    How to load a <script> src = " " </script> into my mirror?
    35 Posts 4 Posters 33.2k Views 5 Watching
    • morozgrafixM Offline
      morozgrafix Moderator @nbrenn
      @nbrenn is your mirror up and running with npm start or node serveronly? If webserver isn’t running on port 8080 you will get connection refused error when attempting to access it over HTTP.
      • N Offline
        nbrenn @morozgrafix
        @morozgrafix I start my mirror with npm start. And my Mirror config.js, I am using Port 8080.
        morozgrafixM 1 Reply Last reply Reply Quote 0
          @nbrenn when your electron MM app shows up on the screen and while it is running, you should be able to do wget http://localhost:8080 without getting connection refused.
          • N Offline
            nbrenn @morozgrafix
            @morozgrafix Yep, when the mirror was running, and running the wget http://localhost:8080 command, I connected successfully.
            So then when I open up a command terminal while the mirror is running, and run:
            wget http://localhost:8080/home/pi/MagicMirror/modules/datafeed/JANUARY22TEST.csv
            it says connected to 8080, but returns 404 Not Found.
              @nbrenn that path is incorrect. Try
              wget http://localhost:8080/modules/datafeed/JANUARY22TEST.csv
              • N Offline
                nbrenn @morozgrafix
                @morozgrafix You got it! The path was the issue. Do you know why I can’t use the path the way I specified?
                Now, I’ll go back and try your solution and see if I have any other problems!
                Thanks again for your help. It’s much appreciated.
                  @nbrenn glad you are getting closer to solving this.
                  Root directory that is served by webserver that is running on localhost:8080/ is mapped to MagicMirror directory. In most cases and in your case the full path of that is /home/pi/MagicMirror.
                  By default it is configured to serve you index.html.
                  So mapping looks kind of like this:
                  http://localhost:8080					---->	/home/pi/MagicMirror/
                  http://localhost:8080/index.html			---->	/home/pi/MagicMirror/index.html
                  http://localhost:8080/modules/module_name		---->	/home/pi/MagicMirror/modules/module_name/
                  http://localhost:8080/modules/module_name/foo.html	---->	/home/pi/MagicMirror/modules/module_name/foo.html
                  as you can see from above when you asking for
                  webserver will attempt to serve you something from
                  /home/pi/MagicMirror/home/pi/MagicMirror/modules/datafeed/JANUARY22TEST.csv
                  which doesn’t really exist and that’s the reason why you can’t use absolute file path in the URL. Which also brings up another point: because root directory that is served by webserver is mapped to /home/pi/MagicMirror, webserver can’t serve anything above the /home/pi/MagicMirror directory. (for example you won’t be able to access /home/pi/foo.html).
                  This is just a small portion of how it works and there are other rules that play role, but hopefully this info shines some light and gives you enough explanation on why your path didn’t work.
                    I’ve moved this thread into Development category, since conversation is now mostly related to your module development.
                    Thanks.
                    • N Offline
                      nbrenn @morozgrafix
                      @morozgrafix I am referring back to your jsfiddle example: jsfiddle example, and you created an object called csvData which you refer to in var data = ...
                      I was wondering how I would create a similar object, except with the file that I have in my directory. I couldn’t seem to find an HTML DOM function that would allow me to load the .csv file. I looked at the examples for the Compliments module, and they were in json. So, I saw that I might be able to use Papa Parse to convert the .csv to json and then follow the similar route as the Compliments.
                      My d3 approach loads the data from my csv onto my mirror, but the .css doesn’t seem to help it. It doesn’t appear in a table, and is very large (displaying in the upper left part of the mirror) even when I specified it to load in the middle.
                      For some context, my .csv data table contains two columns of time-series data for which I want to sum together. And then I just want to output a sentence like, “Your sum is XXX.”
                      Thanks again for the clarifications. I’m slowly wrapping my head around the interaction of the HTML and Javascript, and I think I get confused when I see code split into HTML and Javascript, when the modules are written with it all together in the HTML DOM format.
                        It would be very difficult for me to guide you through building entire module without seeing the code and understanding what it is doing. That’s the reason why I’m only able to give you bits and pieces of information. One of the things that can help is for you to create a repo on GitHub with code that you got so far and then I can take a look and possibly offer some suggestions.
