    MMM-CalendarExt3 only one calendar not updating
    35 Posts 4 Posters 22.0k Views 4 Watching
      sdetweil @emlowe
      @emlowe the default for ext3 is 30 mins
      if missed at waitFetch
      only see the timing in
      pm2 log
      default calendar working, right?
      emloweE 1 Reply Last reply
      • emloweE
        emlowe Module Developer @sdetweil
        @sdetweil No, I’m stopped testing Ext3 and I am only testing the default calendar.
        it is not working - I see Loading... for some number of minutes or hours, I haven’t determined any consistency. This test run is now past 45 mins and it still says Loading… despite having broadcast the events 9 times:
        [2025-01-27 14:25:24.525] [LOG]   Starting MagicMirror: v2.31.0-develop
        [2025-01-27 14:25:31.806] [LOG]   Create new calendarfetcher for URL ...
        [2025-01-27 14:26:21.083] [INFO]  Calendar-Fetcher: Broadcasting 22 events from ...
        [2025-01-27 14:32:08.812] [INFO]  Calendar-Fetcher: Broadcasting 22 events from ...
        [2025-01-27 14:37:55.863] [INFO]  Calendar-Fetcher: Broadcasting 22 events from
        [2025-01-27 14:43:42.948] [INFO]  Calendar-Fetcher: Broadcasting 22 events from
        [2025-01-27 14:49:30.144] [INFO]  Calendar-Fetcher: Broadcasting 22 events from
        [2025-01-27 15:12:37.552] [INFO]  Calendar-Fetcher: Broadcasting 21 events from
        still says Loading ... - if I refresh the browser page - then they all appear immediately
          sdetweil @emlowe
          @emlowe can you extract those events out to a file
          curl -sL theurl >somefile.txt
          and share the file and your calendar config in an email to me
          same userid at gmail
          so i can look at it
          one other thing is open the developers window console tab
          ctrl-shift-i, select the console tab
          or do
          npm run start:dev
          and see if there are any errors
          the browser side broadcasts so it GOT the events block
          then it processes for the ui
          • emloweE
            @sdetweil No errors in the console log
            If I wait long enough where this seems anywhere between 15min to an hour or more, they do appear without a manual refresh.
            maybe it’s a complexity issue - when I curl the calender link (it’s a google private ICS link) - the resulting file is 4.8MB - I imagine parsing that is somewhat time-consuming
              sdetweil @emlowe
              @emlowe yes, and new code takes longer than old with lots of events
              what is the calendar refreshinterval
              • emloweE
                @sdetweil You mean fetchInterval: 5 * 60 * 1000?
                the calendar module doesn’t have refreshinterval does it?
                  sdetweil @emlowe
                  @emlowe fetchInterval is same
                  • emloweE
                    I added various log outputs to node_helper.js and calendar.js
                    node_helper is sending the socket notification for CALENDAR_EVENTS
                    this is not received by the front end code in calendar.js
                    I don’t know what happens to it, but I added logging to print out in calendar.js whenever the socketNotificationReceived handler is called and it doesn’t print.
                    (unless I refresh the page - at which point it does)
                    emloweE S 3 Replies Last reply
                    • emloweE
                      emlowe Module Developer @emlowe
                      Something even stranger - if I immediately refresh the page it also works. Here I mean is:
                      npm run server
                      got to browser and bring up host:8080
                      calendar will say “Loading” for a very long time
                      (despite the events getting broadcast)
                      But if I :
                      npm run server
                      go to browser and bring up host:8080
                      calender says “Loading”
                      Refresh the page immediately
                      calendar says “Loading”
                      calendar will immediately show the events as soon as the events are broadcast
                        sdetweil @emlowe
                        @emlowe oh, “cool” ugh, i opened an issue about that last year
                        just reopened
                        https://github.com/MagicMirrorOrg/MagicMirror/issues/3380
                        can you add the contents of your post in an comment
                        actually this one
                        https://forum.magicmirror.builders/topic/19345/mmm-calendarext3-only-one-calendar-not-updating/30?page=3#
                          MMRIZE
                          Hmmm… I was in our traditional ceremony with my family - a lunar new year, so I couldn’t catch this post. Sorry.
                          Anyway, this symptom is not my module’s fault, right? There were some reports similar to this, but not figured out.
                            sdetweil @emlowe
                            @emlowe can you try this , configure bigger socketio buffer
                            see the post in the issue
                            https://github.com/MagicMirrorOrg/MagicMirror/issues/3380#issuecomment-2645778523
                              ok, that didnt help
