    MMM-update - Please help beginner and need help
    17 Posts 2 Posters 5.4k Views 2 Watching
      Rberry91 @sdetweil
        sdetweil @Rberry91
        @Rberry91 yes, the npm install failed, probably cause you have the wrong nodejs version
        node -v
        the release notes say 20.18.1 or higher
        not any node 21
        if you had used my upgrade script it would have handled that
        R 1 Reply Last reply
          Rberry91 @sdetweil
          Hi Sam,
          Yes reading other articles I definitely should have used yours and will be from now on.
          Is there a way to fix it? Are you able to tell me a script to use.
            sdetweil @Rberry91
            @Rberry91 run the upgrade script with
            force
            as the parameter
              Rberry91 @sdetweil
              Is that just force at the end
              So
              bash -c “$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)” force
                sdetweil @Rberry91
                @Rberry91 correct
                R 3 Replies Last reply
                  Rberry91 @sdetweil
                  Thank you so much it worked 😃
                    Rberry91 @sdetweil
                    Hi Sam,
                    Unfortunately when I run the magic mirror I am now getting invalid date for my weather?
                    Would you be able to help?
                      Rberry91 @sdetweil
                      S 3 Replies Last reply
                        sdetweil @Rberry91
                        @Rberry91 the openweather apikey is defaulted to version 3
                        which requires a credit card
                          sdetweil @Rberry91
                          @Rberry91 also see
                          https://forum.magicmirror.builders/topic/19323/version-2-30-0-weather-module-stuck-loading-worked-fine-before-upgrade
                            sdetweil @Rberry91
                            @Rberry91 did you fix this?