                        In your original post you mentioned that you wanted to display CSV data from the file in HTML table format which seems a bit different from your most recent requirement:
                        To achieve the above following very rough logic would need to be implemented:
                        1. CSV file is created/updated in /home/pi/MagicMirror/modules/datafeed/file.csv
                        2. When module is loaded JS creates a variable and reads contents of the CSV file into it (similar to what compliments module does)
                        3. CSV data in that variable is parsed, sum of the values in one of the columns calculated and assigned to another variable (sum).
                        4. DOM element is created and innerHTML of that element is updated with "Your sum is " + sum
                        5. At given config interval steps 1-4 are repeated to get fresh set of data.
                        Is this close to something that you are trying to do?
                        (Above steps aren’t accounting for any error handling etc.)
                        BTW I don’t think you need to convert your CSV to JSON, especially if this is a simple 2 column file. Commenting out or removing xobj.overrideMimeType("application/json"); from complimentFile example should be sufficient for CSV file reading.
                        Thanks.
                          morozgrafix Moderator @morozgrafix
                          I also updated JSfiddle example with sum calculation logic: https://jsfiddle.net/morozgrafix/8oz1t9g4/2/
                          • N Offline
                            nbrenn @morozgrafix
                            @morozgrafix Thanks for your outline. It is very, very helpful and appreciated. So I tried to take what you suggested to turn it into my code, and put it onto GitHub.
                            I created a GitHub repository that contains my .css, .csv, and datafeed.js. My areas of confusion (which you’ll probably see in the code) are around how I called in the remoteFile in my getDom. I am not sure if I did that correctly. https://github.com/brennn1/Magic-Mirror-Datafeed-Module
                            My .csv is coming in the format which you’ll see on the Github - so each data point is separated by a new line. So I changed where you had the line.split(",") to line.split("\n").
                            Do you see anything obvious that will cause me problems? I will go ahead and see what errors I get when I load it onto my mirror.
                            morozgrafixM 2 Replies Last reply Reply Quote 0
                              @nbrenn perfect!!! i can now see your full code and have better idea what you are trying to achieve.
                              Your data file is not really a CSV (Comma Separated Values) file, just a text file with values on each line, so you were correct to remove that line.split(",") part. I already spotted a few things where your code will not work correctly. I will take a closer look at it later tonight and hopefully together we can get this resolved.
                                @nbrenn I’ve reworked the code to follow that logic outline to get Your sum is 37 to show up in the middle of the MM. You can find a PR on GitHub or just look at my fork of your repo. Most of the code is commented and hopefully easy to follow. I also added some configuration options for better flexibility.
                                0_1485341408447_upload-7b56fda4-6a24-42d5-8a75-8fc10ccd0dc4
                                Since you didn’t need a table any longer, I took some shortcuts with processing the data and just calculating the sum of all numeric values from the file. You can add the module to the MM and then as it runs update the datafile with new values, MM should update in about a minute or whatever your updateInterval is set to.
                                Let me know if you have any questions.
                                P.S. I didn’t run it on RasPi, but it should work without a problem. :fingers_crossed: Also if you are planning to make this module available for others it may be worth renaming it to MMM-datafeed to follow the standard naming conventions.
                                N 1 Reply Last reply Reply Quote 1
                                • N Offline
                                  nbrenn @morozgrafix
                                  @morozgrafix This looks awesome! I will try to work with this over the next couple days and will let you know if I have any other questions! Thanks!
                                    @nbrenn sounds good. Good luck!
                                    • N Offline
                                      nbrenn @morozgrafix
                                      @morozgrafix Everything is working very well so far!
                                      I am updating my “Sum” daily, but I would like to be able to show the previous day’s sum. Could I store the value of the sum at 11:59pm, each evening, and then display that value in addition to the current day’s sum?
                                      Additionally, how could I modify the line of code:
                                      this.sum = lines.reduce((a, b) => a + b, 0);
                                      to allow for me to sum across multiple columns? So, if my .csv has 3 columns, I’d like the sum total of them.
                                      • cowboysdudeC Offline
                                          @nbrenn sorry swamped at work today. That line just takes all of the values from each line and adds them up. It will not work for multiple columns and true csv files. You would need to resort to logic that we had initially in JSfiddle. If I have time I will look into this later today.
                                          • N Offline
                                            nbrenn @morozgrafix
                                            @morozgrafix I think I can work around this by changing the SQL query (that generates my .csv) to include just one column. Then I can implement it as a new module, placed above the current one.
