message Remote Control
@pat59 can you do this
From a terminal window
pm2 stop all cd ~/MagicMirror npm start &>somefile.txtThe post the contents of somefile.txt
Thank you, it works.
I was far from finding this. Thanks again for everything.
Sincerely, -
I spoke too quickly after performing the manipulation it restarts by itself no more messages however once I restart the raspberry the message reappears.
In the message it tells me https://github.com Username -
@pat59 said in message Remote Control:
in the message it tells me https://github.com Username
sorry, I don’t understand that text
as I said, you have to disable the updateNotification module
{ module: "updatenotification", disabled: true, }OR
you have to list the modules to ignore{ module:"updatenotification", position: whatever it is, config: { ignoreModules:["MMM-Remote-Control"] } }these messages in the pm2 log
[2025-03-14 20:51:34.981] [INFO] Checking git for module: MMM-MealieMenu [2025-03-14 20:51:35.028] [INFO] Checking git for module: MMM-pages [2025-03-14 20:51:35.070] [INFO] Checking git for module: MMM-CurlToNotificationare from the updateNotification module checking each module not ignored
module: "updatenotification", disabled :true, position: "top_center", config: { ignoreModules:["MMM-Remote-Control"], updateAutorestart: true, // restart MagicMirror automaticaly after update updates: [ // MMM-MeteoFrance rule { "MMM-MeteoFrance": "npm run update" }, ] } }, { the message is still there , l don't know anymotre after several attempts to modify the js config -
@pat59 and you restarted MagicMirror after changing config?
can you show the screen again?
are there multiple instances of updatenotification in the config.js? -
Yes, I systematically restart after each change in js.
Well, you did find that there were indeed two update notifications in config.js.
Something I would never have thought of after making the change in the second update notification in config.js. This one works, no more messages, even though I spent hours solving a lesson in restraint. Thanks again. -
@pat59 great work…
The excellent work is partly due to your patience, thank you for everything, I am so happy.
@pat59 I think you should try my MMM-Config module, as you continue to have problems with config.js
https://github.com/sdetweil/MMM-Config
this will present a form for the system and module properties.
it will also support adding modules too…
it will also show you when you have multiple instances…
S sdetweil has marked this topic as solved on
Hello
Thank you, I’ll try. Thank you. Have a nice day.
