    MMM-MPlayer - display issue
    3 Posts 1 Posters 623 Views 1 Watching
    • evroomE Offline
      evroom
      I have this issue with MMM-MPlayer, that also has been reported by other users of the module.
      When using the module, the MPlayer window is seen in the middle of the screen and has a MPlayer title.
      This is what is running when using the module:
      admin@MagicPi3b:~/MagicMirror/modules/MMM-MPlayer $ ps -eaf | grep mplayer | grep -v grep
      admin 38919 38729 18 12:17 ? 00:00:01 mplayer -monitoraspect 0  -noborder -vf rotate=-1 -geometry 10:225 -xy 640 -rtsp-stream-over-tcp -vo xv,gl,gl_nosw,vdpau, -nosound rtsp://axisviewer:password@192.168.178.55/axis-media/media.amp?streamprofile=ACC_Low
      The value of DISPLAY is: :0
      When I run the same command like this, it is working as expected:
      admin@MagicPi3b:~/MagicMirror/modules/MMM-MPlayer $ DISPLAY=:0 mplayer -monitoraspect 0  -noborder -vf rotate=-1 -geometry 10:225 -xy 640 -rtsp-stream-over-tcp -vo xv,gl,gl_nosw,vdpau, -nosound rtsp://axisviewer:password@192.168.178.55/axis-media/media.amp?streamprofile=ACC_Low
      The MMM-MPlayer module uses this to start mplayer:
          const env = { ...process.env, DISPLAY: ':0' };
          const mplayerProcess = spawn(`mplayer`,
             [`${mplayerOption}`, `${mplayerOptionValue}`,
              `${stream}`],
              {env: env});
      I cannot get my finger behind this and I have no idea why this happens like this.
      Any ideas ?
      MagicMirror version: 2.33.0
      Test environment:
      MagicMirror version: v2.33.0
      • evroomE evroom referenced this topic on
      • evroomE Offline
        evroom @evroom
        To answer myself:
        I cleaned the array using:
            const mplayerArgumentsArrayFilter = mplayerArgumentsArray.filter(discardEmptyArgument);
            function discardEmptyArgument(value, index, array) {
              return value != '';
        Then spawned using that array:
            // Spawn a new mplayer process
            const mplayerProcess = spawn(`mplayer`, mplayerArgumentsArrayFilter, {env: env});
        Now it is working correct.
        Test environment:
        • evroomE Offline
          evroom @evroom
          I found out following:
          When using
                 ['-rtsp-stream-over-tcp',
                  '-noborder',
                  '-monitoraspect', '0',
                  '-vf', 'rotate=-1',
                  '-geometry', '5:225',
                  '-x', '640',
                  '-y', '360',
                  'rtsp://axisviewer:password@192.168.178.55/axis-media/media.amp?streamprofile=ACC_Low'],
                  {env: env});
          The stream is correct on the monitor.
          When using
                  '-noborder',
                  '-vf', 'rotate=-1',
                  '-x', '640',
                  '-y', '360',
                  {env: env});
          The stream is NOT correct on the monitor (MPlayer window in the center).
          So the problem is spawning with empty parameters.
          When running it from the command line, this is not an issue, as the shell takes care of the empty places between the arguments.
          I tried with undefined and null iso ''but that does not work.
          Only idea how to solve this ?
          Cleaning the array somehow ?
          Test environment:
          • evroomE Offline
            evroom @evroom
            To answer myself:
                  return value != '';
            Test environment:
            • evroomE evroom has marked this topic as solved on
