    HEIC and MMM-ImagesPhotos
    20 Posts 3 Posters 6.0k Views 3 Watching
      sdetweil @rts58
      @rts58 said in HEIC and MMM-ImagesPhotos:
      animationSpeed: 500,
      have you tried setting this to 0?
      HEIC? the module looks for
      const enabledTypes = [“image/jpeg”, “image/png”, “image/gif”];
      what is a filetype for HEIC?
      you can edit that array and add the the for heic
       const enabledTypes = ["image/jpeg", "image/png", "image/gif", "image/heic"];
      R R 2 Replies Last reply Reply Quote 1
        @sdetweil HEIC is the Apple iOS version of HEIF (=High Efficiency Image Format) …
          rts58 @sdetweil
          I thought I had tried setting it to 0, but apparently I hadn’t. Now that I have made that change, it is working fine.
          The filetype for HEIC is supposed to “image/heic”. I added that to the enabledTypes array in node_helper.js and it now it is also working!
          Awesome, as always, thank you Sam!
          • R rts58 has marked this topic as solved on
            sdetweil @rts58
            @rts58 awesome, i’ll submit a pr to update the module
              rts58 @sdetweil
              @sdetweil I am still have trouble with some of the HEIC files.
              If the module runs across an unsupported HEIC (or corrupted jpg) file it will just stop and continue showing the last image.
              I couldn’t find any log or error for files that won’t open. I’ve compared the files it can and can’t open and don’t see any difference in the file details or exif data. Is there a way to have it just skip the unsupported file?
              The module does get locked up, it will not continue with a new image even after the update interval has passed. Thanks for your help.
                sdetweil @rts58
                @rts58 can you look in the developers window console tab
                ctrl-shift-i
                  rts58 @sdetweil
                  @sdetweil yes I’ve been looking at it. If it works I’ll get a message that the image loaded and link, image setting size … , and setting top. If it doesn’t it won’t show anything.
                    sdetweil @rts58
                    @rts58 ok, i’ll look at error handlers
                    R S 2 Replies Last reply Reply Quote 0
                      rts58 @sdetweil
                      @sdetweil if it helps when I dig into the elements it shows:
                      <img src="/MMM-ImagesPhotos/photo/module_9_MMM-ImagesPhotos/IMG_3259-Copy.HEIC" style="left: 0px; position: relative; opacity: 0;">
                      So it thinks it is loading the file.
                        @rts58
                        in front of
                        img.onload()
                        add
                        img.onerror(){
                           this.updateDom()
                          rts58 @sdetweil
                          @sdetweil this is what I did which is creating an uncaught syntax error on the line with the first “{”.
                          	img.onerror(){
                          	this.updateDom()
                                  img.onload = (evt) => {
                                    // Get the image of the event
                                    const eventImage = evt.currentTarget;
                                    Log.log(
                                      `image loaded=${eventImage.src} size=${eventImage.width}:${eventImage.height}`
                            sdetweil @rts58
                            @rts58 im an idiot, sorry
                            better
                            img.onerror= ()=>{
                            	this.updateDom()
                              rts58 @sdetweil
                              @sdetweil I’m not seeing any errors in the console.
                                sdetweil @rts58
                                @rts58 i did not add error reporting yet, this should keep it
                                from stalling
                                  @rts58 the prior code started the timer only after
                                  image was loaded. but we have already waited timeout time
                                  so we can get the next image
                                    sdetweil @rts58
                                    @rts58 just pushed the updated code, git pull in the module folder
                                    logs an error record to the dev window console on load fail, with the url of the failing image
                                      rts58 @sdetweil
                                      @sdetweil great, thanks. I’ll let you know how it goes.
                                        rts58 @sdetweil
                                        @sdetweil It’s working great now. No longer freezing on image files that it cannot open. And it is properly reflecting the error with the file name in the console! THANKS!
                                          sdetweil @rts58
                                          @rts58 awesome!!
