    MMM-CalendarExt3 and MMM-MonthlyCalendar blank
    59 Posts 3 Posters 24.7k Views 3 Watching
      sdetweil @Scott-M
      @Scott-M ok, starting server is correct…
      did you npm install or npm run install-mm
      after installing the clipping fix?? (its required)
        Scott-M @sdetweil
        @sdetweil said in MMM-CalendarExt3 and MMM-MonthlyCalendar blank:
        I see, my mistake. I assumed from the forum post that this was if you use the development branch, as the instructions said
        git fetch origin pull/3679/head:_fix_clipping
        git switch _fix_clipping
        # if you get an error error, rm package-lock.json
        # and repeat the git switch
        restart MM
        with npm run install-mm further down the post. I must have done this on the older one I am using though as it works.
        Away all weekend so won’t be able to check until Monday.
        Thanks again!
          Scott-M
          Just to pick back up on this, I checked my bash history and I did npm run install-mm after the clipping fix.
          I have tried a few times now to do this with the same result, this time without the clipping fix.
          Reflashed the image and then the following steps are my bash history from first run of the OS. Only change to the config file is changing the port and the full whitelist. I selected No to the pm2 question, the screensaver was not disabled, just a waring about not knowing how to disable on an labwc compositor.
          bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/raspberry.sh)"
          cd ~/MagicMirror/config
          nano config.js
          npm run start
          With the following results, MagicMirror doesn’t start. and doesn’t get any futher that the whitelist warning. Same result without the full whitlist though…
          scott@MagicMirror:~/MagicMirror/config $ npm run start
          > magicmirror@2.30.0 start
          > npm run start:x11
          > magicmirror@2.30.0 start:x11
          [2025-03-25 09:38:22.852] [LOG]   Starting MagicMirror: v2.30.0
          [2025-03-25 09:38:22.861] [LOG]   Loading config ...
          [2025-03-25 09:38:22.862] [LOG]   config template file not exists, no envsubst
          [2025-03-25 09:38:23.052] [INFO]  Checking config file /home/scott/MagicMirror/config/config.js ...
          [2025-03-25 09:38:23.078] [INFO]  Your configuration file doesn't contain syntax errors :)
          [2025-03-25 09:38:23.078] [INFO]  Checking modules structure configuration ...
          [2025-03-25 09:38:23.117] [INFO]  Your modules structure configuration doesn't contain errors :)
          [2025-03-25 09:38:23.119] [LOG]   Loading module helpers ...
          [2025-03-25 09:38:23.119] [LOG]   No helper found for module: alert.
          [2025-03-25 09:38:23.122] [LOG]   Initializing new module helper ...
          [2025-03-25 09:38:23.122] [LOG]   Module helper loaded: updatenotification
          [2025-03-25 09:38:23.122] [LOG]   No helper found for module: clock.
          [2025-03-25 09:38:23.169] [LOG]   Initializing new module helper ...
          [2025-03-25 09:38:23.169] [LOG]   Module helper loaded: calendar
          [2025-03-25 09:38:23.170] [LOG]   No helper found for module: compliments.
          [2025-03-25 09:38:23.170] [LOG]   No helper found for module: weather.
          [2025-03-25 09:38:23.208] [LOG]   Initializing new module helper ...
          [2025-03-25 09:38:23.208] [LOG]   Module helper loaded: newsfeed
          [2025-03-25 09:38:23.208] [LOG]   All module helpers loaded.
          [2025-03-25 09:38:23.211] [LOG]   Starting server on port 8089 ...
          [2025-03-25 09:38:23.216] [WARN]  You're using a full whitelist configuration to allow for all IPs
          Would be useful is someone can replicate this and see if it is something peculiar to my enviroment.
          Raspberry Pi5 with 64 Bit Debian Bookworm with desktop.
          I am just about to try with the 32 bit image but the whole process takes a while.
