    Getting MMM-CalendarExt3Agenda to show more than 10 days out
    12 Posts 2 Posters 3.4k Views 2 Watching
      smegbadger
      Hi
      I am running MM via MagicMirrorOS on a RPi4B with a portrait monitor. Although the Calendar module is pulling through loads of events from Google, only the first ten days worth show. I’ve set startDayIndex to 0 and endDayIndex to 20 but ten days is all that will show.
      I’ve left the main calendar visible in the screenshot so you can see the number of events returned (it obs will be hidden in the final version of the config).
      I want the agenda to be bigger anyway, hopefully to take up 2/3 of the screen width. I tried adding
      .CX3A {
        --fontsize: 26px; /* Or whatever you need. The default value is 16px */
      .CX3A .event .headline.useSymbol .symbol {
        font-size: 20px; /* Or whatever you need. The default value is 75% of `.CX3A { --fontsize }` */
      to /opt/mm/mounts/css/custom.css that I found in another forum post but that didn’t change any size
      Many thanks in advance
      Steve
        smegbadger
        Hi
        I’ve discovered the CSS for the agenda module has a hard height limit
        .CX3A .agenda {
          max-height: 600px;
        increasing that to 1325px fills the screen height . I can’t tell if that was the problem all along as the patch is in place now!
        overriding the font and width as follows has given me the size of agenda I wanted.
        .CX3A {
          font-size: 30px;
          max-width: 600px;
          font-size: 25px;
        many thanks for your help
          sdetweil @smegbadger
          @smegbadger can you show the calendar config,
          xxx out private part of any url, dont remove any lines
            smegbadger @sdetweil
            @sdetweil config.js
            /* Config Sample
             * see https://docs.magicmirror.builders/configuration/introduction.html
             * and https://docs.magicmirror.builders/modules/configuration.html
             * You can use environment variables using a `config.js.template` file instead of `config.js`
             * which will be converted to `config.js` while starting. For more information
             * see https://docs.magicmirror.builders/configuration/introduction.html#enviromnent-variables
            let config = {
                    address: "0.0.0.0",     // Address to listen on, can be:
                    port: 8080,
                    basePath: "/",  // The URL path where MagicMirror² is hosted. If you are using a Reverse proxy
                    ipWhitelist: [],        // Set [] to allow all IP addresses
            A
                    useHttps: false,                        // Support HTTPS or not, default "false" will use HTTP
                    httpsPrivateKey: "",    // HTTPS private key path, only require when useHttps is true
                    httpsCertificate: "",   // HTTPS Certificate path, only require when useHttps is true
                    language: "en",
                    locale: "en-GB",   // this variable is provided as a consistent location
                                       // it is currently only used by 3rd party modules. no MagicMirror code uses this value
                                       // as we have no usage, we  have no constraints on what this field holds
                                       // see https://en.wikipedia.org/wiki/Locale_(computer_software) for the possibilities
                    timeFormat: 24,
                    units: "metric",
                                    module: "alert",
                                    module: "updatenotification",
                                    position: "fullscreen_above"
                                    module: "MMM-Universal-Pir",
                                        position: "bottom_right",
                                            gpioCommand: "gpiomon -r -b gpiochip0 23",
                                            onCommand: "wlr-randr --output HDMI-A-1 --on --transform 90",
                                            offCommand: "wlr-randr --output HDMI-A-1 --off",
                                            deactivateDelay: 60 * 1000,
                                    module: "clock",
                                            displayType: "both",
                                            analogPlacement: "top",
                                            //displaySeconds: false,
                                            dateFormat: "dddd, D MMMM YYYY",
                                            showSunTimes: true,
                                            showMoonTimes: "phase",
                                            lat: 51.8236443,
                                            lon: -0.7986995
                                    header: "Family Schedule",
                                    position: "top_center",
                                            dateFormat: "Do MMM",
                                            maximumEntries: 100,
                                                            symbol: "calendar-check",
