    Unable to get MMM-Calendar to broadcast past events
    5 Posts 2 Posters 937 Views 2 Watching
    • T Offline
      thecaptainzap
      I’m a new user trying to get my MagicMirror up and running. I’m running into an issue with MMM-Calendar or MMM-CalendarExt3. I’m using the “week” view and as soon as events are in the past, it won’t show any of them.
      I’ve done a bit of browsing on the forum (amazing community of helpful people, BTW!) and believe I have everything aligned, including setting maximumEntries, maximumNumberOfDays, pastDaysCount, and broadcastPastEvents in MMM-calendar.
      I created a test calendar to try to simplify things, and created 5 events, one on each day of the week this week. When running MagicMirror, I get a notification that Calendar-Fetcher for [FAMILY] is broadcasting 3 events, presumably today, tomorrow and Friday. See below for the 5 expected events.
      Here’s my code (with personal details omitted):
                             			module: "alert",
                             			maximumEntries: 10000,
                             			maximumNumberOfDays: 28,
                             			pastDaysCount: 14,
                             			maxTitleLength: 50,
                             			showLocation: false,
                             			wrapEvents: true,
                             			broadcastPastEvents: true,
                             						//fetchInterval: 7 * 24 * 60 * 60 * 1000,
                             						url: "https://ics.calendarlabs.com/76/mm3137/US_Holidays.ics",
                             						color: "#7c7c7c",
                             						//Family Calendar
                             						url: "https://calendar.google.com/calendar/ical/[PRIVATE CALENDAR ADDRESS]/basic.ics",
                             						color: "#e7ba51",
                             			module: "MMM-CalendarExt3",
                             			title: "",
                             				instanceID: "familyCalendar",
                             				mode: "week",
                             				weekIndex: 0,
                             				weeksInView: 2,
                             				maxEventLines: 5,
                             				firstDayOfWeek: 0,
                             				cellDateOptions: {month: 'long', day: 'numeric'},
                             				maxEventLines: 8,
                             				calendarSet: ['Holidays', 'Family', 'School'],
      Here’s a screengrab of my Google Calendar and what I would expect to see in MMM-CalendarExt3:
      And here’s what’s on my MagicMirror:
      I’m guessing I’m missing something simple, but I just don’t see it. I appreciate everyone’s help!
        sdetweil @thecaptainzap
        @thecaptainzap
        thanks… I missed something in your prior post
        all of these
                               			pastDaysCount: 14,
                               			maxTitleLength: 50,
                               			wrapEvents: true,
        go AFTER the
        line in the module definition in config.js
        as they are parameters TO the calendar module, NOT to the MagicMirror runtime
        also, this seems to be a problem
        fatal: refusing to fetch into branch 'refs/heads/_fix_clipping' checked out at '/home/tim/MagicMirror'
          @thecaptainzap did you put on the fix
          https://forum.magicmirror.builders/topic/19282/version-2.30.0-calendar-fix-for-clipping-broadcast-events
          • T Offline
            thecaptainzap @sdetweil
            @sdetweil Thanks so much for the reply! I didn’t know about that fix and have now applied it. However, it is still only broadcasting future events. I only get the 2 events (today and tomorrow). Nothing from the 24th-26th.
            I ran into the “package-lock.json” error. Removed that file, proceeded with installation. Then restarted MM. No change so rebooted the machine to feel good about myself. Ran “npm run install-mm” again after the reboot. Still no change.
            Here’s the result of the 2nd install (after reboot):
            tim@calendar:~$ cd ~/MagicMirror/
            tim@calendar:~/MagicMirror$ git fetch origin pull/3679/head:_fix_clipping
            tim@calendar:~/MagicMirror$ git switch _fix_clipping
            M       index.html
            Already on '_fix_clipping'
            tim@calendar:~/MagicMirror$ npm run install-mm
            > magicmirror@2.31.0-develop install-mm
            > npm install --no-audit --no-fund --no-update-notifier --only=prod --omit=dev
            > magicmirror@2.31.0-develop postinstall
            > npm run install-vendor && npm run install-fonts && echo "MagicMirror² installation finished successfully!
            > magicmirror@2.31.0-develop install-vendor
            > " && cd vendor && npm install --loglevel=error --no-audit --no-fund --no-update-notifier
            up to date in 1s
            > magicmirror@2.31.0-develop install-fonts
            > echo "Installing fonts ...
            > " && cd fonts && npm install --loglevel=error --no-audit --no-fund --no-update-notifier
            up to date in 1s
            > magicmirror@2.31.0-develop prepare
            > [ -f node_modules/.bin/husky ] && husky || echo no husky installed.
            no husky installed.
            up to date in 13s
            I appreciate your time & feedback!
              @thecaptainzap
              all of these
                                     			pastDaysCount: 14,
                                     			maxTitleLength: 50,
                                     			wrapEvents: true,
              go AFTER the
              • T Offline
                @sdetweil Thank you! I knew I was doing something silly. Moving those config settings inside the config brackets fixed my issue!!
                I think the “fatal” error was because I had already run that command once, but I can’t say for certain.
                Again, I appreciate your help on this!
