    Version 2.30.0 weather module, stuck loading, worked fine before upgrade
    52 Posts 6 Posters 35.0k Views 7 Watching
      sdetweil @Rberry91
      @Rberry91 if you have the 3.0 apikey you dont add any extra parms
      just type, apikey, lat and lon
      R 1 Reply Last reply
        Rberry91 @sdetweil
        It still says invalid date
        Sorry so many questions
          sdetweil @Rberry91
          @Rberry91 open the developers window, ctrl-shift-i,
          select the console tab,
          and enter weath in the filter field
          do you see errors? like 401, 403
            Rberry91 @sdetweil
              sdetweil @Rberry91
              @Rberry91 401 means the apikey is invalid
                Rberry91 @sdetweil
                Hi Sam,
                So I got it to work however the header is Australia/Brisbane, which is not correct. But the weather details are correct, how do I change the name of the header. I have added location and locationID
                  sdetweil @Rberry91
                  @Rberry91 v3 does not return the right location,
                  location/id are not used in v3, only lat/lon
                  use the module header property
                  module:…
                  header:“…”
                  the set the weather config option
                  appendLocationToHeader:false,
                    Rberry91 @sdetweil
                    Hi Sam,
                    Now I have an message to update the MMM-GooglePhotos module. How do I do that without causing problems like before. I did try your code and it didn’t seem to work but I am most likely doing something incorrect
                      sdetweil @Rberry91
                      @Rberry91 didnt try my code? i do not supply anything that will update modules.
                      my upgrade script is only for base MagicMirror
                      every module upgrade is the same
                      cd ~/MagicMirror/modules/modulename
                      git pull
                      xxx see the module doc on what to do after
                      sometimes you need an npm install, sometimes not
                        Rberry91 @sdetweil
                        Hi again,
                        The MMM- GoohlePhotos was not updating so I re installed and am know getting a error of missing creditionals please help20250313_050643.jpg
                          sdetweil @Rberry91
                          @Rberry91 now you have to follow the module instructions to get authorization again
                            Rberry91 @sdetweil
                            I reverted to the older version and I have tried updating using your command and other ones and still doesn’t update tell me that “pulling without specifying how to reconcile divergent branches is etc”
                            The other problem I am having is the weather, the forecast works but the current Weather doesn’t and they are the same code.20250313_055015.jpg 20250313_055058.jpg
                              sdetweil @Rberry91
                              @Rberry91 divergent branches sounds like you have both modules trying to merge to the same folder
                              delete then git clone again
                              the nan says the apikey is wrong
                              and you have a typo, MagicMirror is case sensitive
                              • butchkemperB
                                butchkemper
                                The configuration parameters I use are:
                                module "MMM-OpenWeatherForecase"
                                latitude and NOT lat
                                longitude and NOT lon
                                apikey and NOT apiKey   <----  Notice the "K"
                                Some MM configuration keywords have abbreviations but not all. The module README file gives the values for the keywords.
                                Also, since your apikey has been revealed to the world, you should cancel the posted key and generate a new key. Always keep the apikey secret.
                                Butch
                                Resistance is not Futile!
                                It is voltage divided by current.
                                • butchkemperB
                                  butchkemper
                                  @sdetweil I noticed this discretion between the Weather module documentation:
                                  • The “Weather” documentation has “apiKey” - large case “K”,
                                  • The “MMM-OpenWeatherForecast” documentation has “apikey” - small case “k”.
                                  Butch
                                    sdetweil @butchkemper
                                    @butchkemper modules can go anything they want
                                    what is used internally can be anything required
                                    I looked at the doc for the default weather module before posting above. as there are two instances, one works the other doesn’t. apikey is the issue
                                    • S sdetweil marked this topic as a regular topic on
                                    • AssassinsA
                                      Assassins
                                      Work on 2.29.0 with api2.5
                                      But now on 2.33.0
                                      It say “NaN”
                                      I get the error 401, it say the apiKey i wrong, but is write from my api key from the website.
                                      How can i get a apiKey to api3.0 without to paid for it. ???
                                      The api2.5 still work, but not on this modul.
                                            module: 'weather',
                                            position: 'bottom_left',
                                            header: 'Ballerup',
                                               lat: "55.7317",
                                               lon: "12.3633",
                                               apiKey: "xxxxx765xxxx98xxxjhx888"
                                        sdetweil @Assassins
                                        @Assassins you cannot get V3 apikey from open weather without providing a credit card.
                                        they don’t charge unless you go over 1000/request per day.
                                        now, you CAN make 2.5 work (if they still accept api requests they keep telling us they are going to do (have done!!)) just be warned that they can/will end this function sometime…
                                        in the module config section
                                        apiKey: 2.5_key
                                        apiVersion: 2.5
                                        and
                                        weatherEndpoint: “current” OR “forecast”
                                        edited
                                        AssassinsA 1 Reply Last reply
                                        • AssassinsA
                                          Assassins @sdetweil
                                          I can only see the header now, where is write Ballerup
                                            module: 'weather',
                                            header: 'Ballerup',
                                              apiVersion: "2.5",
                                              weatherEndpoint: "/current",
                                               lat: "55.7317",
                                               lon: "12.3633",
                                            sdetweil @Assassins
                                            @Assassins
                                            sorry
                                            weatherEndpoint: “current” or 'forecast" , no /
                                            also, the old api use location or locationID, not lat/lon
                                            and I see you can’t look them up anymore on OWM site
                                            here is from the old doc
                                            locationID	Location ID from OpenWeatherMap This will override anything you put in location.
                                            Leave blank if you want to use location. <------=======
                                            Example: 1234567
                                            Default value: false
                                            Note: When the location and locationID are both not set, the location will be based on the information provided by the calendar module. The first upcoming event with location data will be used.
                                            location	The location used for weather information.
                                            Example: 'Amsterdam,Netherlands'
                                            so it ‘seems’ that location by itself would do it.
                                            • 2 / 3
