message Remote Control
18 Posts 2 Posters 1.9k Views 2 Watching
    pat59
    How can I remove this update message without doing it? I did it and had to contact Mr. SDETWEIL because my Mirror stopped working. He fixed it, thank you.20250312_091938.jpg
    S 1 Reply Last reply Mar 12, 2025, 12:38 PM Reply Quote 0
      pat59
      Yes, I systematically restart after each change in js.
      Well, you did find that there were indeed two update notifications in config.js.
      Something I would never have thought of after making the change in the second update notification in config.js. This one works, no more messages, even though I spent hours solving a lesson in restraint. Thanks again.
      S 1 Reply Last reply Mar 16, 2025, 2:29 PM Reply Quote 0
      • S Away
        sdetweil @pat59
        @pat59 this is caused by the updatenotification module
        as we just installed a fresh copy, i dont understand why this is showing again
        so you have 2 choices
        disable the updatenotification module in config.js
        module:"updatenotification",
        disabled:true,
        or
        add the MMM-Remote-Control module to the updateNotification ignore list
        module:"updatenotification".
        position:"...."
        config:{
          ignoreModules:['MMM-Remote-Control']
          pat59
          Hello
          Sorry ,but l forgot to mention that this is a second mirror ,not the one you repaired for me .
          l tried your instruction, but it doen’t reboot .
          module: “updatenotification”,
          position: “”,
          ignoreModules: [‘MMM-Remote-Control’]
          updateAutorestart: true, // restart MagicMirror automaticaly after update
          updates: [
          // MMM-MeteoFrance rule
          “MMM-MeteoFrance”: “npm run update”
          S 1 Reply Last reply Mar 12, 2025, 1:32 PM Reply Quote 0
          • S Away
            sdetweil @pat59
            @pat59
            position: “”,
            yes, this is invalid
            i put that line there to make sure you understood where the following lines should be. not to indicate exact text
            you have to learn how to debug and resolve these kinds of issue
            1st thing is to look at the logs, as you use pm2 to autolaunch MagicMirror
            that is
            pm2 logs --lines=xxxx
            where xxxx is some number, default 15
              pat59
              Okay, thanks, I’ll look at it again, thanks.
              S 1 Reply Last reply Mar 14, 2025, 3:36 PM Reply Quote 0
              • S Away
                sdetweil @pat59
                @pat59 did you find and fix the problem?
                  pat59
                  Good evening.
                  No, I haven’t found anything. I’ve searched extensively and tried for 5 hours, but to no avail.
                  I tried this: /{
                  / It doesn’t work. I went to the forum and tried some things in js.conf.
                  This morning, I turned on the one you fixed for me, and the update message came back. I’ll continue using it. Thanks again for your message.
                  S 1 Reply Last reply Mar 14, 2025, 8:01 PM Reply Quote 0
                  • S Away
                    sdetweil @pat59
                    @pat59 can you do this
                    From a terminal window
                    pm2 stop all
                    npm start &>somefile.txt
                    The post the contents of somefile.txt
                      pat59
                      Thank you, it works.
                      I was far from finding this. Thanks again for everything.
                      Sincerely,
                        pat59
                        I spoke too quickly after performing the manipulation it restarts by itself no more messages however once I restart the raspberry the message reappears.
                        In the message it tells me https://github.com Username
                        S 1 Reply Last reply Mar 15, 2025, 4:24 AM Reply Quote 0