          Update: couldn’t get it to install on the 32 bit version. New install of 32 bit bookworm, ran the install script and it fails with:
          installing correct version of node and npm, please wait
          /usr/local/bin/n: line 753: /usr/local/bin/node: cannot execute: required file not found
          bash: line 309: /usr/local/bin/node: cannot execute: required file not found
          node failed to install, exiting
            sdetweil @Scott-M
            @Scott-M i will examine and fix the installer
            32bit on pi5 might never run as there were conflicting hardware changes
            can you try to start for wayland?
            npm run start:wayland
            see https://forum.magicmirror.builders/topic/19269/new-magicmirror-start-options-in-version-2-30-0
              Scott-M @sdetweil
              > magicmirror@2.30.0 start:wayland
              > WAYLAND_DISPLAY="${WAYLAND_DISPLAY:=wayland-1}" ./node_modules/.bin/electron js/electron.js --enable-features=UseOzonePlatform --ozone-platform=wayland
              did not find extension DRI_Mesa version 1
              failed to bind extensions
              [2025-03-25 13:07:24.800] [LOG]   Starting MagicMirror: v2.30.0
              [2025-03-25 13:07:24.809] [LOG]   Loading config ...
              [2025-03-25 13:07:24.811] [LOG]   config template file not exists, no envsubst
              [2025-03-25 13:07:25.425] [INFO]  Checking config file /home/scott/MagicMirror/config/config.js ...
              [2025-03-25 13:07:25.451] [INFO]  Your configuration file doesn't contain syntax errors :)
              [2025-03-25 13:07:25.451] [INFO]  Checking modules structure configuration ...
              [2025-03-25 13:07:25.489] [INFO]  Your modules structure configuration doesn't contain errors :)
              [2025-03-25 13:07:25.491] [LOG]   Loading module helpers ...
              [2025-03-25 13:07:25.492] [LOG]   No helper found for module: alert.
              [2025-03-25 13:07:25.498] [LOG]   Initializing new module helper ...
              [2025-03-25 13:07:25.499] [LOG]   Module helper loaded: updatenotification
              [2025-03-25 13:07:25.499] [LOG]   No helper found for module: clock.
              [2025-03-25 13:07:25.640] [LOG]   Initializing new module helper ...
              [2025-03-25 13:07:25.640] [LOG]   Module helper loaded: calendar
              [2025-03-25 13:07:25.642] [LOG]   No helper found for module: compliments.
              [2025-03-25 13:07:25.647] [LOG]   No helper found for module: weather.
              [2025-03-25 13:07:25.761] [LOG]   Initializing new module helper ...
              [2025-03-25 13:07:25.762] [LOG]   Module helper loaded: newsfeed
              [2025-03-25 13:07:25.762] [LOG]   All module helpers loaded.
              [2025-03-25 13:07:25.765] [LOG]   Starting server on port 8089 ...
              [2025-03-25 13:07:25.770] [WARN]  You're using a full whitelist configuration to allow for all IPs
              [1800:0325/130726.055765:ERROR:wayland_connection.cc(198)] Failed to connect to Wayland display: No such file or directory (2)
              [1800:0325/130726.055835:ERROR:ozone_platform_wayland.cc(264)] Failed to initialize Wayland platform
              [1800:0325/130726.055842:ERROR:env.cc(258)] The platform failed to initialize.  Exiting.
              /home/scott/MagicMirror/node_modules/electron/dist/electron exited with signal SIGSEGV
                sdetweil @Scott-M
                @Scott-M this is confusing… by default the system is setup for wayland/labwc,
                not x11 (which npm start does)
                just another test, using manual install into another folder
                cd ~
                git clone https://github.com/MagicMirrorOrg/MagicMirror.git fribble
                cd fribble
                npm run install-mm
                npm start
                if that fails then try erasing the saved electron info
                cd ~
                rm -rf .config/Electron
                cd MagicMirror
                npm start
                you try the fribble directory too
                  Scott-M @sdetweil
                  Sorry, same result with both of those, doesn’t get past the starting server message.
                  System info:
                  sudo cat /sys/firmware/devicetree/base/model;echo
                  cat /etc/os-release
                  Raspberry Pi 5 Model B Rev 1.0
                  PRETTY_NAME="Debian GNU/Linux 12 (bookworm)"
                  NAME="Debian GNU/Linux"
                  VERSION_ID="12"
                  VERSION="12 (bookworm)"
                  VERSION_CODENAME=bookworm
                  ID=debian
                  HOME_URL="https://www.debian.org/"
                  SUPPORT_URL="https://www.debian.org/support"
                  BUG_REPORT_URL="https://bugs.debian.org/"
                  I do have an SD with a working MagicMirror on it, installed exactly the same was a couple of weeks ago.
