    HEIC and MMM-ImagesPhotos
    20 Posts 3 Posters 6.0k Views 3 Watching
      rts58 @sdetweil
      @sdetweil if it helps when I dig into the elements it shows:
      <img src="/MMM-ImagesPhotos/photo/module_9_MMM-ImagesPhotos/IMG_3259-Copy.HEIC" style="left: 0px; position: relative; opacity: 0;">
      So it thinks it is loading the file.
        @rts58
        in front of
        img.onload()
        add
        img.onerror(){
           this.updateDom()
          rts58 @sdetweil
          @sdetweil this is what I did which is creating an uncaught syntax error on the line with the first “{”.
          	img.onerror(){
          	this.updateDom()
                  img.onload = (evt) => {
                    // Get the image of the event
                    const eventImage = evt.currentTarget;
                    Log.log(
                      `image loaded=${eventImage.src} size=${eventImage.width}:${eventImage.height}`
            sdetweil @rts58
            @rts58 im an idiot, sorry
            better
            img.onerror= ()=>{
            	this.updateDom()
              rts58 @sdetweil
              @sdetweil I’m not seeing any errors in the console.
                sdetweil @rts58
                @rts58 i did not add error reporting yet, this should keep it
                from stalling
                  @rts58 the prior code started the timer only after
                  image was loaded. but we have already waited timeout time
                  so we can get the next image
                    sdetweil @rts58
                    @rts58 just pushed the updated code, git pull in the module folder
                    logs an error record to the dev window console on load fail, with the url of the failing image
                    R 2 Replies Last reply Reply Quote 1
                      rts58 @sdetweil
                      @sdetweil great, thanks. I’ll let you know how it goes.
                        rts58 @sdetweil
                        @sdetweil It’s working great now. No longer freezing on image files that it cannot open. And it is properly reflecting the error with the file name in the console! THANKS!
                          sdetweil @rts58
                          @rts58 awesome!!
