Voice assistant
 Can anyone recommend me voice assistant module that works on raspberry Pi 3
 @notgood i’d look thru the third party modules list, linked above what do you want this voice assistant to do? Amazon has pretty much killed software based Alexa services
 see https://forum.magicmirror.builders/topic/16069/alexa-implementations-now-more-difficult-and-some-features-will-stop-workingand there is currently not a Google Assistant or Apple Home
 interface
 Putting an echo dot behind the mirror was a lot less headache then trying to get any Alexa modules working…
 @cyberphox yes AlexaControl module helps.
 @notgood I use the nodred alexa skill to configure alexa devices for my HomeAssistant devices, and automations. (devices connected wth mqtt via zigbee controller, and zigbee2mqtt docker container)
 @sdetweil hi thank you for replying,is there way I can with on this forum like direct message, I wanted to ask some doubts about mm
 @cyberphox i do have echo dot but it’s speaker not working properly,Thank you for replying
 @notgood there is chat, under a users profile
S sdetweil has marked this topic as solved on
