    MMM-DWD-Pollen and MMM-pollen remain in status "loading"
    3 Posts 2 Posters 814 Views 2 Watching
    • K
      Klinge
      Spring is coming and I wanted to install pollen modules.
      So I installed two pollen modules MM-DWD-Pollen and MMM-pollen at once
      Both modules remain in the ‘loading’ status.
      Here I show you my configuration
                                      module: "MMM-DWD-Pollen",
                                      header: "Pollenwarnung",
                                              updateInterval: 2 * 60 * 60 * 1000, // every 1 hour
                                              DWD_region: 42, // Ostwestfalen
                                              icon: true, // Show icons or not
                                              showNullValue: false, //Show value or symbol if value is 0
                                              module: "MMM-pollen",
                                              position: "top_right",  // This can be any of the regions.
                                                      locationLongitude: x.xxxxxx,
                                                      locationLatitude: xx.xxxxxx,
      When I start the MMM I got this log
      [2025-02-18 15:47:06.959] [INFO]  Checking git for module: MMM-DWD-Pollen
      [2025-02-18 15:47:07.387] [INFO]  Checking git for module: MMM-pollen
      [2025-02-18 15:47:07.491] [LOG]   MMM-DWD-Pollen: Success loading
      and regarding the two instances from another DWD-Pollen forum post I got the following result
      pi@raspi-mm-bad:~/MagicMirror $ netstat -plan|grep 8080
      (Not all processes could be identified, non-owned process info
       will not be shown, you would have to be root to see it all.)
      tcp6       0      0 ::1:8080                :::*                    LISTEN      67920/electron.js
      tcp6       0      0 ::1:8080                ::1:54378               TIME_WAIT   -
      tcp6       0      0 ::1:8080                ::1:57896               TIME_WAIT
      Thank you for your tips :-)
        sdetweil @Klinge
        @Klinge see this issue on dwd-pollen
        https://github.com/carstendirks/MMM-DWD-Pollen/issues/10
        and this on mmm-pollen
        https://github.com/vincep5/MMM-Pollen/issues/4
        K 1 Reply Last reply
        • K
          Klinge @sdetweil
          @sdetweil Thank you again.
          I thought, that default will display all pollen. It seems not.
          But now it is running.
          • K Klinge has marked this topic as solved on
