    Magic Mirror with Pi4 OS not working with Pi5
    30 Posts 4 Posters 11.3k Views 4 Watching
    • T
      TomOMaley
      That is what I get with pm2 logs --lines=20.
      [TAILING] Tailing last 20 lines for [all] processes (change the value with --lines option)
      /home/pi5/.pm2/pm2.log last 20 lines:
      PM2 | 2025-03-17T20:06:56: PM2 log: Concurrent actions : 2
      PM2 | 2025-03-17T20:06:56: PM2 log: SIGTERM timeout : 1600
      PM2 | 2025-03-17T20:06:56: PM2 log: ===============================================================================
      PM2 | 2025-03-17T20:06:56: PM2 log: App [mm:0] starting in -fork mode-
      PM2 | 2025-03-17T20:06:56: PM2 log: App [mm:0] online
      PM2 | 2025-03-17T20:57:48: PM2 log: Stopping app:mm id:0
      PM2 | 2025-03-17T20:57:49: PM2 log: App [mm:0] exited with code [0] via signal [SIGINT]
      PM2 | 2025-03-17T20:57:49: PM2 log: pid=1128 msg=process killed
      PM2 | 2025-03-17T20:57:49: PM2 log: App [mm:0] starting in -fork mode-
      PM2 | 2025-03-17T20:57:49: PM2 log: App [mm:0] online
      PM2 | 2025-03-17T21:16:19: PM2 log: Stopping app:mm id:0
      PM2 | 2025-03-17T21:16:19: PM2 log: App [mm:0] exited with code [0] via signal [SIGINT]
      PM2 | 2025-03-17T21:16:19: PM2 log: pid=3621 msg=process killed
      PM2 | 2025-03-17T21:16:19: PM2 log: App [mm:0] starting in -fork mode-
      PM2 | 2025-03-17T21:16:19: PM2 log: App [mm:0] online
      PM2 | 2025-03-17T21:20:13: PM2 log: Stopping app:mm id:0
      PM2 | 2025-03-17T21:20:13: PM2 log: App [mm:0] exited with code [0] via signal [SIGINT]
      PM2 | 2025-03-17T21:20:13: PM2 log: pid=4540 msg=process killed
      PM2 | 2025-03-17T21:20:13: PM2 log: App [mm:0] starting in -fork mode-
      PM2 | 2025-03-17T21:20:13: PM2 log: App [mm:0] online
      /home/pi5/.pm2/logs/mm-error.log last 20 lines:
      0|mm | [5164:0317/212015.666827:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: Datei oder Verzeichnis nicht gefunden (2)
      0|mm | [5164:0317/212015.666942:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: Datei oder Verzeichnis nicht gefunden (2)
      0|mm | [5164:0317/212015.667063:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: Datei oder Verzeichnis nicht gefunden (2)
      0|mm | [5164:0317/212015.667127:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: Datei oder Verzeichnis nicht gefunden (2)
      0|mm | [5164:0317/212015.669483:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: Datei oder Verzeichnis nicht gefunden (2)
      0|mm | [5164:0317/212015.671772:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: Datei oder Verzeichnis nicht gefunden (2)
      0|mm | [5164:0317/212015.672140:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: Datei oder Verzeichnis nicht gefunden (2)
      0|mm | [5164:0317/212015.672271:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: Datei oder Verzeichnis nicht gefunden (2)
      0|mm | [5164:0317/212015.672606:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: Datei oder Verzeichnis nicht gefunden (2)
      0|mm | [5164:0317/212015.672981:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: Datei oder Verzeichnis nicht gefunden (2)
      0|mm | [5164:0317/212015.673132:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: Datei oder Verzeichnis nicht gefunden (2)
      0|mm | [5164:0317/212015.674044:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: Datei oder Verzeichnis nicht gefunden (2)
      0|mm | [5164:0317/212015.674213:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: Datei oder Verzeichnis nicht gefunden (2)
      0|mm | [5164:0317/212015.674280:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: Datei oder Verzeichnis nicht gefunden (2)
      0|mm | [5164:0317/212015.674369:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: Datei oder Verzeichnis nicht gefunden (2)
      0|mm | [5164:0317/212015.674413:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: Datei oder Verzeichnis nicht gefunden (2)
      0|mm | [5164:0317/212015.674498:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: Datei oder Verzeichnis nicht gefunden (2)
      0|mm | [5164:0317/212015.674546:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: Datei oder Verzeichnis nicht gefunden (2)
      0|mm | [5164:0317/212015.674644:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: Datei oder Verzeichnis nicht gefunden (2)
      0|mm | [5164:0317/212015.674691:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: Datei oder Verzeichnis nicht gefunden (2)
      /home/pi5/.pm2/logs/mm-out.log last 20 lines:
      0|mm | [2025-03-17 21:20:15.575] [LOG] Connecting socket for: MMM-MoonPhase
      0|mm | [2025-03-17 21:20:15.575] [LOG] Starting module helper: MMM-MoonPhase
      0|mm | [2025-03-17 21:20:15.575] [LOG] Connecting socket for: MMM-FroniusSolar2
      0|mm | [2025-03-17 21:20:15.576] [LOG] Connecting socket for: MMM-text-clock
      0|mm | [2025-03-17 21:20:15.576] [LOG] Starting module helper: MMM-text-clock
      0|mm | [2025-03-17 21:20:15.577] [LOG] Connecting socket for: mmm-systemtemperature
      0|mm | [2025-03-17 21:20:15.579] [LOG] Starting node helper: mmm-systemtemperature
      0|mm | [2025-03-17 21:20:15.580] [LOG] Sockets connected & modules started …
      0|mm | [2025-03-17 21:20:15.697] [LOG] Launching application.
