    MMM-CalendarExt3 only one calendar not updating
    35 Posts 4 Posters 22.0k Views 4 Watching
    • emloweE
      emlowe Module Developer @emlowe
      I guess I should have run some tests with just the standard calendar module.
      Now just using the standard calendar module - and it just says “Loading” despite having also printed “Broadcasting 22 events from”
        sdetweil @emlowe
        @emlowe as you updated to the develop branch, did you also redo the npm run install-mm
        • emloweE
          I did yes - so the current test results are this
          The calendar did eventually appear - but it took quite some time - I wasn’t watching, so I don’t know when exactly - I’ll test again. But it was several minutes after the log output of “broadcasting 22 events”
            sdetweil @emlowe
            @emlowe the default for ext3 is 30 mins
            if missed at waitFetch
            only see the timing in
            pm2 log
            default calendar working, right?
            emloweE 1 Reply Last reply
            • emloweE
              emlowe Module Developer @sdetweil
              @sdetweil No, I’m stopped testing Ext3 and I am only testing the default calendar.
              it is not working - I see Loading... for some number of minutes or hours, I haven’t determined any consistency. This test run is now past 45 mins and it still says Loading… despite having broadcast the events 9 times:
              [2025-01-27 14:25:24.525] [LOG]   Starting MagicMirror: v2.31.0-develop
              [2025-01-27 14:25:31.806] [LOG]   Create new calendarfetcher for URL ...
              [2025-01-27 14:26:21.083] [INFO]  Calendar-Fetcher: Broadcasting 22 events from ...
              [2025-01-27 14:32:08.812] [INFO]  Calendar-Fetcher: Broadcasting 22 events from ...
              [2025-01-27 14:37:55.863] [INFO]  Calendar-Fetcher: Broadcasting 22 events from
              [2025-01-27 14:43:42.948] [INFO]  Calendar-Fetcher: Broadcasting 22 events from
              [2025-01-27 14:49:30.144] [INFO]  Calendar-Fetcher: Broadcasting 22 events from
              [2025-01-27 15:12:37.552] [INFO]  Calendar-Fetcher: Broadcasting 21 events from
              still says Loading ... - if I refresh the browser page - then they all appear immediately
                sdetweil @emlowe
                @emlowe can you extract those events out to a file
                curl -sL theurl >somefile.txt
                and share the file and your calendar config in an email to me
                same userid at gmail
                so i can look at it
                one other thing is open the developers window console tab
                ctrl-shift-i, select the console tab
                or do
                npm run start:dev
                and see if there are any errors
                the browser side broadcasts so it GOT the events block
                then it processes for the ui
                • emloweE
                  @sdetweil No errors in the console log
                  If I wait long enough where this seems anywhere between 15min to an hour or more, they do appear without a manual refresh.
                  maybe it’s a complexity issue - when I curl the calender link (it’s a google private ICS link) - the resulting file is 4.8MB - I imagine parsing that is somewhat time-consuming
                    sdetweil @emlowe
                    @emlowe yes, and new code takes longer than old with lots of events
                    what is the calendar refreshinterval
                    • emloweE
                      @sdetweil You mean fetchInterval: 5 * 60 * 1000?
                      the calendar module doesn’t have refreshinterval does it?
                        sdetweil @emlowe
                        @emlowe fetchInterval is same
                        • emloweE
                          I added various log outputs to node_helper.js and calendar.js
                          node_helper is sending the socket notification for CALENDAR_EVENTS
                          this is not received by the front end code in calendar.js
                          I don’t know what happens to it, but I added logging to print out in calendar.js whenever the socketNotificationReceived handler is called and it doesn’t print.
                          (unless I refresh the page - at which point it does)
                          emloweE S 3 Replies Last reply
                          • emloweE
                            Something even stranger - if I immediately refresh the page it also works. Here I mean is:
                            npm run server
                            got to browser and bring up host:8080
                            calendar will say “Loading” for a very long time
                            (despite the events getting broadcast)
                            But if I :
                            npm run server
                            go to browser and bring up host:8080
                            calender says “Loading”
                            Refresh the page immediately
                            calendar says “Loading”
                            calendar will immediately show the events as soon as the events are broadcast
                              sdetweil @emlowe
                              @emlowe oh, “cool” ugh, i opened an issue about that last year
                              just reopened
                              https://github.com/MagicMirrorOrg/MagicMirror/issues/3380
                              can you add the contents of your post in an comment
                              actually this one
                              https://forum.magicmirror.builders/topic/19345/mmm-calendarext3-only-one-calendar-not-updating/30?page=3#
                                MMRIZE
                                Hmmm… I was in our traditional ceremony with my family - a lunar new year, so I couldn’t catch this post. Sorry.
                                Anyway, this symptom is not my module’s fault, right? There were some reports similar to this, but not figured out.
                                  sdetweil @emlowe
                                  @emlowe can you try this , configure bigger socketio buffer
                                  see the post in the issue
                                  https://github.com/MagicMirrorOrg/MagicMirror/issues/3380#issuecomment-2645778523
                                    ok, that didnt help
