    Issue with Outlook recurring events
    26 Posts 2 Posters 4.1k Views 2 Watching
    • W Offline
      WallysWellies
      Hello all.
      I’m having some issues with Outlook calendar events in the default calendar app and I think I have narrowed it down to a daylight savings issue (bug?):
      As you can see above, the recurring rule is expiring the evening before the event so these events do not show in my calendar.
      I realise this is looking like a Microsoft issue but I wondered if anyone had encountered this before and knows how to fix it?
      One thing that appears to work is setting my timezone to UTC then re-saving the event which I guess I can do unless someone has a better idea… Doing this sets the “UNTIL” time to 00:00 on the day of the actual event.
        sdetweil @WallysWellies
        @WallysWellies this fix sets the rrule:until to start of day+1 day for fullday events (tested in LA, Chicago, London and Sydney timezones)
        add three lines
        modules/default/calendarcalendarfetcherutils.js
        					event.start = rule.options.dtstart;  // old code line 294
                                                // insert these three lines
        					if((rule.options.until != undefined) && CalendarFetcherUtils.isFullDayEvent(event)){
        						Log.debug("fixup rrule until")
        						rule.options.until = new Date(new Date(moment(rule.options.until).startOf("day").add(1,"day")).getTime())
        					Log.debug("fix rrule start=", rule.options.dtstart); // old code line 301
          @WallysWellies if the event is a full day event(DTSTART:VALUE=DATE) then the rrule until should also only be date
          also full day events are considered local timezone only
          i dont think the parser (not our code) validates that
          oh, then rrule processes it ( also not our code)
          we call rrule.between() to get the list of events that match the rule between a year ago and an year forward(by default)
            @WallysWellies do you have that full VEVENT so i can look at its processing in both places as i work on both
            • W Offline
              WallysWellies @sdetweil
              @sdetweil Here is a problematic event:
              BEGIN:VEVENT
              DESCRIPTION:\n
              RRULE:FREQ=YEARLY;UNTIL=20250504T230000Z;INTERVAL=1;BYMONTHDAY=5;BYMONTH=5
              UID:040000008200E00074C5B7101A82E00800000000DAEF6ED30D9FDA01000000000000000
               010000000D37F812F0777844A93E97B96AD2D278B
              SUMMARY:Person A's Birthday
              DTSTART;VALUE=DATE:20250505
              DTEND;VALUE=DATE:20250506
              CLASS:PUBLIC
              PRIORITY:5
              DTSTAMP:20250428T133000Z
              TRANSP:TRANSPARENT
              STATUS:CONFIRMED
              SEQUENCE:0
              X-MICROSOFT-CDO-APPT-SEQUENCE:0
              X-MICROSOFT-CDO-BUSYSTATUS:FREE
              X-MICROSOFT-CDO-INTENDEDSTATUS:BUSY
              X-MICROSOFT-CDO-ALLDAYEVENT:TRUE
              X-MICROSOFT-CDO-IMPORTANCE:1
              X-MICROSOFT-CDO-INSTTYPE:1
              X-MICROSOFT-DONOTFORWARDMEETING:FALSE
              X-MICROSOFT-DISALLOW-COUNTER:FALSE
              X-MICROSOFT-REQUESTEDATTENDANCEMODE:DEFAULT
              X-MICROSOFT-ISRESPONSEREQUESTED:FALSE
              END:VEVENT
              And here is a working event:
              BEGIN:VEVENT
              DESCRIPTION:\n
              RRULE:FREQ=YEARLY;UNTIL=20250503T000000Z;INTERVAL=1;BYMONTHDAY=3;BYMONTH=5
              UID:040000008200E00074C5B7101A82E00800000000591C9B3BAA0EDA01000000000000000
               01000000005E6F2F9D20F7947B69F54FBF0794A6D
              SUMMARY:Person B's Birthday
              DTSTART;VALUE=DATE:20250503
              DTEND;VALUE=DATE:20250504
              CLASS:PUBLIC
              PRIORITY:5
              TRANSP:TRANSPARENT
              STATUS:CONFIRMED
              SEQUENCE:0
              END:VEVENT
              Thanks for taking a look.
                @WallysWellies thanks, forgot to ask what timezone you are in
                • W Offline
                  @sdetweil I’m in the UK. Since it’s British summer time I don’t know if that means I’m UTC+1 or something else… GMT, BST… Stupid changing clocks!
                    add three lines
                    • W Offline
                      @sdetweil Thank you - that has fixed my upcoming calendar event 👍
                      S 3 Replies Last reply Reply Quote 1
                        @WallysWellies cool, i will submit as a change for next release
                          @WallysWellies you will need to use my upgrade script and reply no to keeping the changed files
                          see https://github.com/sdetweil/MagicMirror_scripts
                          note upgrade is a two part process
                          test, do nothing (highlight exposed files, if any)
                          do upgrade
