    openweathermap not working
    11 Posts 2 Posters 2.0k Views 2 Watching
      sdetweil @Sam 0
      @Sam-0 see https://forum.magicmirror.builders/topic/19323/version-2-30-0-weather-module-stuck-loading-worked-fine-before-upgrade
        Sam 0 @Sam 0
        @Sam-0 I read your post but I can’t figure it out. Does the entire option not work or did I make a mistake somewhere?
          @dontronics
          dont need provider, endpoint, or apiversion as those are the defaults
          the apiKey is the one backed by credit card, right?
            Sam 0 @sdetweil
            I didn’t have to give a credit card, I don’t have one either, so it won’t work at all? Is the location option correct? Thanks for the effort and answering the questions
            S S 2 Replies Last reply Reply Quote 0
              sdetweil @Sam 0
              @Sam-0 read the top of the linked post.
                Sam 0 @Sam 0
                @Sam-0 I have made some changes and now I get a different message, this is what I have in my config now, can anyone help me with what still needs to be done? config:
                // See ‘Configuration options’ for more information.
                weatherProvider: “openweathermap”,
                apiKey: “drtdgrdgfgfdgdfgfdgfdtestmmmmmmm”,
                lat: 52.0575,
                lon: 4.4931,
                apiBase:‘https://api.openweathermap.org/data/’,
                weatherEndpoint:‘/onecall’,
                message on mm invalid that NAN
                  Sam 0 @sdetweil
                  @sdetweil I read the topic maybe my English is not so good that I do not understand it well can you indicate what I am doing wrong I have now adjusted the following
                  disabled: false,
                  module: “weather”,
                  position: “top_right”,
                  header: “Weather Forecast”,
                  config:
                  apiKey: “ghgjhgjhgjghjgjfghchghf”,
                  lat: 52.0575,
                  lon: 4.4931,
                    Sam 0 @sdetweil
                    @sdetweil ok I continued searching and now have the following config which seems to work at the moment disabled: false,
                    module: “weather”,
                            config:
                    	apiKey: "fnotmyapikey sampletestttghfhghfhfghfhghh",
                    	lat: 52.0575,
                    	lon: 4.4931,
                    apiVersion: ‘2.5’,
                    weatherEndpoint: “/weather”,
                      Sam 0
                      module: “weather”,
                              config:
                      	lat: 52.0575,
                      	lon: 4.4931,
                      apiVersion: ‘2.5’,
                      I added
                      the following values
                      apiVersion:
                      ‘2.5’,
                        sdetweil @Sam 0
                        @Sam-0 you finally got it
                        as your native language is not english, have the browser translate the page
