    MMM-CalendarExt3 only one calendar not updating
    35 Posts 4 Posters 22.0k Views 4 Watching
    • emloweE
      emlowe Module Developer
      Yea, it’s a mystery to me as well - I just know doing the manual refresh works very reliably.
      I’ve had this problem on a stock pi3 b and a pi3 a+ - initially, I thought it was related to the low memory issues on the pi3 a+ - but as I update to use this new module from older ones I’ve seen it again on a stock 4gb pi3
        sdetweil @emlowe
        @emlowe its clearly a timing issue… multiple people have encountered it…
        I think you can change the waitFetch value up , depending on the time between fetchs as shown in the pm2 logs…
        emloweE 1 Reply Last reply
        • emloweE
          emlowe Module Developer @sdetweil
          Was out for a week - some more details:
          Here are relevant log entries:
          0|MagicMirror | [2025-01-27 10:54:33.580] [LOG] Launching application.
          0|MagicMirror | [2025-01-27 10:54:50.855] [LOG] Create new calendarfetcher for url: - Interval: 300000
          0|MagicMirror | [2025-01-27 10:55:44.585] [INFO] Calendar-Fetcher: Broadcasting 23 events from
          0|MagicMirror | [2025-01-27 11:01:33.443] [INFO] Calendar-Fetcher: Broadcasting 23 events from
          So that was about a minute to broadcast the first time, and then it follows the refresh interval reasonably closes.
          I have the Ext3 module waitFetch set to 5 minutes (5 * 60 *1000) - well after the first broadcast. When the Ext3 module draws after 5 minutes, there is nothing in it, and it is empty with no events whatsoever. It’s like it has no data at all.
          I have the Ext3 module refreshInterval set to 7 minutes (7 * 60 * 1000) - after the 7 minutes the module will refresh and it remains empty despite the calendar having done two broadcasts. The Ext3 module will remain empty for hours.
          However, if I manually refresh the browser using the remotecontrol module - the Ext3 module takes 5 minutes to appear (based on waitFetch but will have all the data)
            sdetweil @emlowe
            @emlowe waitfetch is from CalendarExt3 start to latest broadcast
            i cannot see start but latest is at 11:01:33
            find start time and subtract. add a couple seconds for variability
            his default waitfetch is 5 SECONDS
            Then after that, next screen refresh is at updateInterval time
            also 23 events seems small, if this is mm v2.23.0, you did put on the clipping fixes right?
            is this the SAME calendar broadcasting?
            then to its first broadcast from ext3 start
            • emloweE
              I am on the develop branch
              The entire start is at 10:54:23
              [2025-01-27 10:54:23.207] [LOG] Starting MagicMirror: v2.31.0-develop
              I’m not sure when Ext3Agenda starts as there is no log item specific to that afaik - but I assume it’s sometime around:
              [2025-01-27 10:54:26.290] [LOG] No helper found for module: MMM-CalendarExt3Agenda.
              so Ext3 start is no earlier than 10:54:23 and the first broadcast was at 10:55:44 - this is much less than the 5 minutes I have manually configured for waitFetch.
              (in other words, I am waiting much longer than should be needed, but it does not work unless I manually refresh)
              The log at 11:01 is the second broadcast of the same calendar
              I am only pulling 5 days of data and not broadcasting past events, 23 is correct.
              hiddenOnStartup: true,
                  broadcastEvents: true,
                  broadcastPastEvents: false,
                  maximumNumberOfDays: 5,
                  maximumEntries: 100,
                  fetchInterval: 5 * 60 * 1000,
                      URL: "<redacted>"
              module: "MMM-CalendarExt3Agenda",
                  showMiniMonthCalendar: false,
                  firstDayOfWeek: 1,
                  startDayIndex: 0,
                  endDayIndex: 0,
                  calendarSet: ['family'],
                  waitFetch: 5 * 60 * 1000,
                  refreshInterval: 7 * 60 * 1000,
                sdetweil @emlowe
                @emlowe ok, in the case of modules that only have a browser component ( no node helper) then
                starting application message is the start time
                another use just resolved the same issue w waitfetch, but he had multiple calendars
                https://forum.magicmirror.builders/topic/19359/mmm-calendarext3agenda-on-a-higher-screen-resolution?page=2
                • emloweE
                  Further strangeness.
                  Let’s say I change waitFetch to something that shouldn’t work (eg 5 seconds) - clearly, this doesn’t work since the first broadcast is after a minute or so.
                  But if I manually refresh the browser as soon as I see the log entry about the broadcast - everything appears just fine.
                  So for example, setting
                  waitFetch: 5 * 1000,
                  refreshInterval: 2 * 60 * 1000,
                  Nothing will appear in the calendar - not at start (expected) and not after 2 mins (1 refresh), or 4 mins, or 10 mins or however long I want to wait - nothing.