      0|mm | [2025-03-17 21:20:16.212] [INFO] System information:
      0|mm | ### SYSTEM: manufacturer: Raspberry Pi Foundation; model: Raspberry Pi 5 Model B Rev 1.1; virtual: false
      0|mm | ### OS: platform: linux; distro: Debian GNU/Linux; release: 12; arch: arm64; kernel: 6.6.74+rpt-rpi-2712
      0|mm | ### VERSIONS: electron: 32.3.3; used node: 20.18.1; installed node: 20.18.1; npm: 10.8.2; pm2: 5.4.3
      0|mm | ### OTHER: timeZone: Etc/GMT-1; ELECTRON_ENABLE_GPU: undefined
      0|mm | [2025-03-17 21:20:16.814] [INFO] Checking git for module: calendar_monthly
      0|mm | [2025-03-17 21:20:16.829] [INFO] Checking git for module: MMM-MoonPhase
      0|mm | [2025-03-17 21:20:16.839] [INFO] Checking git for module: MMM-FroniusSolar2
      0|mm | [2025-03-17 21:20:16.855] [INFO] Checking git for module: MMM-text-clock
      0|mm | [2025-03-17 21:20:16.863] [INFO] Checking git for module: mmm-systemtemperature
      0|mm | [2025-03-17 21:20:16.871] [INFO] Checking git for module: MagicMirror
        sdetweil @TomOMaley
        @TomOMaley OK, need to see more lines,
        but
        to get rid of some noise errors
        edit the ~/MagicMirror/installers/mm.sh
        and change npm start to
        npm run start:wayland
        then
        pm2 flush
        pn2 restart mm
        wait a while, then pm2 logs --lines=50
        T 1 Reply Last reply
        • T
          TomOMaley @sdetweil
          @sdetweil Hello Sam, in the installers/mm.sh, second line, I find: npm run start:x11 ; should I change this to npm start:wayland OR to npm run start:wayland ?
          AND
          then
          pm2 flush
          pn2 restart mm ! Is it pn2 OR pm2 ?
            sdetweil @TomOMaley
            @TomOMaley
            good catch
            npm start, is the only shortcut
            all others require npm run
            see the package.json
            scripts
            list for other npm run commands
            • T
              TomOMaley @sdetweil
              Sorry, don not know, how to edit mm.sh. when I go to ~/MagicMirror/installers/mm.sh I get a long list but can not edit it. When I go to mm.sh via Datei Manager I get only this few lines:
              #!/bin/bash
              This file is still here to keep PM2 working on older installations.
              cd /home/pi5/MagicMirror
              DISPLAY=:0 npm start.
              I have seen that in raspberry config > advanced options one can switch to wayland backends. Could that help here in any way? Sorry but my knowledge in Linux is not really exciting. Thanks for all your effort.
                sdetweil @TomOMaley
                @TomOMaley
                there it is
                edit
                nano is a terminal windows based
                genie is a graphical editor
                there lots of others
                • T
                  TomOMaley @sdetweil
                  @sdetweil ???
                    sdetweil @TomOMaley
                    @TomOMaley you replace npm start
                    with npm run start:wayland
                    right?
                    you said you didnt know how to edit. how do you change config.js?
                    T 2 Replies Last reply
                    • T
                      TomOMaley @sdetweil
                      @sdetweil can’t neither write nor do anything in mm.sh
                      • T
                        TomOMaley @sdetweil
                        @sdetweil Thank you so far Sam. I give up and will use my Pi4 where everything runs smothly. It is much to time consuming and frustrating. When I have more time I think I try an MM installation manually from scratch. I really appriciate your help. Can I show my appreciation in any way ?
                        S 2 Replies Last reply
                          sdetweil @TomOMaley
                          @TomOMaley
                          cd ~/MagicMirror/installers
                          nano mm.sh
                          move around with arrow keys, backspace , etc,
                          change
                          then
                          ctrl-o
                          to write file, hit enter
                          ctrl-x to exit
                          this project requires a lot of learning
                          no shortcuts
                          time for a linux class
                            sdetweil @TomOMaley
                            @TomOMaley said in Magic Mirror with Pi4 OS not working with Pi5:
                            just be careful… there are lots of things my script does for you
