    MMM-Universal-Pir - Desparately seeking right command
    4 Posts 2 Posters 919 Views 2 Watching
      rkorell Module Developer
      Good eveneing, all.
      My mirror is working fine, I was able to configure a Raspi5 with bookworm and all migrated modules are working in this version.
      Because I have to keep in mind that my favourite MMM-Pir ( :-) ) won’t run that much in future I try to investigate alternatives.
      The most current module for PIR detection seems to be MMM-Universal-Pir.
      Unfortunately I’m not able to figure out the right commands (or the module doesn’t work - but I’ve seen some success messages).
      For some strange reason my Mirror-Autostart is configured with a X11 start, so on my bookworm instance I have disabled wayland to run MagicMirror in this mode, so “default” commands of module won’t definitely not work.
      I’ve found here around :
      “vcgencmd display_power 1” / “vcgencmd display_power 0” - on bookworm vgencmd doesn’t have this “display_power” option.
      “echo on | sudo tee /sys/class/drm/card1-HDMI-A-1/status” / “echo off | sudo tee /sys/class/drm/card1-HDMI-A-1/status” – this doesn’t do anything on my system - neither on terminal command-line nor in module.
      “DISPLAY=:0.0 xrandr --output HDMI-1 --off” / “DISPLAY=:0.0 xrandr --output HDMI-1 --primary --mode 2560x1440 --rate 59.951 --pos 0x0 --rotate left” are the most promising candidates - they at least are working on command-line in terminal
      But xrandr doesn’t work with MMM-Universal-Pir.
      (I’ve also tried to use these xrandr commands without display-reference
      (“xrandr --output HDMI-1 --off” / “xrandr --output HDMI-1 --primary --mode 2560x1440 --rate 59.951 --pos 0x0 --rotate left”* ) . Doesn’t work, either (from module).
      Is anybody out there with Pi5/bookworm/X11 with a working configuration / Command pair?
      And an additional question to those who are uing this module successfully: Is it true, that the countdown is not interrupted if a motion is detected ? (this is my impression when looking at the countdown - but may 1 Minute is too short) …
      Many thanks for any hint!
      Regards,
      Ralf
        rkorell Module Developer @rkorell
        @rkorell said in MMM-Universal-Pir - Desparately seeking right command:
        these are the right commands and are working now!
        (If one was not too blonde to switch the commands …)
        My fault - I’ve entered the on comand to the off parameter …
        Sorry!
        Regards,
        Ralf
        • R rkorell has marked this topic as solved on
          atwist
          I am trying to get this to work after no longer being able to use MMM-Pir. When the countdown hits 0 the screen goes black like it should . But, then it immediately turns back on even without motion.
          What am i missing?
          I’m using the DISPLAY=0.0 xrandr --output HDMI-2 --off
          It works fine from the command line but not within MM.
            rkorell Module Developer @atwist
            @atwist said in MMM-Universal-Pir - Desparately seeking right command:
            Dear @atwist, guessing from the distance is quite hard.
            You didn’t provide system information.
            From your told story you can try to check two things which came in my mind:
            1. PIR sensor: does this work correctly / is it adjustd correctly (on my sensor there are two screws to adjust distance and sensitivity.
              I had SERIOUS truble with theses settings and motion detection as my Pi5 gettih hot (caused by insufficient cooling)
            2. Screen/Monitor itself: Does some energy setting is causing the monitor to come back by itself?
            Good luck,
            Ralf