                  I have just going to try another fresh install of bookworm, update / upgrade and then manually install nodejs and npm and MagicMirror ans see what happens. Don’t expect a different result but will see what happens.
                    Scott-M @Scott-M
                    @Scott-M @sdetweil
                    So, it works installing manually, bash history…:
                    sudo apt update
                    sudo apt full-upgrade
                    sudo reboot now
                    curl -sL https://deb.nodesource.com/setup_20.x | sudo -E bash -
                    sudo apt-get install nodejs -y
                    sudo apt install npm
                    cd MagicMirror
                    npm run install-mm
                    cp config/config.js.sample config/config.js
                    npm start
                    The install log from the one that doesn’t run is here if that helps at all.
                      sdetweil @Scott-M
                      @Scott-M very interesting… only thing I can see different is the sandbox permissions
                      I don’t have time til later today to examine any more…
                      thanks for the feedback
                        Scott-M @sdetweil
                        @sdetweil OK, I will keep the various SD cards with working and non working version for a while just in case it would be of help.
                          sdetweil @Scott-M
                          @Scott-M thanks… appreciate that
                            Scott-M @sdetweil
                            I had one more attempt at this, this time I ran an update and upgrade before running your script and this time it worked. Cannot see why that would be…
                            Happy to experiment more if you need more info but I am going to start on building the 2 way mirror now!
                              sdetweil @Scott-M
                              @Scott-M and my script does that before too, its in the install.log file
                                Scott-M @sdetweil
                                I am sorry if this has been a wild goose chase and a waste of your time. I flashed the SD card, ran the script several times and it didn’t work, I will try one more time tomorrow and leave it at that.
                                Random results from repeating the same process are very frustrating.
                                  sdetweil @Scott-M
                                  @Scott-M frustrating indeed
                                  but its normal
                                    Scott-M @sdetweil
                                    Results from todays adventures writing Pi images to SD cards…
                                    I don’t really know what, if any difference there could be but I flashed 4 SD cards with the same
                                    64 bit Bookworm image.
                                    2 of them, I just ran the install script and let it update the system. The other 2, I updated / upgraded first. 1 with apt full-upgrade and the other with apt upgrade and then ran the install script.
                                    The first 2 stopped at the same point on the starting server message and the other 2 just worked.
                                    When the system stops at the starting server message, CTRL-C doesn’t do anything so SIGINT is not being picked up.
                                    It may well just be something peculiar to my setup or enviroment.
                                      sdetweil @Scott-M
                                      @Scott-M great feedback… I have family stuff most of the day today…
                                      did you do npm install or npm run install-mm
                                      npm run install-mm is more like what I do in the script… which limits what things npm does…
                                      npm install does everything possible
                                        Scott-M
                                        I didn’t do either, I just ran your script from first run on the OS on the first 2 cards. On the other 2 cards, on first run of the OS I entered
                                        sudo apt update
                                        The only difference between them is your script not updating the system. It may all just be a coincidence and someone else with same hardware verifying would be helpful.
                                        S 2 Replies Last reply
                                          sdetweil @Scott-M
                                          @Scott-M ah… ok, I don’t do full-upgrade… only upgrade
                                          Use apt upgrade for routine updates when you don't want to risk removing packages.
                                          Use apt full-upgrade when you need to ensure that all packages are up-to-date, even if it means removing some packages.
                                          Be cautious when using apt full-upgrade as it can potentially remove packages that you might need.
                                          but it seems that full-upgrade handles some dependencies NOT handled by upgrade, which seems like a bug to me… whats the point of upgrade if dependencies aren’t handled…
                                            sdetweil @Scott-M
                                            @Scott-M if you have a hankering to run another test, run the script from the test branch for next release… it will still get 2.30 , this does full-upgrade
                                            bash -c “$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/v231/raspberry.sh)”
                                            • 2 / 3
