    MMM-SystemMonitor
    24 Posts 7 Posters 9.2k Views 6 Watching
      sdetweil @Richard238
      @Richard238 what is the error?
      npm run config:check
        Richard238 @sdetweil
        @sdetweil said in MMM-SystemMonitor:
        pi@mmv2:~ $ npm run config:check
        npm error code ENOENT
        npm error syscall open
        npm error path /home/pi/package.json
        npm error errno -2
        npm error enoent Could not read package.json: Error: ENOENT: no such file or directory, open '/home/pi/package.json'
        npm error enoent This is related to npm not being able to find a file.
        npm error enoent
        npm error A complete log of this run can be found in: /home/pi/.npm/_logs/2025-02-02T19_09_35_627Z-debug-0.log
        pi@mmv2:~ $
          @Richard238 in the MagicMirror folder
            [2025-02-02 21:35:32.330] [INFO]  Checking modules structure configuration ...
            [2025-02-02 21:35:32.511] [ERROR] Cannot read properties of undefined (reading 'units')
            Module says:
            units: config.units,
            And also tried with
            units: metric,
            Which failed with:
            [ERROR] metric is not defined
            config.js towards the beginning says:
            units: 'metric',
              @Richard238 to the right of :
              Numbers and true/false do not need quotes
              Any thing that has a letter needs quotes
                I don’t understand, sorry?
                  @Richard238 in config.js all properties are
                  The value, to the right of the colon (:)
                  If a number or tr/false
                  Does not need quotes
                  If it contains a letter or symbol
                  It needs quotes
                  units : metric
                  To the right is metric
                  It has letters, so needs quotes
                    That’s fixed it.
                    Module in config.js
                    units: 'config.units'
                    config.js before modules
                    was
                    units: 'metric',
                    Changed it to
                    units: "metric",
                    Quite how Free Memory can be 128% I’ve no idea, that’s for another day.
                    For now, it’s working. Thank you!
                      @Richard238 cool. Single or double quotes don’t matter as long as they are matched
                      Be careful on quotes and copying from the forum
                      If the quotes are curved, they are word processing style and Javascript doesn’t understand them
                      " or ’
                      If they are vertical, they are good
                      " or  '
                        JS lesson #1 :-)
                          mebster5 @btastic
                          @btastic
                          I’m new to MM and just been putting together my board over the last week.
                          I’ve used your module and think it’s great.
                          One thing I did find is that your default way of grabbing diskspace had the device hard coded.
                          I made this change to node_helper.js:
                          async.apply(exec, "df -h /|grep dev|awk '{print $4}'"),
                          That looked for the root partition and was able to then return the correct value for me.
                            sdetweil @mebster5
                            @mebster5 submit that as a pr
