    Issue with MMM-Config
    7 Posts 2 Posters 1.6k Views 2 Watching
    • JohanbaJ Offline
      Johanba
      I am getting the following issue with the module MMM-Config
      I have updated, reinstalled but it seems the issue persists
      [2025-04-08 16:00:14.166] [ERROR] (node:3805) UnhandledPromiseRejectionWarning: Error: An error occured: 404
      at buildFormData (/home/johanba/MagicMirror/modules/MMM-Config/module_installer/runserver.js:138:11)
      at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
      (Use electron --trace-warnings ... to show where the warning was created)
      [2025-04-08 16:00:14.167] [ERROR] (node:3805) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag --unhandled-rejections=strict (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 1)
      S 3 Replies Last reply Reply Quote 0
        sdetweil @Johanba
        @Johanba on the road
          sdetweil @Johanba
          @Johanba the url changed, can you go to the MMM-Config folder and do
          git pull
          to update
          then restart MagicMirror
            sdetweil @Johanba
            @Johanba did you get this resolved?
            • JohanbaJ Offline
              Johanba
              HI
              @sdetweil getting the following message
              johanba@raspberrypi:~/MagicMirror/modules/MMM-Config $ git pull
              Your configuration specifies to merge with the ref ‘refs/heads/better_repo_url’
              from the remote, but no such ref was fetched.
                sdetweil @Johanba
                @Johanba just git clone. the improvements have all been incorporated
                  sdetweil @Johanba