                  But if I manually refresh - everything appears right away as long as I refresh after the broadcast log line
                    sdetweil @emlowe
                    @MMRIZE will have to advise. this is the depth of my knowledge
                    i work on the default calendar
                    well, one thing
                    when you refresh the page, all the modules web components are reloaded. the default cal sends a request to its node helper to get events. and it has them already, so sends immediately
                    and of course because the default cal will be shown, its shows with the correct events, right??
                    • emloweE
                      Yea, I believe the default calender is working and broadcasting correctly - not sure exactly where Ext3Agenda is having problems - but I have a few ideas I plan to try out.
                      • emloweE
                        emlowe Module Developer @emlowe
                        Bah! I have to apologize - I was on the develop branch but apparently, I was some commits behind and I think I was missing the commit that fixed the “clipping” problem
                        I made sure to update to the head of develop and things are working much better now. So it seems all along it has been the known issue
                        Doh!
                        • emloweE
                          Actually have to take this back. Currently testing running in server only mode and a browser so I can see the console easier
                          When I see in the log this line:
                          [2025-01-27 13:52:24.893] [INFO] Calendar-Fetcher: Broadcasting 22 events from <redacted>
                          I can say that modules are NOT getting any calendar notifications, despite this log entry. They are not broadcast. I added some code to Ext3Agenda to print out when it gets any notification, and it never gets any CAL items. (I see it getting DOM_CREATED, DOM_UPDATED, etc,etc)
                          I see in the console log the following:
                          sorting events count=0
                          slicing events total maxcount=100
                          which seems odd given that the helper reported broadcasting 22 events. Those items repeat in the console log , but it’s always sorting events count=0
                          UNTIL I refresh the browser - Now I see the Ext3Agenda module getting CALENDER_EVENTS and sorting events count=22
                          • emloweE
                            I guess I should have run some tests with just the standard calendar module.
                            Now just using the standard calendar module - and it just says “Loading” despite having also printed “Broadcasting 22 events from”
                              sdetweil @emlowe
                              @emlowe as you updated to the develop branch, did you also redo the npm run install-mm
                              • emloweE
                                I did yes - so the current test results are this
                                The calendar did eventually appear - but it took quite some time - I wasn’t watching, so I don’t know when exactly - I’ll test again. But it was several minutes after the log output of “broadcasting 22 events”
                                  sdetweil @emlowe
                                  @emlowe the default for ext3 is 30 mins
                                  if missed at waitFetch
                                  only see the timing in
                                  pm2 log
                                  default calendar working, right?
                                  • emloweE
                                    @sdetweil No, I’m stopped testing Ext3 and I am only testing the default calendar.
                                    it is not working - I see Loading... for some number of minutes or hours, I haven’t determined any consistency. This test run is now past 45 mins and it still says Loading… despite having broadcast the events 9 times:
                                    [2025-01-27 14:25:24.525] [LOG]   Starting MagicMirror: v2.31.0-develop
                                    [2025-01-27 14:25:31.806] [LOG]   Create new calendarfetcher for URL ...
                                    [2025-01-27 14:26:21.083] [INFO]  Calendar-Fetcher: Broadcasting 22 events from ...
                                    [2025-01-27 14:32:08.812] [INFO]  Calendar-Fetcher: Broadcasting 22 events from ...
                                    [2025-01-27 14:37:55.863] [INFO]  Calendar-Fetcher: Broadcasting 22 events from
                                    [2025-01-27 14:43:42.948] [INFO]  Calendar-Fetcher: Broadcasting 22 events from
                                    [2025-01-27 14:49:30.144] [INFO]  Calendar-Fetcher: Broadcasting 22 events from
                                    [2025-01-27 15:12:37.552] [INFO]  Calendar-Fetcher: Broadcasting 21 events from
                                    still says Loading ... - if I refresh the browser page - then they all appear immediately
                                      sdetweil @emlowe
                                      @emlowe can you extract those events out to a file
                                      curl -sL theurl >somefile.txt
                                      and share the file and your calendar config in an email to me
                                      same userid at gmail
                                      so i can look at it
                                      one other thing is open the developers window console tab
                                      ctrl-shift-i, select the console tab
                                      or do
                                      npm run start:dev
                                      and see if there are any errors
                                      the browser side broadcasts so it GOT the events block
                                      then it processes for the ui
                                      • emloweE
                                        @sdetweil No errors in the console log
                                        If I wait long enough where this seems anywhere between 15min to an hour or more, they do appear without a manual refresh.
                                        maybe it’s a complexity issue - when I curl the calender link (it’s a google private ICS link) - the resulting file is 4.8MB - I imagine parsing that is somewhat time-consuming
                                          sdetweil @emlowe
                                          @emlowe yes, and new code takes longer than old with lots of events
                                          what is the calendar refreshinterval
                                          • emloweE
                                            @sdetweil You mean fetchInterval: 5 * 60 * 1000?
                                            the calendar module doesn’t have refreshinterval does it?
