    I need Help. my shopping list is not clickable
    9 Posts 3 Posters 966 Views 3 Watching
    • L Offline
      lucifer6669
      so I’m not sure if this is the right area but, I built a module to create a real time editable shopping list. the core is there but I cannot click into the box to add an item. when I check the dev logs it shows no issues and when I exit dev logs it lets me type into the box, but I cannot add the item. once I click out the box I cannot click in it. I’m stumped and even resorted to AI for help with zero luck. what am I missing? any help would be greatly appreciated.
      Module.register("MMM-ShoppingList", {
          defaults: {
              initialItems: [] // Initial items in the shopping list
          start: function() {
              console.log("Starting module: " + this.name);
              this.shoppingList = this.config.initialItems;
          getStyles: function() {
              return ["MMM-ShoppingList.css"];
          getDom: function() {
              wrapper.id = "shopping-list-container";
              var heading = document.createElement("h1");
              heading.innerText = "Shopping List";
              wrapper.appendChild(heading);
              var list = document.createElement("ul");
              list.id = "shopping-list";
              wrapper.appendChild(list);
              for (let item of this.shoppingList) {
                  list.appendChild(this.createListItem(item));
              var inputDiv = document.createElement("div");
              inputDiv.id = "add-item";
              var input = document.createElement("input");
              input.type = "text";
              input.id = "new-item";
              input.placeholder = "Add new item...";
              inputDiv.appendChild(input);
              var button = document.createElement("button");
              button.innerText = "Add";
              button.onclick = () => {
                  alert("Button clicked");
                  this.addItem(input.value);
                  input.value = "";
              inputDiv.appendChild(button);
              wrapper.appendChild(inputDiv);
              console.log('Returning wrapper with interactive elements');
              console.log('DOM:', wrapper);
              return wrapper;
          createListItem: function(item) {
              var li = document.createElement("li");
              li.innerText = item;
              var deleteSpan = document.createElement("span");
              deleteSpan.className = "delete";
              deleteSpan.innerHTML = "❌";
              deleteSpan.onclick = () => {
                  alert("Delete clicked");
                  this.removeItem(item);
              li.appendChild(deleteSpan);
              return li;
          addItem: function(item) {
              if (item === "") return;
              console.log('Adding item:', item);
              this.shoppingList.push(item);
              this.renderShoppingList();
              console.log('Item added:', item);
          removeItem: function(item) {
              console.log('Removing item:', item);
              this.shoppingList = this.shoppingList.filter(i => i !== item);
              console.log('Item removed:', item);
          renderShoppingList: function() {
              var list = document.getElementById("shopping-list");
              if (list) {
                  list.innerHTML = "";
                      console.log('Rendering item:', item);
                  console.log('DOM updated with new list');
              } else {
                  console.log('Error: Shopping list container not found');
              console.log('Notification received:', notification);
              if (notification === "DOM_OBJECTS_CREATED") {
                  console.log('DOM_OBJECTS_CREATED notification received');
      the Dev Log:
      Initializing MagicMirror².
      translator.js:116 Loading core translation file: translations/en.json
      VM4 sandbox_bundle:2 Electron Security Warning (Insecure Content-Security-Policy) This renderer process has either no Content Security
        Policy set or a policy with "unsafe-eval" enabled. This exposes users of
        this app to unnecessary security risks.
      For more information and help, consult
      https://electronjs.org/docs/tutorial/security.
      This warning will not show up
      once the app is packaged.
