    I am using the default clock module in analog mode. Is there a way to enlarge the date up top, and change the thickness of the clock hands?
    12 Posts 2 Posters 2.8k Views 2 Watching
      briantogo
        sdetweil @briantogo
        @briantogo font-size was easy
        .clock .date {
          font-size: 60px; // or whatever
        the clock hands also easy as they are commented in clock-styles.css
        for hour hand
        .clock-hour {
          width: 0;
          height: 0;
          position: absolute;
          top: 50%;
          left: 50%;
          margin: -2px 0 -2px -25%; /* numbers must match negative length & thickness */
          padding: 2px 0 2px 25%; /* indicator length & thickness */
          background: var(--color-text-bright);
          transform-origin: 100% 50%;
          border-radius: 3px 0 0 3px;
        change 2 to something else, in all the places
        here (and in the screen shot) 4 in custom.css
        .clock-hour {
          width: 0;
          height: 0;
          position: absolute;
          top: 50%;
          left: 50%;
          margin: -4px 0 -4px -25%;   /* numbers must match negative length & thickness */
          padding: 4px 0 4px 25%;     /* indicator length & thickness */
        clock-minute for minute handle
        clock-second for second hand
          sdetweil @briantogo
          @briantogo yes, thru css. see clock_styles.css
          override that in the custom.css
            sdetweil @briantogo
            @briantogo see the second link in my signature below for help on how to use the browser dev window for css
              briantogo @sdetweil
              Thanks Sam. I could not find anywhere in the clock_styles.cs to change any of this. The closest I got was a setting under clock-hour/ width. I changed that to 2, and it had no effect. I could not find anything on changing the date size above the clock. And I couldn’t figure out the develpers window, that may be too advanced for me.
              Any other suggestions?
              Thanks,
              Brian
                sdetweil @briantogo
                .clock .date {
                for hour hand
                .clock-hour {
                  width: 0;
                  height: 0;
                  position: absolute;
                  top: 50%;
                  left: 50%;
                .clock-hour {
                  width: 0;
                  height: 0;
                  position: absolute;
                  top: 50%;
                  left: 50%;
                  briantogo @sdetweil
                  OK, so I get all this Sam, thanks for the help, but now I have a new issue. I’m using a Pi3, and I don’t think it has the horsepower to run Magic Mirror smoothly. The program frequently locks up, mmm-rain-map is the first to freeze. And now I can’t expand the various lines in the developers window.
                  So now I’m thinking of getting a Pi5 with 16 GB’s of RAM. What do you think?
                  Thanks,
                  Brian
                    sdetweil @briantogo
                    @briantogo you dont NEED to go all the way to 16g
                    4 is plenty, but the future is hard to tell
                      briantogo
                      Hi Sam, I loaded my new RPi5 with 16 GB’s ram, and boy does it fly!
                      So getting back to issue, I tried changing the clock hands in clock_styles.css. I changed the hour hand to 2 and changed the minute hand to 20, and could not tell the difference.
                      Also, I could not change the text size of the date above the analog clock. When I use the developer mode, I cannot expand
                      When I click the drop down arrow, it briefly expands then contracts again.
                      Any suggestions please?
                      Thanks,
                      Brian!
                        sdetweil @briantogo
                        @briantogo disable seconds for the debug then it will stay
                        you changed both values for both hands, right?
                        show your custom css for clock
                          sdetweil @briantogo
                          @briantogo said in I am using the default clock module in analog mode. Is there a way to enlarge the date up top, and change the thickness of the clock hands?:
                          don’t change them there
                          copy that whole css entry to custom.css
                          for each hand
                          don’t change our files
                            briantogo
                            Finally got it Sam, thanks for the help
                              sdetweil @briantogo
                              @briantogo awesome!!
