emlowe
                                            @emlowe oh, “cool” ugh, i opened an issue about that last year
                                            just reopened
                                            https://github.com/MagicMirrorOrg/MagicMirror/issues/3380
                                            can you add the contents of your post in an comment
                                            actually this one
                                            https://forum.magicmirror.builders/topic/19345/mmm-calendarext3-only-one-calendar-not-updating/30?page=3#
