    Magic Mirror - Auto-Update ?
    9 Posts 2 Posters 1.5k Views 2 Watching
      rkorell Module Developer
      Dear team,
      my MagicMirror ran stable for a pretty good time.
      Now - for some unknown reasons - the icons (custom SVG files) for the standard weather module forecast becomes really tiny so nearly invisible.
      I do not made any changes in the last past days. (really. :-) !)
      Because it’s related to a “standard” module here my question: Is the mirror updating by himself?
      And if this is the case - how can I avoid this?
      Thanks a LOT for any idea.
      Regards,
      Ralf
        @sdetweil said > which class caused the smaller size?
        Dear Sam,
        don’t know!
        have experimented a while to change several parameters in the developer’s console who could be associated with the size but none of my trials caused any visible change.
        At least I could figure out (by the association with the filename) which CSS element is representing the icon.
        This is (in my case)
        .weather_forecast .weathericon
        (I’ve (as many users) two instances of the weather module and gave them a classes definition to handle CSS for both instances different. In the Forecast instance (class weather_forecast) are the described symptoms located)
        I’ve played around and have done some research and came to the conclusion that height could be the appropriate attribute.
        For this reason I’ve added
        .weather_forecast .weathericon  {
        height: 30px;
        to my custom.css and this exactly does the trick.
        Where the “overnight” changes comes from - I have absolutely no idea and - see above - couldn’t even figure out any “change” …
        Sorry for this.
        • May I’m to dumb to figure it out …
        Thanks a lot, anyway.
        Warmest regards,
        Ralf
          sdetweil @rkorell
          @rkorell MagicMirror will not autoupdate
          there was some code added to the updateNotifications module, to support some tool to update modules i think. that tool doent exist yet
          if you are using pm2, those events should be recorded in the logs
          have you tried restarting MagicMirror?
            Dear Sam, yes I’ve restarted the mirror several times, no effect.
            Thanks to second link in your signature I was able to identify the CSS topic which addresses the size of the icon - but this was not neccessary earlier - worked without this.
            IS there an auto-update mechanism?
            (this would be bad…)
            Regards,
            Ralf
              sdetweil @rkorell
              @rkorell said in Magic Mirror - Auto-Update ?:
              no… I am strongly against that… given the issues users encounter on nearly every update
                @sdetweil OK, good news.
                Then I’m really asking what happened to cause the described changes on my mirror.
                It’s obviously “magic” again :-)
                Regards,
                Ralf
                  sdetweil @rkorell
                  @rkorell so you updated custom.css
                  in the developers window , which class caused the smaller size? and where was it sourced from ( the file name is shown too)
                    Dear Sam,
                    don’t know!
                    height: 30px;
                    Sorry for this.
                    Warmest regards,
                    Ralf
                      sdetweil @rkorell
                      @rkorell css is a challenging area. trying to figure out what overrides what when.
                      glad you have a solution.
                      thanks for your feedback
                        @sdetweil THANKS to YOU for your huge effort here in this place!
                        Ralf
                        • R rkorell has marked this topic as solved on
