    HEIC and MMM-ImagesPhotos
    20 Posts 3 Posters 5.2k Views 3 Watching
      rts58 @sdetweil
      I thought I had tried setting it to 0, but apparently I hadn’t. Now that I have made that change, it is working fine.
      The filetype for HEIC is supposed to “image/heic”. I added that to the enabledTypes array in node_helper.js and it now it is also working!
      Awesome, as always, thank you Sam!
      • R rts58 has marked this topic as solved on
        sdetweil @rts58
        @rts58 awesome, i’ll submit a pr to update the module
          rts58 @sdetweil
          @sdetweil I am still have trouble with some of the HEIC files.
          If the module runs across an unsupported HEIC (or corrupted jpg) file it will just stop and continue showing the last image.
          I couldn’t find any log or error for files that won’t open. I’ve compared the files it can and can’t open and don’t see any difference in the file details or exif data. Is there a way to have it just skip the unsupported file?
          The module does get locked up, it will not continue with a new image even after the update interval has passed. Thanks for your help.
            sdetweil @rts58
            @rts58 can you look in the developers window console tab
            ctrl-shift-i
              rts58 @sdetweil
              @sdetweil yes I’ve been looking at it. If it works I’ll get a message that the image loaded and link, image setting size … , and setting top. If it doesn’t it won’t show anything.
                sdetweil @rts58
                @rts58 ok, i’ll look at error handlers
                R S 2 Replies Last reply Reply Quote 0
                  rts58 @sdetweil
                  @sdetweil if it helps when I dig into the elements it shows:
                  <img src="/MMM-ImagesPhotos/photo/module_9_MMM-ImagesPhotos/IMG_3259-Copy.HEIC" style="left: 0px; position: relative; opacity: 0;">
                  So it thinks it is loading the file.
                    @rts58
                    in front of
                    img.onload()
                    add
                    img.onerror(){
                       this.updateDom()
                      rts58 @sdetweil
                      @sdetweil this is what I did which is creating an uncaught syntax error on the line with the first “{”.
                      	img.onerror(){
                      	this.updateDom()
                              img.onload = (evt) => {
                                // Get the image of the event
                                const eventImage = evt.currentTarget;
                                Log.log(
                                  `image loaded=${eventImage.src} size=${eventImage.width}:${eventImage.height}`
                        sdetweil @rts58
                        @rts58 im an idiot, sorry
                        better
                        img.onerror= ()=>{
                        	this.updateDom()
                          rts58 @sdetweil
                          @sdetweil I’m not seeing any errors in the console.
                            sdetweil @rts58
                            @rts58 i did not add error reporting yet, this should keep it
                            from stalling
                              @rts58 the prior code started the timer only after
                              image was loaded. but we have already waited timeout time
                              so we can get the next image
                                sdetweil @rts58
                                @rts58 just pushed the updated code, git pull in the module folder
                                logs an error record to the dev window console on load fail, with the url of the failing image
                                R 2 Replies Last reply Reply Quote 1
                                  rts58 @sdetweil
                                  @sdetweil great, thanks. I’ll let you know how it goes.
                                    rts58 @sdetweil
                                    @sdetweil It’s working great now. No longer freezing on image files that it cannot open. And it is properly reflecting the error with the file name in the console! THANKS!
                                      sdetweil @rts58
                                      @rts58 awesome!!
