    I need Help. my shopping list is not clickable
    9 Posts 3 Posters 1.0k Views 3 Watching
      chrisfr1976 @lucifer6669
      @lucifer6669 Hi,
      you’re running this:
      loader.js:178 Load script: modules/MMM-Fireworks/MMM-Fireworks.js
      module.js:489 Module registered: MMM-Fireworks
      loader.js:151 Bootstrapping module: MMM-Fireworks
      If is is configured in fullscreen_above you can’t see it but it is there.
      I think MMM-Fireworks it can be in fullscreen_behind. But you may need to check if you have a background image that the z-index is correct. You can try to add in the background image css a z-index: -2; and for Fireworks a z-index: -1;. Then start a test for Fireworks. If you can see it, it should be okay and you can click in your list. I’m not sure if this works. This is on my to-check-list :)
      Regards, Chris.
      S L 2 Replies Last reply Reply Quote 0
        sdetweil @chrisfr1976
        @chrisfr1976 fullscreen_below
          sdetweil @lucifer6669
          @lucifer6669 also, you should start w your module only while developing
          • L Offline
            lucifer6669 @chrisfr1976
            @chrisfr1976 thanks. i will try this. i have no issues with the fireworks module firing when my chore list is completed. but it may be interfering with the clickable chore list.
            • L Offline
              lucifer6669 @sdetweil
              @sdetweil @chrisfr1976 you all are amazing. all i had to do was change the fireworks to fullscreen_below and now it all works. the text box is clickable and editable and the chores list sets off the fireworks and i see them. thank you both. i enjoy learning and doing all this.
                @lucifer6669
                I’ve just fixed that issue in general. I’ve added wrapper.style.pointerEvents = "none"; and p.canvas.style.pointerEvents = "none"; in the module file. This allows pointer events to pass to modules underneath! So also the CalExt3 can be used again with the pop-up windows. I’m also very happy now :-)
                Cheers Chris!
                Regards, Chris.
