    How can I make sure that a third-party module (MMM) is safe to use?
    4 Posts 3 Posters 697 Views 3 Watching
    • T Offline
      TagTube
      Hi everyone,
      I’m starting to explore third-party MagicMirror modules (MMMs), and I’ve found some really cool ones. However, before I install anything, I want to make sure I’m not putting my system or data at risk.
      What are your tips for checking whether a third-party module is safe and trustworthy?
      Are there any red flags I should look out for in the code or repository?
      Do you only use modules from specific sources?
      Thanks in advance 😊
        sdetweil @TagTube
        @TagTube there are no advisories . examining the code is the only way. no tests you can run
        so far because of opensource we have not had any bad actor developers
        • BKeyportB Offline
          @sdetweil … depends on how to define bad actor. We’ve not had any developers that have used the platform in a bad way with their modules, yes…
            sdetweil @BKeyport
            @BKeyport i know, didn’t want to go down that rat hole
            i proposed some module standards, (based on that experience) no minified code, so that bad actors cant hide.
            there are currently only 7 modules w minified code, but they were all generated from typescript source. so minified in that case is unimportant.
            we dont have a way to enforce any such standards
            makes me think of some vault to keep things from disappearing too
