    Fan for Pi5???
    11 Posts 3 Posters 2.6k Views 3 Watching
    • BKeyportB Offline
      BKeyport Module Developer @rkorell
      @rkorell Mine is in a https://argon40.com/products/argon-one-v3-case-for-raspberry-pi-5 case, hidden behind the TV.
        rkorell @BKeyport
        @BKeyport OK, thanks!
        • Have seen this somewhere sometimes …
          I had to have the one with NVME - pretty expensive (for a pi-housing) and pretty big - I‘ve not that much space behind the mirror but will consider this as an alternative.
          Keep you posted…
          Regards,
          Ralf
          rkorell @BKeyport
          @BKeyport - there are some reviews out there stating, that raspi 5 power supply isn’t capable to power this config sufficiently and that the temperature is about 70°C and fan is loud …
          As you‘re recommending this I assume that his isn‘t the case in your installation (mentioned reviews are for the NVME housings…).
          Is this assumption correct?
          Thanks,
          Ralf
            sdetweil @rkorell
            @rkorell i have 2 pi5 w the official fan. one w nvme hat and one without. both are silent after a year
              rkorell @sdetweil
              @sdetweil Lucky guy!
              Thanks for feedback!
              Ralf
                rkorell @sdetweil
                @sdetweil , @BKeyport :
                In the meantime a GeeekPi Ultra Thin ICE Tower Cooler is arrived and just installed.
                Fan is bigger than Pi - looks weird.
                After 20 minutes temperature is at 52°C nothing to hear.
                Keep you posted…
                Thanks for your feedback so far!
                Ralf
                  sdetweil @rkorell
                  @rkorell that is a beast!!!
                    rkorell @sdetweil
                    @sdetweil :-) indeed ….
                    (Fits millimeter-exactly behind the mirror no more space left…)
                    But seems to work.
                    • BKeyportB Offline
                      @rkorell I haven’t had any issues - it spreads the heat out much more than many of the setups, but it does work in keeping the system running without much noise. This is on a RasPi 5 that runs two mirrors - one with pages flipping all the time, the other showing camera feeds. Very process intensive. I got it initially because the pi was going to be visible - if I was going to use it in the config I have now, I’d likely go with something with a large heat sink and a quiet (Noctura?) fan.
                        rkorell @BKeyport
                        @BKeyport OK, thanks for your viewpoint!
                        Than I‘m on the right way - still works today :-)
                        Temperature was 45°C today in the morning - was at 56° everytime before …
                        So even passive cooling seems to be much better.
                        Nice rest of weekeend to all of you.
                        Ralf
