    How do I display an RTSP camera stream?
    16 Posts 4 Posters 4.6k Views 4 Watching
      SteveMann
      Thanks for the info. Perhaps I was using the wrong search term. I was looking for RTSP here:
      https://github.com/MagicMirrorOrg/MagicMirror/wiki/3rd-party-modules
      Is there a better place to search for Modules?
      My home office has no window facing the front of my house and I had been using a tablet running a browser to watch the stream, but MagicMirror is shaping up to be a better solution.
      Is this another rabbit hole? (Home Assistant was the first). I am already planning my next MM location…
      • BKeyportB Offline
        BKeyport Module Developer @SteveMann
        @SteveMann RTSP isn’t directly compatible with MagicMirror. The only solution I ever found to work, and what I’ve stuck with, is load up an old Pi 4 with MotionEyeOS - and use that to convert over to web, then use something like MMM-EmbedURL to show the stream provided by MotionEye.
          sdetweil @SteveMann
          @SteveMann in the header here
            SteveMann @BKeyport
            @BKeyport said in How do I display an RTSP camera stream?:
            Thanks for the tip, but I don’t see how MotionEye would serve my cameras RTSP stream?
            • BKeyportB Offline
              @SteveMann MotionEyeOS will take in the RTSP stream and push out a web compatible stream. At that point, you can take MMM-Embed URL and show the stream. I use the older non-supported MotionEyeOS because the newer versions of MotionEye don’t want to work reliably yet in the way I want.
              My motion eye settings - note, I have the low setting in use to save the Pi4 from working too hard:
              the embed URL is http://192.168.X.X/picture/1/frame/
              			module: "MMM-EmbedURL",
              			classes: "camera1",
              				updateInterval: 0,
              				animationSpeed: 0,
              				appendTimestamp: false,
              				attibutes: [],
              				embed: [
              					"http://192.168.X.X/picture/1/frame/"
                SteveMann @BKeyport
                @BKeyport
                I always thought that MotionEyeOS was a DVR for webcams.
                Thanks for the feedback. I know what I will be doing tonight.
                Today I’ve been experimenting with mplayer and VLC on the Pi (not on MagicMirror), and no matter what I do the stream freezes after a few minutes. I know that the camera stream is still streaming because I see it on Frigate on a separate PC.
                Could it be as simple as the Pi3 running out of resources?
                • BKeyportB Offline
                  @SteveMann Pi3 is likely being choked to death with that. It’s hard on the Pi4. If I could get it to run the way I wanted on a Pi 5, I’d upgrade to that myself.
                    SteveMann @BKeyport
                    I wanted to try MotionEyeOS, but I can’t find anything recent. The git was archived five years ago and the only binary that I could find was for the Pi2. Is there a supported version somewhere that I’ve missed?
                    • BKeyportB Offline
                      @SteveMann That’s the rough part - the original author abandoned the project - and they’re rebuilding…
                      https://github.com/motioneye-project/motioneyeos/releases - use the pi image there to get started - will work on everything up to Pi 4. Does not work on Pi 5.
                      • H Offline
                        hrmax23
                        Also looking to stream a camera feed from Frigate. It looks like MMM-FreeboxTV would have worked but can’t find that anywhere.
