    Version 2.30.0 weather module, stuck loading, worked fine before upgrade
    52 Posts 6 Posters 33.8k Views 7 Watching
      sdetweil @Richard238
      @Richard238 all config goes in config.js
      Never need to edit any other file
      R 1 Reply Last reply
        Richard238 @sdetweil
        openweathermap.js is unchanged
        WeatherProvider.register("openweathermap", {
        	providerName: "OpenWeatherMap",
        	// Set the default config properties that is specific to this provider
        	defaults: {
        		apiVersion: "3.0",
        		apiBase: "https://api.openweathermap.org/data/",
        		// weatherEndpoint is "/onecall" since API 3.0
        		// "/onecall", "/forecast" or "/weather" only for pro customers
        		weatherEndpoint: "/onecall",
        		locationID: false,
        		// the /onecall endpoint needs lat / lon values, it doesn't support the locationId
        		lat: 0,
        		lon: 0,
        		apiKey: ""
        config.js shows
        		module: 'weather',
        		header: 'Current zzzzzzzzzzzzzzzz  weather: ',
        		position: 'top_right',
        			//weatherProvider: "openweathermap",
        			type: "current",
        			lat: nnnnnnnnnnn,
        			lon: -nnnnnnnnnnnnn,
        			apiKey: "aaaaaaaaaaaaaaaaaaaaaaaaaaa"
        			//type: 'current',
        			//location: 'xxxxxxxxxxxxxx',
        			//locationID: 'zzzzzzzz',  //ID from https://www.openweathermap.org
        			//apiKey: 'aaaaaaaaaaaaaaaaaaaaaaaaaaa'
          @Richard238
          providerName: “OpenWeatherMap”
          That is not the correct property name
          From the doc
          https://docs.magicmirror.builders/modules/weather.html#usage
            With no caps? Still doesn’t work.
              @Richard238 again show the whole config, xxx out the api key
              Start w
              position
              and config
              provider
              type ( default is current)
              apikey
              lat
              lon
              the 3.0 apikey requires a credit card backing, right?
                			module: 'weather',
                			header: 'Current zzzzzzzzzzzzz  weather: ',
                				lat: 111111111111111,
                				lon: 1111111111111111111111,
                				apiKey: "aaaaaaaaaaaaaaaaaaaaaaaaaaaaaa",
                				type: 'current',
                				units: 'config.units'
                				//location: 'zzzzzzzzzzzzzzz',
                I must have had that API key for aeons, don’t ever remember it having a c/card behind it.
                Maybe it’s out-of-date.
                  @Richard238 yes they told us the old free api was being terminated. only the new api exists, so we changed the defaults
                  but other users have reported the 2.5 apikey still works
                  see the 1st post on this topic
                    Rberry91 @sdetweil
                    @sdetweil hi Sam,
                    I have added a credit card and added the extra codes from the article and it doesn’t load.20250308_055711.jpg
                      sdetweil @Rberry91
                      @Rberry91 if you have the 3.0 apikey you dont add any extra parms
                      just type, apikey, lat and lon
                        Rberry91 @sdetweil
                        It still says invalid date
                        Sorry so many questions
                          sdetweil @Rberry91
                          @Rberry91 open the developers window, ctrl-shift-i,
                          select the console tab,
                          and enter weath in the filter field
                          do you see errors? like 401, 403
                            Rberry91 @sdetweil
                              sdetweil @Rberry91
                              @Rberry91 401 means the apikey is invalid
                                Rberry91 @sdetweil
                                Hi Sam,
                                So I got it to work however the header is Australia/Brisbane, which is not correct. But the weather details are correct, how do I change the name of the header. I have added location and locationID
                                  sdetweil @Rberry91
                                  @Rberry91 v3 does not return the right location,
                                  location/id are not used in v3, only lat/lon
                                  use the module header property
                                  module:…
                                  header:“…”
                                  the set the weather config option
                                  appendLocationToHeader:false,
                                    Rberry91 @sdetweil
                                    Hi Sam,
                                    Now I have an message to update the MMM-GooglePhotos module. How do I do that without causing problems like before. I did try your code and it didn’t seem to work but I am most likely doing something incorrect
                                      sdetweil @Rberry91
                                      @Rberry91 didnt try my code? i do not supply anything that will update modules.
                                      my upgrade script is only for base MagicMirror
                                      every module upgrade is the same
                                      cd ~/MagicMirror/modules/modulename
                                      git pull
                                      xxx see the module doc on what to do after
                                      sometimes you need an npm install, sometimes not
                                        Rberry91 @sdetweil
                                        Hi again,
                                        The MMM- GoohlePhotos was not updating so I re installed and am know getting a error of missing creditionals please help20250313_050643.jpg
                                          sdetweil @Rberry91
                                          @Rberry91 now you have to follow the module instructions to get authorization again
                                            Rberry91 @sdetweil
                                            I reverted to the older version and I have tried updating using your command and other ones and still doesn’t update tell me that “pulling without specifying how to reconcile divergent branches is etc”
                                            The other problem I am having is the weather, the forecast works but the current Weather doesn’t and they are the same code.20250313_055015.jpg 20250313_055058.jpg
                                            • 2 / 3