                                                            url: "https://ics.calendarlabs.com/75/4e419f5b/UK_Holidays.ics"
                                                            fetchInterval: 60 * 1000,
                                                            url: "https://calendar.google.com/xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx.ics"
                                    module: "MMM-CalendarExt3Agenda",
                                    //header: "Family Agenda",
                                            instanceId: "Calendar",
                                            locale: "en-GB",
                                            firstDayOfWeek: 1,
                                            startDayIndex: 0,
                                            endDayIndex: 20,
                                            refreshInterval: 1000 * 60 * 5,
                                            calendarSet: ['uk-holidays', 'kemp-schedule']
                                    module: "weather",
                                    position: "bottom_left",
                                            weatherProvider: "openmeteo",
                                            type: "current",
                                            windUnits: "mph",
                                            showWindDirectionAsArrow: true,
                                            lat: 51.8236443,
                                            lon: -0.7986995
                                    module: "weather",
                                    //header: "Forecast",
                                            type: "forecast",
                                            roundTemp: true,
                                            maxNumberOfDays: 8,
                                            fadePoint: 1,
                                            lat: 51.8236443,
                                            lon: -0.7986995
                                    module: "newsfeed",
                                    position: "bottom_bar",
                                            feeds: [
                                                            title: "BBC News",
                                                            url: "https://feeds.bbci.co.uk/news/world/rss.xml"
                                            showSourceTitle: true,
                                            showPublishDate: true,
                                            broadcastNewsFeeds: true,
                                            broadcastNewsUpdates: true
            S 2 Replies Last reply
              @smegbadger i only needed the calendar module config
              BUT the docker container image does not have the clipping fix installed.
              https://forum.magicmirror.builders/topic/19282/version-2-30-0-calendar-fix-for-clipping-broadcast-events
                @smegbadger you might be able to overcome this with a higher maximumEvents (which includes past in this bug)
                  smegbadger
                  @smegbadger said in Getting MMM-CalendarExt3Agenda to show more than 10 days out:
                  I took it to maximumEntries: 500 but that didn’t change anything.
                  Which directory do i need to be in to execute the git pull for the patch as the structure is slightly different with docker?
                  /opt/mm/mounts/modules or /opt/mm/mounts/modules/default (where the calendar module is)
                    smegbadger
                    Hi
                    following the same process that i used to install MMM-CalendarExt3Agenda in the fiirst place i ran the git inside the docker but it hasn’t changed the display. Have i done it incorrectly?
                    magicm@magicmirror:/opt/mm/run $ docker exec -it mm bash
                    node@magicmirror:/opt/magic_mirror$ ls
                    CHANGELOG.md      clientonly                entrypoint.sh      js               mount_ori            serveronly
                    Collaboration.md  config                    eslint.config.mjs  jsconfig.json    node_modules         tests
                    LICENSE.md        create_restore_script.sh  fonts              mm2.png          package-lock.json    translations
                    README.md         cspell.config.json        index.html         module-types.ts  package.json         vendor
                    build.info        css                       jest.config.js     modules          prettier.config.mjs
                    node@magicmirror:/opt/magic_mirror$ git fetch origin pull/3679/head:_fix_clipping
                    remote: Enumerating objects: 27479, done.
                    remote: Counting objects: 100% (27479/27479), done.
                    remote: Compressing objects: 100% (9077/9077), done.
                    remote: Total 27158 (delta 17476), reused 26718 (delta 17037), pack-reused 0 (from 0)
                    Receiving objects: 100% (27158/27158), 22.64 MiB | 12.11 MiB/s, done.
                    Resolving deltas: 100% (17476/17476), completed with 228 local objects.