      warnAboutInsecureCSP @ VM4 sandbox_bundle:2
      translator.js:132 Loading core translation fallback file: translations/en.json
      loader.js:178 Load script: modules/MMM-Cursor/MMM-Cursor.js
      module.js:489 Module registered: MMM-Cursor
      loader.js:151 Bootstrapping module: MMM-Cursor
      loader.js:155 Scripts loaded for: MMM-Cursor
      loader.js:194 Load stylesheet: modules/MMM-Cursor/MMM-Cursor.css
      loader.js:158 Styles loaded for: MMM-Cursor
      loader.js:161 Translations loaded for: MMM-Cursor
      loader.js:178 Load script: modules/default/alert/alert.js
      module.js:489 Module registered: alert
      loader.js:151 Bootstrapping module: alert
      loader.js:178 Load script: modules/default/alert/notificationFx.js
      loader.js:155 Scripts loaded for: alert
      loader.js:194 Load stylesheet: vendor/css/font-awesome.css
      loader.js:194 Load stylesheet: modules/default/alert/./styles/notificationFx.css
      loader.js:194 Load stylesheet: modules/default/alert/./styles/center.css
      loader.js:158 Styles loaded for: alert
      translator.js:99 alert - Load translation: translations/en.json
      translator.js:99 alert - Load translation fallback: translations/bg.json
      loader.js:161 Translations loaded for: alert
      loader.js:178 Load script: modules/default/clock/clock.js
      module.js:489 Module registered: clock
      loader.js:151 Bootstrapping module: clock
      loader.js:178 Load script: vendor/node_modules/moment/min/moment-with-locales.js
      loader.js:178 Load script: vendor/node_modules/moment-timezone/builds/moment-timezone-with-data.js
      loader.js:178 Load script: vendor/node_modules/suncalc/suncalc.js
      loader.js:155 Scripts loaded for: clock
      loader.js:194 Load stylesheet: modules/default/clock/clock_styles.css
      loader.js:158 Styles loaded for: clock
      loader.js:161 Translations loaded for: clock
      loader.js:178 Load script: modules/MMM-WiFiPassword/MMM-WiFiPassword.js
      module.js:489 Module registered: MMM-WiFiPassword
      loader.js:151 Bootstrapping module: MMM-WiFiPassword
      loader.js:178 Load script: modules/MMM-WiFiPassword/qrcode.min.js
      loader.js:194 Load stylesheet: modules/MMM-WiFiPassword/MMM-WiFiPassword.css
      loader.js:155 Scripts loaded for: MMM-WiFiPassword
      loader.js:158 Styles loaded for: MMM-WiFiPassword
      loader.js:161 Translations loaded for: MMM-WiFiPassword
      loader.js:178 Load script: modules/MMM-ShoppingList/MMM-ShoppingList.js
      module.js:489 Module registered: MMM-ShoppingList
      loader.js:151 Bootstrapping module: MMM-ShoppingList
      loader.js:155 Scripts loaded for: MMM-ShoppingList
      loader.js:194 Load stylesheet: modules/MMM-ShoppingList/MMM-ShoppingList.css
      loader.js:158 Styles loaded for: MMM-ShoppingList
      loader.js:161 Translations loaded for: MMM-ShoppingList
      loader.js:178 Load script: modules/default/weather/weather.js
      module.js:489 Module registered: weather
      loader.js:151 Bootstrapping module: weather
      loader.js:254 File already loaded: moment.js
      loader.js:178 Load script: modules/default/weather/weatherutils.js
      loader.js:178 Load script: modules/default/weather/weatherobject.js
      loader.js:178 Load script: modules/default/weather/providers/overrideWrapper.js
      loader.js:178 Load script: modules/default/weather/weatherprovider.js
      loader.js:254 File already loaded: suncalc.js
      loader.js:178 Load script: modules/default/weather/providers/openmeteo.js
      loader.js:155 Scripts loaded for: weather
      loader.js:254 File already loaded: font-awesome.css
      loader.js:194 Load stylesheet: vendor/node_modules/weathericons/css/weather-icons.css
      loader.js:194 Load stylesheet: modules/default/weather/weather.css
      loader.js:158 Styles loaded for: weather
      loader.js:161 Translations loaded for: weather
      loader.js:254 File already loaded: weatherutils.js
      loader.js:254 File already loaded: weatherobject.js
      loader.js:254 File already loaded: modules/default/weather/providers/overrideWrapper.js
      loader.js:254 File already loaded: weatherprovider.js
      loader.js:254 File already loaded: modules/default/weather/providers/openmeteo.js
      loader.js:254 File already loaded: weather-icons.css
      loader.js:254 File already loaded: weather.css
      loader.js:178 Load script: modules/MMM-DailyChoreGridColor/MMM-DailyChoreGridColor.js
      module.js:489 Module registered: MMM-DailyChoreGridColor
      loader.js:151 Bootstrapping module: MMM-DailyChoreGridColor
      loader.js:155 Scripts loaded for: MMM-DailyChoreGridColor
      loader.js:158 Styles loaded for: MMM-DailyChoreGridColor
      loader.js:161 Translations loaded for: MMM-DailyChoreGridColor
      loader.js:178 Load script: modules/MMM-Fireworks/MMM-Fireworks.js
      module.js:489 Module registered: MMM-Fireworks
      loader.js:151 Bootstrapping module: MMM-Fireworks
      loader.js:178 Load script: https://cdnjs.cloudflare.com/ajax/libs/p5.js/1.5.0/p5.min.js
      loader.js:155 Scripts loaded for: MMM-Fireworks
      loader.js:158 Styles loaded for: MMM-Fireworks
      loader.js:161 Translations loaded for: MMM-Fireworks
      loader.js:194 Load stylesheet: css/custom.css
      MMM-Cursor.js:24 Starting module: MMM-Cursor
      alert.js:42 Starting module: alert
      clock.js:43 Starting module: clock
      MMM-ShoppingList.js:7 Starting module: MMM-ShoppingList
      weatherprovider.js:28 Weather provider: Open-Meteo initialized.
      weatherprovider.js:39 Weather provider: Open-Meteo started.
      main.js:601 All modules started!
