    Version 2.31.0 Error With Upgrade Scripts
    5 Posts 2 Posters 1.2k Views 2 Watching
      atwist
      I used the upgrade script to update my MagicMirror to 2.31.0 from 2.30.0. It ran into an error and now MagicMirror won’t start.
      The upgrade log file shows
      Ver 2.30.0 and Ext3 modules loaded, install fix
      • _fix_clipping
        master
        npm error code EACCES
        npm error syscall rename
        npm error path /home/twist/MagicMirror/node_modules/.ast-types-VPJXcxdi/node_modules/tslib/CopyrightNotice.txt
      and it continues with npm error.
      Any ideas how to fix this?
        sdetweil @atwist
        @atwist eaccess denied sounds like you might have run
        one of the npm commands w sudo. (never do that)
        so to fix this you have to do it again to clean up
        sudo rm -rf node_modules
        cd fonts
        sudo rm - rf node_modules
        cd ../vendor
        then run the upgrade script again with
        force
        instead of
        apply
        at the end
          sdetweil @atwist
          @atwist can you tell me what you did?
          note that upgrade is a 2 step process
          test
          do
          show me the output of ~/MagicMirror/installers/upgrade.log
            sdetweil @atwist
            cd fonts
            cd ../vendor
            force
            instead of
            apply
            at the end
              atwist
              I didn’t think i ran it with sudo but apparently i did. Thank you for your help!!
              I did try the test first and it didn’t show errors. But, you got it working!
                sdetweil @atwist
                @atwist awesome!