                    From https://github.com/MagicMirrorOrg/MagicMirror
                     * [new ref]           refs/pull/3679/head -> _fix_clipping
                     * [new tag]           v2.0.0              -> v2.0.0
                     * [new tag]           v2.0.1              -> v2.0.1
                     * [new tag]           v2.0.2              -> v2.0.2
                     * [new tag]           v2.0.3              -> v2.0.3
                     * [new tag]           v2.0.4              -> v2.0.4
                     * [new tag]           v2.0.5              -> v2.0.5
                     * [new tag]           v2.1.0              -> v2.1.0
                     * [new tag]           v2.1.1              -> v2.1.1
                     * [new tag]           v2.1.2              -> v2.1.2
                     * [new tag]           v2.1.3              -> v2.1.3
                     * [new tag]           v2.10.0             -> v2.10.0
                     * [new tag]           v2.10.1             -> v2.10.1
                     * [new tag]           v2.11.0             -> v2.11.0
                     * [new tag]           v2.12.0             -> v2.12.0
                     * [new tag]           v2.13.0             -> v2.13.0
                     * [new tag]           v2.14.0             -> v2.14.0
                     * [new tag]           v2.15.0             -> v2.15.0
                     * [new tag]           v2.16.0             -> v2.16.0
                     * [new tag]           v2.17.0             -> v2.17.0
                     * [new tag]           v2.17.1             -> v2.17.1
                     * [new tag]           v2.18.0             -> v2.18.0
                     * [new tag]           v2.19.0             -> v2.19.0
                     * [new tag]           v2.2.0              -> v2.2.0
                     * [new tag]           v2.2.1              -> v2.2.1
                     * [new tag]           v2.2.2              -> v2.2.2
                     * [new tag]           v2.20.0             -> v2.20.0
                     * [new tag]           v2.21.0             -> v2.21.0
                     * [new tag]           v2.22.0             -> v2.22.0
                     * [new tag]           v2.23.0             -> v2.23.0
                     * [new tag]           v2.24.0             -> v2.24.0
                     * [new tag]           v2.25.0             -> v2.25.0
                     * [new tag]           v2.26.0             -> v2.26.0
                     * [new tag]           v2.27.0             -> v2.27.0
                     * [new tag]           v2.28.0             -> v2.28.0
                     * [new tag]           v2.29.0             -> v2.29.0
                     * [new tag]           v2.3.0              -> v2.3.0
                     * [new tag]           v2.3.1              -> v2.3.1
                     * [new tag]           v2.4.0              -> v2.4.0
                     * [new tag]           v2.4.1              -> v2.4.1
                     * [new tag]           v2.5.0              -> v2.5.0
                     * [new tag]           v2.6.0              -> v2.6.0
                     * [new tag]           v2.7.0              -> v2.7.0
                     * [new tag]           v2.7.1              -> v2.7.1
                     * [new tag]           v2.8.0              -> v2.8.0
                     * [new tag]           v2.9.0              -> v2.9.0
                    node@magicmirror:/opt/magic_mirror$ git switch _fix_clipping
                    error: Your local changes to the following files would be overwritten by checkout:
                            package-lock.json
                            package.json
                    Please commit your changes or stash them before you switch branches.
                    Aborting
                    node@magicmirror:/opt/magic_mirror$ rm package-lock.json
                    node@magicmirror:/opt/magic_mirror$ rm package.json
                    D       config/config.js.sample
                    Previous HEAD position was c24de64d Release 2.30.0 (#3673)
                    Switched to branch '_fix_clipping'
                    node@magicmirror:/opt/magic_mirror$ exit
                    exit
                      @smegbadger you also need to do a new
                      npm run install-mm
                        smegbadger
                        Hi
                        I ran npm run install-mm in the docker container as the above commands and rebooted. The agenda is still truncated
                        Steve
                          @smegbadger AND restarted the container??
                            smegbadger
                            Hi
                            .CX3A .agenda {
                              max-height: 600px;
                            .CX3A {
                              font-size: 30px;
                              max-width: 600px;
                              font-size: 25px;
                              @smegbadger awesome!!