      MMM-ShoppingList.js:103 Notification received: ALL_MODULES_STARTED
      MMM-Fireworks.js:68 Notification received: ALL_MODULES_STARTED
      MMM-ShoppingList.js:51 Returning wrapper with interactive elements
      MMM-ShoppingList.js:52 DOM: <div id=​"shopping-list-container">​<h1>​Shopping List​</h1>​<ul id=​"shopping-list">​<li>​flex"Milk"<span class=​"delete">​❌​</span>​</li>​<li>​flex"Eggs"<span class=​"delete">​❌​</span>​</li>​<li>​flex"Bread"<span class=​"delete">​❌​</span>​</li>​</ul>​<div id=​"add-item">​<input type=​"text" id=​"new-item" placeholder=​"Add new item...">​<button>​Add​</button>​</div>​</div>​
      MMM-ShoppingList.js:103 Notification received: MODULE_DOM_CREATED
      MMM-Fireworks.js:68 Notification received: MODULE_DOM_CREATED
      MMM-ShoppingList.js:103 Notification received: DOM_OBJECTS_CREATED
      MMM-ShoppingList.js:105 DOM_OBJECTS_CREATED notification received
      MMM-ShoppingList.js:93 Rendering item: Milk
      MMM-ShoppingList.js:93 Rendering item: Eggs
      MMM-ShoppingList.js:93 Rendering item: Bread
      MMM-ShoppingList.js:96 DOM updated with new list
      MMM-Fireworks.js:68 Notification received: DOM_OBJECTS_CREATED
      weather.js:164 New weather information available.
      MMM-ShoppingList.js:103 Notification received: CURRENTWEATHER_TYPE
      MMM-Fireworks.js:68 Notification received: CURRENTWEATHER_TYPE
      MMM-ShoppingList.js:103 Notification received: WEATHER_UPDATED
      MMM-Fireworks.js:68 Notification received: WEATHER_UPDATED
      • L Offline
        lucifer6669 @sdetweil
        @sdetweil @chrisfr1976 you all are amazing. all i had to do was change the fireworks to fullscreen_below and now it all works. the text box is clickable and editable and the chores list sets off the fireworks and i see them. thank you both. i enjoy learning and doing all this.
          sdetweil @lucifer6669
          @lucifer6669 are spans clickable ?
          use the developers window, ctrl-shift-i
          sources tab
          find your code in left nav, then you can step thru the code as it happens
          • L Offline
            @sdetweil honestly at this point I have no idea what i’m doing. I have another module chore list that has clickable toggles and button and even activates fireworks once everything is marked done and it works perfectly fine
            C S 2 Replies Last reply Reply Quote 0
              chrisfr1976 @lucifer6669
              @lucifer6669 Hi,
              you’re running this:
              If is is configured in fullscreen_above you can’t see it but it is there.
              I think MMM-Fireworks it can be in fullscreen_behind. But you may need to check if you have a background image that the z-index is correct. You can try to add in the background image css a z-index: -2; and for Fireworks a z-index: -1;. Then start a test for Fireworks. If you can see it, it should be okay and you can click in your list. I’m not sure if this works. This is on my to-check-list :)
              Regards, Chris.
              S L 2 Replies Last reply Reply Quote 0
                @chrisfr1976 fullscreen_below
                  @lucifer6669 also, you should start w your module only while developing
                  • L Offline
                    lucifer6669 @chrisfr1976
                    @chrisfr1976 thanks. i will try this. i have no issues with the fireworks module firing when my chore list is completed. but it may be interfering with the clickable chore list.
                    • L Offline
                        @lucifer6669
                        I’ve just fixed that issue in general. I’ve added wrapper.style.pointerEvents = "none"; and p.canvas.style.pointerEvents = "none"; in the module file. This allows pointer events to pass to modules underneath! So also the CalExt3 can be used again with the pop-up windows. I’m also very happy now :-)
                        Cheers Chris!
                        Regards, Chris.
