    openweathermap not working
    11 Posts 2 Posters 1.9k Views 2 Watching
      @dontronics
      dont need provider, endpoint, or apiversion as those are the defaults
      the apiKey is the one backed by credit card, right?
        Sam 0 @sdetweil
        I didn’t have to give a credit card, I don’t have one either, so it won’t work at all? Is the location option correct? Thanks for the effort and answering the questions
        S S 2 Replies Last reply Reply Quote 0
          sdetweil @Sam 0
          @Sam-0 read the top of the linked post.
            Sam 0 @Sam 0
            @Sam-0 I have made some changes and now I get a different message, this is what I have in my config now, can anyone help me with what still needs to be done? config:
            // See ‘Configuration options’ for more information.
            weatherProvider: “openweathermap”,
            apiKey: “drtdgrdgfgfdgdfgfdgfdtestmmmmmmm”,
            lat: 52.0575,
            lon: 4.4931,
            apiBase:‘https://api.openweathermap.org/data/’,
            weatherEndpoint:‘/onecall’,
            message on mm invalid that NAN
              Sam 0 @sdetweil
              @sdetweil I read the topic maybe my English is not so good that I do not understand it well can you indicate what I am doing wrong I have now adjusted the following
              disabled: false,
              module: “weather”,
              position: “top_right”,
              header: “Weather Forecast”,
              config:
              apiKey: “ghgjhgjhgjghjgjfghchghf”,
              lat: 52.0575,
              lon: 4.4931,
                Sam 0 @sdetweil
                @sdetweil ok I continued searching and now have the following config which seems to work at the moment disabled: false,
                module: “weather”,
                        config:
                	apiKey: "fnotmyapikey sampletestttghfhghfhfghfhghh",
                	lat: 52.0575,
                	lon: 4.4931,
                apiVersion: ‘2.5’,
                weatherEndpoint: “/weather”,
                  Sam 0
                  module: “weather”,
                          config:
                  	lat: 52.0575,
                  	lon: 4.4931,
                  apiVersion: ‘2.5’,
                  I added
                  the following values
                  apiVersion:
                  ‘2.5’,
                    sdetweil @Sam 0
                    @Sam-0 you finally got it
                    as your native language is not english, have the browser translate the page
