    MMM-update - Please help beginner and need help
    17 Posts 2 Posters 5.4k Views 2 Watching
      sdetweil @Rberry91
      @Rberry91 yes, the npm install failed, probably cause you have the wrong nodejs version
      node -v
      the release notes say 20.18.1 or higher
      not any node 21
      if you had used my upgrade script it would have handled that
      R 1 Reply Last reply
        Rberry91 @sdetweil
        Hi Sam,
        Yes reading other articles I definitely should have used yours and will be from now on.
        Is there a way to fix it? Are you able to tell me a script to use.
          sdetweil @Rberry91
          @Rberry91 run the upgrade script with
          force
          as the parameter
            Rberry91 @sdetweil
            Is that just force at the end
            So
            bash -c “$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)” force
              sdetweil @Rberry91
              @Rberry91 correct
              R 3 Replies Last reply
                Rberry91 @sdetweil
                Thank you so much it worked 😃
                  Rberry91 @sdetweil
                  Hi Sam,
                  Unfortunately when I run the magic mirror I am now getting invalid date for my weather?
                  Would you be able to help?
                    Rberry91 @sdetweil
                    S 3 Replies Last reply
                      sdetweil @Rberry91
                      @Rberry91 the openweather apikey is defaulted to version 3
                      which requires a credit card
                        sdetweil @Rberry91
                        @Rberry91 also see
                        https://forum.magicmirror.builders/topic/19323/version-2-30-0-weather-module-stuck-loading-worked-fine-before-upgrade
                          sdetweil @Rberry91
                          @Rberry91 did you fix this?
