    message Remote Control
    18 Posts 2 Posters 3.7k Views 2 Watching
      pat59
      Hello
      Sorry ,but l forgot to mention that this is a second mirror ,not the one you repaired for me .
      l tried your instruction, but it doen’t reboot .
      module: “updatenotification”,
      position: “”,
      ignoreModules: [‘MMM-Remote-Control’]
      updateAutorestart: true, // restart MagicMirror automaticaly after update
      updates: [
      // MMM-MeteoFrance rule
      “MMM-MeteoFrance”: “npm run update”
        sdetweil @pat59
        @pat59
        position: “”,
        yes, this is invalid
        i put that line there to make sure you understood where the following lines should be. not to indicate exact text
        you have to learn how to debug and resolve these kinds of issue
        1st thing is to look at the logs, as you use pm2 to autolaunch MagicMirror
        that is
        pm2 logs --lines=xxxx
        where xxxx is some number, default 15
          pat59
          Okay, thanks, I’ll look at it again, thanks.
            sdetweil @pat59
            @pat59 did you find and fix the problem?
              pat59
              Good evening.
              No, I haven’t found anything. I’ve searched extensively and tried for 5 hours, but to no avail.
              I tried this: /{
              / It doesn’t work. I went to the forum and tried some things in js.conf.
              This morning, I turned on the one you fixed for me, and the update message came back. I’ll continue using it. Thanks again for your message.
                sdetweil @pat59
                @pat59 can you do this
                From a terminal window
                pm2 stop all
                npm start &>somefile.txt
                The post the contents of somefile.txt
                  pat59
                  Thank you, it works.
                  I was far from finding this. Thanks again for everything.
                  Sincerely,
                    pat59
                    I spoke too quickly after performing the manipulation it restarts by itself no more messages however once I restart the raspberry the message reappears.
                    In the message it tells me https://github.com Username
                      sdetweil @pat59
                      @pat59 said in message Remote Control:
                      in the message it tells me https://github.com Username
                      sorry, I don’t understand that text
                      as I said, you have to disable the updateNotification module
                        module: "updatenotification",
                        disabled: true,
                      OR
                      you have to list the modules to ignore
                         module:"updatenotification",
                         position: whatever it is,
                           ignoreModules:["MMM-Remote-Control"]
                      these messages in the pm2 log
                      [2025-03-14 20:51:34.981] [INFO]  Checking git for module: MMM-MealieMenu
                      [2025-03-14 20:51:35.028] [INFO]  Checking git for module: MMM-pages
                      [2025-03-14 20:51:35.070] [INFO]  Checking git for module: MMM-CurlToNotification
                      are from the updateNotification module checking each module not ignored
                        pat59
                        disabled :true,
                        position: "top_center",
                          ignoreModules:["MMM-Remote-Control"],
                          updates: [
                              "MMM-MeteoFrance": "npm run update"
                        the message is still there , l don't know anymotre after several attempts to modify the js config
